Panasonic TX-26LXD8 stuck in standby.
+ More Options
Posts
  • py3m4n
    • Jul 2011
    • 99
    • Scotland
    #41
    Re: Panasonic TX-26LXD8 stuck in standby.
    I need to go just now but I will do as you asked and update in around an hour.
    • py3m4n
      • Jul 2011
      • 99
      • Scotland
      #42
      Originally posted by budm
      Take the voltage reading at PIN 1 when TV is first plugged into the outlet and also the power switch is activated, I want to see the output change state or not,
      Comes up to 2.74vdc and holds steady.
        Since the the reset line is holding steady and not going up and down in sync with the pin 52 of the controller IC, then we need to look some where else.
        • digimansam
          • Aug 2012
          • england
          #44
          hi did anyone solve the fault on this Panasonic TV as i have the same fault
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #45
            It would appear not - thread seems to have petered out,- if you want help to troubleshoot yours please confirm this is the fault you have to save everyone looking back.
            "Fault - When turned on Standby light lights up then goes off immediately. PSU clicking."
            Have you done any testing that has been done in the thread.
            Please advise the part numbers of your boards and say if they are the same as in the thread.
            Please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
            Examples of what is needed
            https://www.badcaps.net/forum/attach...1&d=1290283049
            https://www.badcaps.net/forum/attach...7&d=1280167246
            It will be useful if you can say a bit about yourself - skills tools etc.
            • BobbyMJ
              Panasonic TC-P60S30 - no standby voltage
              by BobbyMJ
              Hi All,
              Wanting to learn some electronics repair skills.
              I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
              So far I have found a blown cap on the main power supply board.
              After replacing it there's still no standby power.
              Poked around and found a resistor on the PSUB power supply board that measures open.
              An online resistor calculator shows this is a 93k ohm resister.
              My questions:
              Is that correct, 93k ohms?
              Is it a fusible resistor?
              Lastly, how do I know what wattage?...
              05-14-2025, 06:42 PM
            • lepak06
              TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
              by lepak06
              Hello
              I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
              The TV is faulty with stuck in Standby RED LED. Can't power the TV.
              Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
              All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
              But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
              01-12-2023, 01:43 AM
            • toty79
              Hisense LTDN50K220WSEU stuck in standby
              by toty79
              Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
              As per Hisense tv title LTDN50K220WSEU stuck in standby
              PSU rsag.820.5687 HLL 4855WF
              Main rsag 7.820.5842
              I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
              05-01-2022, 04:39 PM
            • lego1234567
              LG 32LB1R - stuck in standby mode
              by lego1234567
              Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
              What could be the problem ? Thanks...
              01-21-2024, 03:39 AM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
