Panasonic TX-26LXD8 stuck in standby.
  • BobbyMJ
    Panasonic TC-P60S30 - no standby voltage
    by BobbyMJ
    Hi All,
    Wanting to learn some electronics repair skills.
    I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
    So far I have found a blown cap on the main power supply board.
    After replacing it there's still no standby power.
    Poked around and found a resistor on the PSUB power supply board that measures open.
    An online resistor calculator shows this is a 93k ohm resister.
    My questions:
    Is that correct, 93k ohms?
    Is it a fusible resistor?
    Lastly, how do I know what wattage?...
    05-14-2025, 06:42 PM
  • lepak06
    TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
    by lepak06
    Hello
    I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
    The TV is faulty with stuck in Standby RED LED. Can't power the TV.
    Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
    All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
    But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
    01-12-2023, 01:43 AM
  • toty79
    Hisense LTDN50K220WSEU stuck in standby
    by toty79
    Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
    As per Hisense tv title LTDN50K220WSEU stuck in standby
    PSU rsag.820.5687 HLL 4855WF
    Main rsag 7.820.5842
    I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
    05-01-2022, 04:39 PM
  • lego1234567
    LG 32LB1R - stuck in standby mode
    by lego1234567
    Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
    What could be the problem ? Thanks...
    01-21-2024, 03:39 AM
  • Nevillet
    Panasonic SA-PM71SD Micro HiFi - not comming out of standby
    by Nevillet
    Hi All,
    I have the above mini HiFi that after powering displays the standby LED and when the power switch is pressed the relay momentarily clicks in then cuts out again.
    I've included an image of the power board schematic.
    There is 5.9V present on pin 4 of CN507 and when the standby button is pressed 2.6V momentarily appears on pin2 of the same connector.
    Any thoughts would be welcome.
    The service manual exceeds the Badcaps file size limit but it can be found here:...
    08-24-2023, 10:58 AM
