Sony Bravia KDL-52W5150 - Are These Symptoms Of A Bad T-Con?
  • NoEcm
    • Mar 2012
    • 13
    Re: Sony Bravia KDL-52W5150 - Are These Symptoms Of A Bad T-Con?
    Originally posted by budm
    I would check the ESR and value (check them when they heated and cooled) on those caps in circle and also the one next to the SMPS IC. The voltage is only off by 3% which is acceptable.
    I pulled the caps you suggested and tested them both hot and cold. All tested good but I replaced them anyway since they wer already out.
    Still having the same problem(s) as described in the above postings.
    At this point, would my next step be to simply replace the T-Con (~$60 or so)?
    • cashkennedy
      • Aug 2011
      • 668
      When you heat that part before plugging in the set, and then plug it in and turn it on (the voltage should be around 12.1 or so at that point), does the TV work then? Cause if its a power supply issue why would you replace the tcon.
      But if the problem doesnt go away just because the voltage is raised, then might be tcon.
      > After rereading everything said so far, i would try leaving it off all night, then heat the part a good bit, then turn on the tv and if it works right away, then you know its just the power supply at fault.
      If the picture is still kind of bad, it might still be the power supply just an issue more with the shape of the output and not the just the voltage value. I think budm would say to be more wary of / suspect the power supply since it already appears to be malfunctioning if heat causes it to change from out of spec to within spec for the voltage.
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      • ethanhunteg
        • May 2012
        • 5
        I'm having the exact problem as in the first post. Occasionally (might be as few as every other or third day and as often as every few minutes) the screen will either start up or start going into that bad picture. Its essentially the dark lines rotating horizontally across the screen (includes over menu screens and title/info screens) with a brighter area in the lower left corner. When this condition happens i'm also getting a buzz/ higher pitched noise constantly.
        I'm really interested to see what ends up helping the OP or if others have ideas. I have a KDL-52W5100, so its a very similar set too. I'm pretty technically adept but not in the realm of voltage/ electricity so I don't know that I'll be able to peel off the back to run voltages tests without pretty detailed instructions. lol
        Next time it happens I'll capture a short video and some pictures.
        • ethanhunteg
          • May 2012
          • 5
          Okay I have captured an albeit lower quality video. Sorry about the bouncing around I was switching remotes a few times. And some pictures.
          http://www.youtube.com/watch?v=gEw9Hg2k1Ys
          Pictures -
          As you can see its really similar to the OP. Is there any way to find out if it were the t-con board or the DC power?
          • JimmysTGP
            • May 2012
            • 45
            • US
            I just had a KDL-52XBR4 here and had those horizontal lines yours had, so we replace the the T-CON and did not fix the problem, however it did have a little different picture than yours, also yours is not an XBR. I would try T-CON first because its the cheaper of the two.
            • ethanhunteg
              • May 2012
              • 5
              I'm finding that it happens a lot when the TV has been off for a while when it first starts up. It seems like once it has been on for a while, usually after a few restarts, then it seems to go without issue.
              Ex. Turn it on, problem starts within the first minute or two
              Restart and a few minutes later it will happen again, restart
              5 or 10 minutes later it might happen again, restart
              then it might run for hours and not happen again till after the TV is off and idle for an extended period of time.
              • NoEcm
                • Mar 2012
                • 13
                Using a can of freeze spray, I thought I could isolate the problem board or component. I slowly sprayed a board and waited a few minutes to see if the results would appear, then moved to the next board. Nothing. Than 30 minutes later, something new showed up on the screen. Picture is now washed out with 4 vertical grey stripes on the left side:
                And if I disconnect the T-Con ribbon cable that feeds the right side of the TV so that there is only a feed to the left side:
                And if I disconnect the T-Con ribbon cable that feeds the left side of the TV so that there is only a feed to the right side:
                Looks like I can remove signal from the right side of the screen by disconecting the T-Con ribbon cable but if I remove the left side ribbon, it still shows the same picture no matter what.
                Based on the above results, did I permanently kill the T-Con (or Main Board) with my freeze spray?
                Any thoughts, advice or further troubleshooting steps would be greatly appreciated.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Did you restart the TV?
                  • NoEcm
                    • Mar 2012
                    • 13
                    Yes, TV has been power cycled several times with the same results.
                    So I'm thinking either the T-CON for left side is bad or the left side LCD Panel is bad.
                    Thoughts?
                    • danielg4
                      • Jul 2012
                      Hi. I was at a thrift store and saw a TV on the shelf, stamped "AS IS, U FIX IT, NO RETURNS," and I figured I'd take a look, trying to turn it on right there in the store. It refused to power on at all, so I figured it was likely something simple, and I bought it. At home, I don't remember what I did, but I got it to power on. I speculated it was some kind of NVRAM corruption at play. I got sound but no picture, with the screen looking exactly like the first photo in this thread. After extensive searching on the web, I found this thread and decided to take a gamble: I ordered a replacement T-con on eBay. With the T-con replaced, the screen immediately came to life! However, the voltages I see being fed from the power supply worry me: 23.9V on the 24V rails, 5.13V on the 5V rails, and 11.86V on the 12V rails. I do not know where on this power supply I may find the regulator for the heat test in this thread. I do not want the second T-con to die from possible under-voltage, especially considering the initial power issue. The TV is an Ölevia 427-S12. Advice? Thanks in advance.
                      Edit: I forgot to mention: There are a total of ten electrolytics on the power supply, a Delta DPS-161AP-E, and none with any visible decay.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        The above voltages are fine. In most TVs, none of them are regulated with any sort of accuracy/precision on the power supply. Voltage regulators on the main board are more likely to be +/- 1% of their stated value.
                        --- begin sig file ---
                        --- end sig file ---
                        • danielg4
                          • Jul 2012
                          OK. What worried me about that was the mention in this thread that lower temperatures could lead to noticeable voltage differences. Is none of that significant either?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Lower operating temperatures should results in increased reliability of the t-con. In all these super thin TVs, there are no cooling fans so heat rises. The t-con is at the top and gets the brunt of the heat.
                            There are voltage regulators or DC/DC converters on the t-con. Both will regulate the output voltage to +/- 1%. They can take in a wide range of input voltages (high and low).
                            • danielg4
                              • Jul 2012
                              But what about the temperature-triggered voltage regulator weirdness in the power supply described earlier in the thread?
                              • Lykkan
                                • Oct 2012
                                • 5
                                Any update on this? My tv is having the same issue (kdl-52w5100)
                                • ethanhunteg
                                  • May 2012
                                  • 5
                                  My TV's issue has morphed now. It now on a cold startup has a tunnel / ring hazing effect. In the center of the screen the refresh rate seems normal and motion doesn't blur the image, however around sides and edges of the screen it has a dark blur and images update very slowly. If I turn if off and on it initially corrects nothing, the same behavior is exhibited when it turns back on. However, after the TV has been running in this blurry tunnel state for a good half hour turning off and on the TV corrects the issue and it operates normally from that point forward so long as I don't power it down for any period of time.
                                  I imagine that the effect would be pretty trippin if I were high, but for now it essentially has turned an otherwise great TV into something so annoying because we must wait about 30 minutes of it running before it starts actually working correctly.
                                  I have not replaced any parts as I can't really get a clear confirmation of if anything will help the issue based on others that may have experienced this same issue. If I get a chance i'll try to upload pics of the tunnel blur vision condition it now exhibits.
                                  • Lykkan
                                    • Oct 2012
                                    • 5
                                    These are about the exact same symptoms my tv is having. Flexing the tv does nothing, and I really don't believe it's a TAB problem and I'm still leaning towards a voltage problem, but I'm moving really soon and don't have time to look at it.
                                    • Lykkan
                                      • Oct 2012
                                      • 5
                                      Problem ended up being a bad tab... look up youtube videos on repairing. Was the top left one.
                                        Yes, top left tab.
                                        http://s807.photobucket.com/albums/y...20KDL-52VL150/
                                        • Lykkan
                                          • Oct 2012
                                          • 5
                                          you fix yours too? bought for $85, sold for $400 $$$
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • PopsCaps
                                            Sony Bravia KDL-40V2500 that will not power on
                                            by PopsCaps
                                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                            I do not hear any sound and I cannot see any backlight.
                                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                            03-25-2025, 11:23 AM
