TECHNIKA LCD19DVDID-107 - Stuck in standby
  • Jasgriff
    • Feb 2012
    • 578
    Picked up 2 of these TV's with the same issue.
    Thought I would share the fix with you in case you come across one of these in the future.
    They both had 2 blown 25v1000uf caps that needed to be replaced. I have attached a picture of this below.
    When the TV was put back together the DVD wouldn't play (something I should have checked before putting it all back together really!). I took it back apart and took out all 4 screw holding the DVD drive in to give me just enough room to move the drive out a little to clean the lens without having to remove the ribbon cables. These are glued and they hover over the power supply so I didn't want to worry about them coming loose in the future.
    Put it all back together again and hey presto all up and running and the dvd is now running well. I'm actually playing some music in the background on it as I write this!
    P.s I know the pictures are of the worst quality I need to get my proper camera back of my sister! Hopefully they are clear enough to give you an idea of what's going on.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    Re: TECHNIKA LCD19DVDID-107 - Stuck in standby
    Nice. Another example of cheap and rubbish supermarket TVs... Tesco looks like they chose the lowest cost OEM they could!
    • Jasgriff
      • Feb 2012
      • 578
      Yep it looked awful and cheap inside!
      • Techstar
        Tv Restoration
        • Dec 2012
        • 122
        • United Kingdom.
        Yep these 2 caps fail often , They are marked on the pcb as C34 AND C49.
        They go leaky usually. There is a 16 volt 680 uf close to these two, i usually
        change it too even if it measures ok as it usually does.
        • Goldieoldie
          • Jul 2014
          • 15
          • England
          I have a technika LCD tv model no. M19n11n02g 801 DVD combi
          The other number on it is lcd19dvdid-307
          I think it has umc of Slovakia boards inside as the code 9735 ( which I've been told is a umc code ) works to access the DVD region menu
          I've tried vestel codes with no luck
          All works fine incl analogue Tunning
          In digital mode the symbol in the menu for Tunning is greyed out,so cant retune in digital mode
          I've tried general reset to no avail
          I would like to try a factory reset in the service menu but I can't find the code anywhere
          Does anyone please know this code or recognise this fault please ?
          Cheers ,Pete
          • selldoor
            Slow Learner
            • 7870
            Have you seen it working on current digital tv signals a lot of these old sets were made redundant. Sometimes you have to them in non digital mode to get to the menus as they are basically non digital sets with an add on. You need the remote to do that. Easiest way might be to get a free freeview box
            on freegle or freecycle?
            • Goldieoldie
              • Jul 2014
              • 15
              • England
              Hi
              Thanks for your reply.
              I have not seen it working in digital mode as it was bought second hand
              In digital mode (it's an option in the menu ) it's showing all the usual channels but no signal as it was used in a different location with a different transmitter
              I'm hoping a reset in the engineers menu might sort it
              • selldoor
                Slow Learner
                • 7870
                It will always show channels until you scan without an aerial
                then it will lose all the old ones - put the aerial back in and scan again.
                Have you read the handbook ??
                Page 20 has a systems settings option then in that select first time setup.?
                • Goldieoldie
                  • Jul 2014
                  • 15
                  • England
                  Sorry,No I do not have the manual
                  How do you go about the first time installation please ?
                  • Goldieoldie
                    • Jul 2014
                    • 15
                    • England
                    Should have said there is no first time installation option in the menu
                      • 31285
                      factory reset code will cause that menu to appear.
                      • Goldieoldie
                        • Jul 2014
                        • 15
                        • England
                        Thanks,but I don't know the factory reset code
                        Do you know please ?
                          • 31285
                          nope
                          • Goldieoldie
                            • Jul 2014
                            • 15
                            • England
                            Sorted !
                            Thanks to everyone for there help
                            Cure is to use a one for all remote
                            I used the Urc 6440 which is a good one to have as it is upgrade able
                            Use one for all code 2426
                            On this particular remote the key marked text becomes the digital tv menu !
                            There you can do a first time install to find any new digital channels
                            Cheers Pete
                            • jordi12
                              • Apr 2017
                              Hi there, I'm fairly new to DYI tv fixing. I got a TECHNIKA LCD19DVDID-108 and suddenly while trying to reprogram the channels it stopped working. The screen went off and the red standby led started blinking every time I turn it on. No sound no signal and no screen light. Reading over the internet I read a common fault is a blown PSU so I bought a replacement. Surprisingly when I opened the TV set, the TV's PSU seemed ok. Nevertheless I connected the new one, (without the lamps, the new psu came with different molex connectors), however it still did not work. I'm attaching a some pics of the original PSU. Any help would be greatly appreciated!
                              • lepak06
                                TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                by lepak06
                                Hello
                                I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                01-12-2023, 01:43 AM
                              • toty79
                                Hisense LTDN50K220WSEU stuck in standby
                                by toty79
                                Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                As per Hisense tv title LTDN50K220WSEU stuck in standby
                                PSU rsag.820.5687 HLL 4855WF
                                Main rsag 7.820.5842
                                I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                05-01-2022, 04:39 PM
                              • lego1234567
                                LG 32LB1R - stuck in standby mode
                                by lego1234567
                                Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                What could be the problem ? Thanks...
                                01-21-2024, 03:39 AM
                              • Stunt
                                Hp Laptop Stuck on Hp protected by hp sure start screen
                                by Stunt
                                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                screen that's it and stuck there. I left it until the following day and i still...
                                09-02-2025, 01:51 PM
                                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                by sam_sam_sam
                                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                I am comparing them to a brand new one that I installed
                                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                I going to let it run for several days before I remount back on the wall next to the...
                                09-05-2024, 06:48 PM
