A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
+ More Options
Posts
  • smg496
    #41
    Re: A guide to fixing/troubleshooting some common plasma TV problems
    Thanks for the rapid reply on 8th Jan Tom, VERY much appreciated! Apologies for the slow 'thanks' and follow up. I thought I may aswell upload a .jpg of the TV switched on with no input just so you can confirm your fatal diagnosis. It's just the coloured lines (they're all stationary but some flicker) that are the issue when there's an input. Looks like I may be selling spares on eBay in the near future I fear... ;0(
      That is most likely a bad plasma panel. Sorry, but it is not repairable.
      • smg496
        #43
        Many thanks Tom! Probably the best Forum I've used...
        • dotcalminc
          • 28
          @tom66, i did place this in another thread, but i'm going to reply here to follow your reply. I did try to change the t con board and got the same outcome. Tab bonds? what does that look like or what do I need to do to repair it? Thanks for your wisdom! Shared knowledge is so awesome.
            Tab bond repair for different fault, same cause:
            https://www.youtube.com/watch?v=xHst6pKLtTE
            (Not my video, but he's excellent at describing the repair of this so I always link to it.)
            • DavidOH
              • May 2012
              • 105
              I put this in the wrong thread the first time. So let's try this again. I've found this to have useful information. At least for me.
              http://youclickspk.blogspot.com/p/te...omponents.html
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #47
                a very good guide thanks for the link some good tips for a novice like me.
                • DFM379
                  • Feb 2013
                  • 10
                  I own a Pioneer Elite FHD1 plasma that was purchased new many years ago. Yesterday, the set powered itself down with a fault (Red) code of 4. Now there is a large horizontal band running across the lower section of the screen about 3” from the bottom. It's about 5” wide, white with a 1 inch black band about 2/3 of the way down. The stripe shows on the screen when the monitor is initially turned on before the picture comes on only it is a muted grey. Occasionally the set powers down with the same fault code (4). I would appreciate hearing what you think the problem is…..
                    That could be a bad plasma panel. A picture of the exact fault would confirm the diagnosis. 4 blinks possibly means short on plasma electrode. Unfortunately, it is probably not repairable.
                    • DFM379
                      • Feb 2013
                      • 10
                      Could it be the Y Drive assembly or the lower buffer board? These are the boards listed for the fault in the repair manual.
                        Hmm, horizontal is left to right. Derp. Not top to bottom, which is panel failure. Left to right may be a Y-drive or Y-scan problem, more likely to be Y-scan (I think that's what Pioneer call them.)
                        • DFM379
                          • Feb 2013
                          • 10
                          I ordered the Y-Drive assembly and the Lower Y-scan board since the problem is in the lower half of the screen. One Scan assembly is labled Lower (A), the other is labeled High (B). They look exactly the same. I assume the one labeled lower controls the lower half of the screen. Sound reasonable?
                            Yes. You can sometimes run this set with only the top buffer installed. You should get a good top half.
                            • DFM379
                              • Feb 2013
                              • 10
                              Here is a photo of the issue - the line remains the same if you switch to an input with no signal.https://www.badcaps.net/forum/attach...1&d=1360112045
                                OK, I change my diagnosis. Definitely looks like a Y-buffer issue to me. I hope a panel fault did not damage the buffer, though, that is rare and only happens on certain older Panasonic plasmas as far as I am aware.
                                Damn nice TV when working!
                                • DFM379
                                  • Feb 2013
                                  • 10
                                  OK, so do you think it is the drive board, the scan board, or could be either so better to replace both? I already ordered both boards, but they came out of an old FHD1 and are used.
                                    I think the SUS (drive-board) is probably OK, but the lower SCAN is bad.
                                    • DFM379
                                      • Feb 2013
                                      • 10
                                      Well the problem got worse today. The TV powered down and won't come on fully anymore. Turns on and powers off at the point when the picture normally comes on. So I took it off its base and opened it up in preparation for the part swap. I think I may have found the bad IC on the scan board (see Photo). I'm still up in the air on changing both boards at the same time or one at a time. Could the drive board cause the problem with the scan board?
                                        Yes, that IC is definitely very bad.
                                        The drive board (when it fails) usually kills either: all the ICs, or the top/bottom most IC. It's very rare for one in the middle of the pack to fail. And as far as I am aware, like most well designed TVs, a failure in the drive board on a Pioneer does not damage the buffer ICs.
                                        You should only need to change the lower board... however, if you've got both, swap both for longevity.
                                        I hope the panel is OK, because I know some Panasonic panel failures can damage the buffers. But I thought it only happened to certain older series. Don't have much info on Pioneer unfortunately.
                                        • m4malious
                                          • Feb 2012
                                          • 13
                                          #60
                                          Tom said "post a thread - the problem is more complex" so here goes...
                                          - LG 42PX5D
                                          - exact history detail unknown as its a donation to me
                                          - powers on ok
                                          - image shows as lilac (purple,reddish) just as described in first post of this thread about z-sustain failure
                                          - fuses on z-sus are ok
                                          - power supply voltages all appear in spec
                                          - issues is hard regardless of input or settings
                                          Suggestions?
                                          M
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
