A guide to fixing/troubleshooting some common plasma TV problems
This topic is closed.
+ More Options
Posts
    Re: A guide to fixing/troubleshooting some common plasma TV problems
    Sort of went pink before going dark completely?
    • mph8783
      • May 2013
      • 20
      Nope, no pink. Just like somebody had unplugged the video source(or psu), but as there is now not even a glow or snow I was suspecting y or x drives rather than logic board.
        OK, I suggest you start a new thread and I and others will try to help you there. It is best to keep this thread for common questions only rather than repair history.
        • mph8783
          • May 2013
          • 20
          Ok, new thread is here
          https://www.badcaps.net/forum/showthread.php?t=28761
          • minhphuongpham
            • May 2013
            Originally posted by tom66
            Since they are vertical, it is most likely the plasma panel data drive ICs. These are not replaceable. However, if they are moving, it could be the control board or distribution board.
            I have a Samsung plasma PN50A450 (720 p). Lately there is a 2" wide black line running from top to bottom of the screen (as if it splits the screen into 2 halves right at the middle). Can this problem be fixed? Thank you for assistance
              I've answered in your thread.
              • ieronymous
                • Jun 2013
                • 9
                • Athens
                #147
                hello
                I would like an opinion about my problam if possible. I have for 2.5 years a 42 panasonic tx-p24u20e plasma screen and suddenly nefore 3 days averical stripe appeared in the middle of the screen up - down i thinnk its cloour its blue and its wide its always the same. I ll try to upload some pics
                heres one
                can i do something to fix it?
                any ideas about the cost to fix it?
                  Cost, likely $0.00.
                  You have a very common fault with this model, a loose connector on the bottom of the plasma panel. You will need to turn the set off, take it apart, and reseat all of the connectors along the bottom of the glass panel. If you need help, post pictures of the chassis.
                  Extremely important: At no point during reseating the cables should you be tempted to power up the set and then attach a cable, doing so runs a high chance of damaging the plasma panel, which would not be repairable. Always turn the set off before making changes.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    And wait 30 seconds or more to allow the caps to discharge to be safe.
                    • ieronymous
                      • Jun 2013
                      • 9
                      • Athens
                      #150
                      Thank you fro your quick reply ... the tv hasnt been moved at all from its current position how's the connector loose? Is there a picture guide of doing the procedure you told me?
                        It wasn't seated at the factory right, and as the set heats up in operation then cools down after being off they can work their way loose. I have encountered several different sets with loose cables being the only fault (3 out of about 50 TVs fixed so far.)
                        • ieronymous
                          • Jun 2013
                          • 9
                          • Athens
                          #152
                          Thank you Tomm .. well is there a wayu to post me a link or by its mechanicalk drawing cyrcling the spots i have to check?
                          ps first time i open a tv
                            Can you show us a picture of what is inside of your TV?
                            • ieronymous
                              • Jun 2013
                              • 9
                              • Athens
                              #154
                              hm.... i cant unplug it right now ... tomorrow probably ... are the connectors you mentioned the same as the flat line on laptops? connecting vga with screen?
                              i ve seen a video but for a different kind of problem
                              http://www.youtube.com/watch?v=EhRDSY4RCt4
                              are these the connectors?
                              • ieronymous
                                • Jun 2013
                                • 9
                                • Athens
                                #155
                                i think this is it
                                http://www.youtube.com/watch?v=-iAm82lhky4
                                  Different fault and different cause for that first one &
                                  The plasma in the video is 5 years older and so very different.
                                  It may be loose LVDS like for laptop; though my opinion is it is more likely panel or C board loose connection.
                                  You NEED to get us a picture of YOUR TV, not of someone else's, not of a different model, because Panasonic are so very fond of making fairly major changes to their panels in the same production year, which may make our guidance inaccurate unless we have exact pictures.
                                  • ieronymous
                                    • Jun 2013
                                    • 9
                                    • Athens
                                    #157
                                    Tom i didnt sent the video because i had the same problem but to show me the spot where i ahve to remove the ribbon cables. Anyway i am sending some pics of my tv backplate
                                    first a small video (inform me if you can see it )
                                    https://www.facebook.com/photo.php?v...type=2&theater
                                    and some pics
                                      The display is divided into 15 portions horizontally (along the width of the TV.)
                                      Of these portions, how much would you say is affected?
                                      • ieronymous
                                        • Jun 2013
                                        • 9
                                        • Athens
                                        #159
                                        Icant understand what you are saying ... too much technical info...nevertheless i thouhg that the procedure was only to disconnect ribon cables, The only thing i can say is the the stripe is vertical at the middle of the screen all the way up -->down and has width 2.5 cm
                                        you also wanted to see the inside of the tv ... your question has nothing to do with the pictures like i have never posted them
                                          I already saw the pictures. I just needed you to clarify.
                                          In this image:
                                          http://i40.tinypic.com/mmr604.jpg
                                          along the bottom of the display you have some flex connectors and metal plates with two screws on them. You need to remove the screws and connector, then reseat the connector and screw it back down. You only need to do the faulty one; locating it can be done by estimating the general area the fault is in.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
