phillips 47pfl7422d is dim on left side of lcd
  • scapino
    • Jun 2013
    • US
    Re: phillips 47pfl7422d is dim on left side of lcd
    @ Tom66 and/or anyone -
    I've removed all four 680uF / 35V caps. I've got a couple 1000uF / 50V caps from work - do you think I can use these or should I just order the correct caps?
    I'm a field engineer, not a design engineer. If I remember my college days correctly, I should still be within the 20% tolerance if these are wired in series. However, if they are wired in parallel then I'd be well over 30% off on total capacitance. I'm assuming they are just starter caps, and taken out of the circuit once fully energized?
    Thanks again!
    -j
    • newtothis
      • Mar 2013
      • 1556
      • england
      Well I found out that it totally depends on the circuit that is being worked on... For example whilst learning I changed a cap for a higher microfarad and voltage and it dodnt cause an issue, Did the same thing on another board and when plugged in... BANG! Fried 5 SMD ceramic resistors Lovely smell it made too but i fixed that and put the correct caps on and working fine.
      Someone else will be able to give you a more precise answer as I'm still learning but thats my view anyway
      • maiden790
        • Nov 2014
        • 94
        Hi I have the same issue, slave had bad caps, replaced them, still dim. Looked at the ceramic fuse and it looks fine but then again a literally looked, I don't have a volt meter yet. What the hecks wrong with this thing?? Someone please help me out with this one please
        one mans is another ones treasure
        • maiden790
          • Nov 2014
          • 94
          okay i found out it is INDEED the ceramic fuse? now how do i look up the correct one and buy it in the united states?? its a KOAC 10A
          • Widgeteer
            • Sep 2015
            Same Issue Here. No backlight, all 4 caps on inverter boards bad. Replaced 4 caps with replacement suggested on first page and left side still dim. Soldered jumper onto ceramic fuse and works perfect. Now ordering replacement for ceramic fuse, then fixing correctly.
            • cervega
              • Dec 2016
              • 3
              Replaced capacitors on the slave left side(there were burnt up, and I tested them for fun)- didn't work.
              Replaced slave inverted board - didn't work.
              Power going to master and slave are constant 24volts
              Does this mean the bulbs are bad?
              • wiru
                • Nov 2015
                • 13
                • Lithuania
                #27
                Have you checked the fuses? Based on other replies in this thread, these could be o/c.
                • cervega
                  • Dec 2016
                  • 3
                  Tested fuses they were fine on the inverter boards.
                  Is there any other fuses I should test, I saw a couple others fuses on the power board amd they tested fine as well.
                  • cervega
                    • Dec 2016
                    • 3
                    Can you replace the master board with a slave?
                    • Stephen
                      A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                      by Stephen
                      Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                      05-29-2025, 10:35 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • ravi_1617
                      HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                      by ravi_1617
                      Hello to all ,
                      I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                      Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                      on external VGA port image is perfect /normal , Attached image...
                      07-25-2025, 12:07 AM
                    • Gjackson
                      SMEG induction cooker error EA on both left hand side cooktops
                      by Gjackson
                      I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
                      07-09-2024, 01:46 PM
                    • valvashon
                      Samsung UN60JU6500, stripe on left side of screen
                      by valvashon
                      Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                      Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                      Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                      Thanks, Val
                      11-21-2025, 03:01 PM
