A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • dbuergi
    Macbook A2442 no display board 820-02098
    by dbuergi
    i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
    So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
    05-25-2025, 10:58 AM
  • TechSplendid
    MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
    by TechSplendid
    Hi All,
    I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
    Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
    04-09-2025, 02:13 AM
  • tyler_jones8209
    2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
    by tyler_jones8209
    So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
    I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
    I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
    I don’t have much experience with laptops, only consoles and controllers...
    Yesterday, 04:54 PM
  • gurpawan
    A2442 14inch Macbook Pro ,JR940 Connector- where to buy?
    by gurpawan
    Hi, can anyone please advise on where to buy the JR940 microphone flex connector? I accidentally broke it while repairing A2442 14inch Macbook Pro 2021. it came off....
    10-22-2025, 02:40 PM
  • rounin
    MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
    by rounin
    Device Information
    • Model: MacBook Pro 14” M1 Pro (A2442)
    • Logic board number: 820-02443-05
    Original Issue
    The device suffered liquid damage, causing a short circuit on the logic board.
    Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
    Work Performed
    Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
    Current Status
    • When powered on, the screen shows support.apple.com/mac/restore....
    10-20-2025, 11:15 PM
