Philips 37PFL5322D/37 Chirping from psu
  • dafrizzy
    • Dec 2013
    Re: Philips 37PFL5322D/37 Chirping from psu
    Found this same tv in the trash almost a year ago. It worked fine until last month but then began turning off randomly before finally going out tonight for good. This thread has been a huge help. Thanks and hopefully these repairs work!
    • Bignew
      • Apr 2014
      My TV started chirping like a bird yesterday. how difficult is it to replace the diodes? Is soldering involved or is it plug and play?
      • philliesfan30m
        • Aug 2013
        • 542
        soldering is involved.
        • Bignew
          • Apr 2014
          Oh boy, thanks
          • lizzrd
            • Jun 2014
            • 21
            I also have this Philips LCD, really liked it until yesterday. After finding this site and this thread, i am thinking of replacing these caps with the Panasonic FM series.
            I do have a question about the 2-3 diodes mentioned on the first page next to the transformer. There is a link to one of them, but i am not sure yet if they are all the same ?
            Thanks for anymore info or instructions...
            • lizzrd
              • Jun 2014
              • 21
              Rereading the thread and checking the pic, one is different. Mr.Bill said he replaced diodes, 2, next to the transformer, location zd902 and zd904.
              budm has a link to the 'one' Bill replaced, a snubber circuit? So this is where i am confused. I would like to do all three if i could get another diode part #. Would that be the thing to do ? , again thanks in advance.
              • lizzrd
                • Jun 2014
                • 21
                I have my board out and ready to order some parts. I guess i am still looking for clarification on the 3 diodes... zd902 + zd904 next to the transformer are P6ke zeners.
                I cannot read or find info for the one at position D925 ? is this a zener diode also ?
                • ktgohdt125
                  • Jun 2010
                  • 10
                  #28
                  D925=UF1007 (UF1007. 1.0A ULTRA-FAST RECTIFIER)
                  here i attach a 37" to 47" PFL series of service manual look from pg 57 to 63
                  hopes this help those who need it.
                  regards
                  ktgoh
                  • lizzrd
                    • Jun 2014
                    • 21
                    I can not say " i can read an electrical circuits' drawings" , but thanks for your reply.
                    I google that uf1007 and found nothing like it at Dig-it-Key... ?
                      • 31068
                      uf4007
                      • lizzrd
                        • Jun 2014
                        • 21
                        Thanks for your replies and help...
                          Digikey, UF1007:
                          http://www.digikey.com/product-detai...DITR-ND/248654
                          Mouser:
                          http://www.mouser.com/ProductDetail/...XLfVE5J3hj8Q==
                          Spec:
                          UF4007 will work
                          • lizzrd
                            • Jun 2014
                            • 21
                            well, a bit disappointed, had a guy at the PC repair shop solder in the two P6KE diodes next to the transformer (ZD902 + ZD904) and the other
                            UF1007 in the D925 spot.
                            He also replaced the 3 large caps. with newer FM series. He did not replace the large cap that is by itself. It did not look bad like the others, but he said it was different ? I guess i thought all the caps circled were the same and ordered 4. His work looked good.
                            So, the tv came on, no chirp, no picture , but it had sound.
                            Any thoughts on my next move ? I almost bought an iron to do this but did not want to screw up my board. I do have a Sunpro multi-meter...
                            • lizzrd
                              • Jun 2014
                              • 21
                              what if i replaced the pin plug?, the one with all the little wires,
                              onto the wrong set or bank of pins ?
                              i am talking about the two rows next to the 'Badcaps' in the first pic...
                              • orgwood
                                • Apr 2013
                                • 39
                                I need your help. I grew up learning linear PS design but never switchers. I know about PWM so I assume it has something to do with that. Here's where I am with this particular problem...
                                I replaced all caps and the 3 diodes with a kit I bought from a reputable seller. Still ticks but doesn't sound like a chirp to me. Replaced the 2 diodes in the 12VDC rail...BTW I found a schematic online for this PS so I'm able to deal with section testing. I'm uploading it...mine's the 37". These seem to be used on Magnavox sets too, maybe others.
                                I measured the 2 rails and only the 12VDC is working. I put my Oscope on both sections -luckily they are very similar in design and I have almost a sine wave across both zener sections going into the FETs. I pulled the output diodes from the output transformer for the 24VDC section and tested them with the MMeter diode range and the look good. So I went back to the main DC rail that feeds both sections and of course its working since the 12VDC section works. Then I pulled some of the middle diodes for testing and they seem okay. I'm pretty certain the ticking noise is coming from the 24VDC output transformer T905 but I can't believe it's bad since I think they are pretty durable. Do bad output caps cause it to short? ANY way to test it with an ohmmeter or Oscope in circuit.
                                  12V is an always on power supply, the 24V is the switched supply that has to be turned on by the command signal at the STANDBY pin, it needs about 3VDC and secondary side GND at that pin. to turn on. This signal is also used to turn on the PFC Voltage booster which will boost the DC Voltage on the main filter cap form 165VDC to >360VDC.
                                  You should disconnect the load to the 24VDC output for now.
                                  • orgwood
                                    • Apr 2013
                                    • 39
                                    Thanks budm, I will give that a go tomorrow to see if the 24VDC comes alive with a standby signal. Would that main filter cap be C907 270uF 450V? I'll check it tomorrow. But is that ticking normal when the 12 & 24VDC are disconnected?
                                      "But is that ticking normal when the 12 & 24VDC are disconnected?" Ticking is not normal.
                                      So were you testing the power supply board with the main board connected to the power supply?
                                      If you do, then the STANDBY may be present, you should check the Voltage at the STANDBY pin to see if it goes from <1 V to > 2.5VDC when power switch is activated. If it does then check the Voltage on the main cap since the 24VDC needs that booted Voltage to function.
                                      If you disconnect the load on the 24V line and it stops clicking, then it can be that too much load is on the 24V due to problem in the inverter boards so the 24V goes into start up/shutdown cycle.
                                      • orgwood
                                        • Apr 2013
                                        • 39
                                        All I've got is the PS board here so no main board is connected....the set is at my son's about 20 minutes away. I don't even have the power switch here so I'm just going to provide the 3VDC through a resistor. I see it activates the base of an NPN with a 4.7K in series so I'll just take it to the 12VDC. Thanks again for the VERY fast replies...it's exactly what I needed to get me going forward with this.
                                        • orgwood
                                          • Apr 2013
                                          • 39
                                          Well, I've got bad news and some news not so great. The bad news is that my Oscope wasn't free floating so I blew out the AC line circuits trying to read the HOT side waveforms. I believe I can fix those bad traces though and I had a spare BD installed when it happened so I think I can put the original one back in. Before that happened, I was able to watch the 24VDC rail rise to around 10VDC when I biased the standby pin ON using a 4.7K resistor to the 12VDC rail. It seemed like it ticked a lot faster while this was happening. I will try to fix the traces tomorrow and have another go at it. Since these boards are scarce, I wondering about putting in a 12VDC PS constantly on and adding a 24VDC separate one and do a manual turn on. Once on, the remote should do everything but control power. Do you happen to know the specs on the amps for both rails? I've got some LCD switchers I think could work but they may not have enough output capability. If I can get the 12VDC rail working, I might just try to put in an extra 24VDC PS just to get this set running for my son. Any thoughts? Thanks, Dave
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • tester001
                                            PLP-60-48 Single Output LED Power Supply - "chirping" noise
                                            by tester001
                                            Dear Badcaps forum members,
                                            Hope that you are all well!
                                            I am a newbie on a mission to figure out the cause of the PSU making a "chirping" noise:
                                            Having searched for this symptom online I have found some indication that failed capacitors may be an issue. To help with the troubleshooting, I have tried to isolate the problem and disconnected the PSU from the rest of the device - the chirping remained.
                                            I have then found that the whole PSU (apart from a small add-on board) can be replaced, and there is even a datasheet for it: https://cdn.badc...
                                            12-06-2023, 06:39 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • Cornito
                                            Philips 50PUH6400 bad color and gosting / slow motion on one side
                                            by Cornito
                                            Hello Team,
                                            New issue on LCD panel where I need to find out the cause and the potential solution.
                                            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                            I've checked voltages, no issue found comparing right and left side of the panel driver.
                                            VHG VGL CKV... are the sames on...
                                            03-08-2024, 06:41 AM
