Philips 37PFL5322D/37 Chirping from psu
  • orgwood
    • Apr 2013
    • 39
    Re: Philips 37PFL5322D/37 Chirping from psu
    My son put it in his TV and everything is working fine including the remote so that means the 12VDC rail and the 24VDC rails are firing up in the right order...12VDC for standby and 24VDC for power on. Thanks so much for all your help and patience. Peace, Dave
    • orgwood
      • Apr 2013
      • 39
      https://www.badcaps.net/forum/showthread.php?t=34579
      Here's the link to the Magnavox SMPS thread since they're basically the same.
      • sherrygarris
        • May 2013
        • united states
        #63
        this is an awesome forum. i currently have 2 of these Phillips with chirping in my shop. Since the 2 zeners in question were in the snubber circuit i removed them from both sets and briefly turned them on (after I'd done basic checks of course) to confirm that these would fix. Both sets powered up fine. I'm ordering the p6ke120a times 4 and will have saved 2 sets from the landfill and made a bit of cash. Thanks to all who continue to contribute and to all who continue to work in the ever changing and sadly shrinking field of TV repair
        • orgwood
          • Apr 2013
          • 39
          I would like for you to help me understand the purpose of those zeners. You said they were in the snubber circuit so I would expect them to limit the voltage that appears across that primary. Is that right? If so, how does removing them and powering on the PS not cause the voltage to go too high. Thanks, Dave
          • itzklove
            • Apr 2016
            Good morning, I ma having a problem with my Philips Power Supply 715T2454-2 which is in a 42" Philips TV. First started out the 24VDC was missing but with the help of this forum trend I replace an IC TEA1507P the 24 VDC is now there, Now I am having another issue.
            Just powering up the Philips Power Supply 715T2454-2, using a Multi-meter I can read the 24VDC at connector J13, pin-1 and pin-2 but after awhile you can see the 24VDC dropping (counting down) 0V; this is with the Philips Power Supply still connect to the AC power source. Here is where it get a little con fusing for me. At first I thought the IC TEA1507P went bad again, so i decided to change it again the next day.
            The next day for some strange reason I decided to powered up the Philips Power Supply again before changing IC TEA1507P, and using the Multi-meter I could again read the 24VDC at connector J13, pin-1 and pin-2, and after awhile "again" the 24VDC begin to dropping and I watch it counting down from 24VDC to 0V. After seen this I let the power supply sit for 12 hours and once again I was able to read 24VDC then watch it count down again.
            Can someone here direct me to the source of the problem.
            • orgwood
              • Apr 2013
              • 39
              Are you powering up the SMPS with a load on the 24VDC? It may be going into overvoltage shutdown without a load. The 24VDC should not come active until you have the 12VDC running and then apply a turn on signal to activate the Stand By pin.
              • itzklove
                • Apr 2016
                Thanks for assisting, and I think you maybe right, because while powering up the power supply board there were no load connected. I had the power supply board out of the TV on a table with the AC plugged in while reading the voltages at connector CN902, pins 1 and 2 (which should 24VDC) and pins 3 and 4 (which should 24VDC).
                When i get home later I will put it back in the TV and complete all the connections and see what happen.
                Thank you
                Kevin
                • Ivan_Ryger
                  • Aug 2017
                  Dear all,
                  please does anyone have a spare transformer HJC-S6192 in a working condition?
                  I replaced shorted TVS diodes and a couple of secondary capacitors. The rest seems to be OK and my LCR meter shows most probably shorted winding.
                  Thank you.
                  Ivan
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    #69
                    I will check when I get home. I cant send you a PM because you are so new to the forum. Send me a PM with your email address and I will let you know.
                    • Ivan_Ryger
                      • Aug 2017
                      Dear all,
                      finally after a long struggling I made my PSU working. At the beginning I found popped three parallel filtering capacitors popped at the secondary side (C952,953,956). In addition to that at the primary side of the transformer, two TVS diodes (ZD902,904) were shorted. You can easily check them by multimeter in the forward direction. After replacing these components, the power supply was still chirping, though.
                      I measured all the passive and active components (resistors, capacitors and diodes) with emphasis on the snubber circuit (D925 checked for forward voltage drop and reverse breakdown voltage, as well, C944 for capacitance). Secondary diodes D922 and D926 were checked for forward voltage and reverse leakage, everything OK. The critical component could be also the source current sensing resistor R949, so i checked it for a resistance by passing 100mA through it and measuring the voltage drop across it. Again everything OK.
                      also tried to swap the active circuits (IC904, Q901) with others - no change.
                      So my suspicion fell on the transformer. You can easily check it with oscilloscope and square wave generator by measuring the Q-factor of the primary winding.
                      I found it somewhat low (somewhat below 10), implying some problems there.
                      The method is described here
                      http://www.giangrandi.ch/electronics...ingdownq.shtml
                      . Luckily, a member TvTimmy found one used transformer in his old stock.
                      The new one had a Q-factor of about 30.
                      So I tried to swap it. The chirping sound has changed but was still present.
                      By measuring the voltage at the pin 8 IC904 I found that this was regularly dropping under UVLO threshold level. Thus the IC was getting into undervoltage lockout state.
                      Next measurements revealed something interesting. When I grounded the base of Q913 through 5kOhm resistor, the power supply started running correctly even with a small 80 Ohm load connected to the output of the 24V line. In this case the main SMPS was powered from lower voltage (170V present on C907), since the PFC pre-reguator was turned off.
                      However, by shorting the optocoupler (IC909) at the phototransistor side the PSU was chirping again. In this test, the PFC pre-regulator was running at full voltage on C907 (about 370V, can be up to 400V). I realized that during this test the voltage was again dropping under UVLO threshold. So it implied an increased power consumption by two chips IC902 and 904. Since I could not find the reason of this problem, i fixed it in slightly different way. By increasing the base current of Q914 I decreased the voltage drop across the next switching transistors. I increased the current by adding a 5kOhm (value not critical) resistor in parallel to R915. In addition to that I had to increase the capacitance of capacitor C958? (47uF/25V original) by changing it with a new one 100uF/35V.
                      After all these steps the PSU finally started working correctly.
                      • G33RT
                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                        by G33RT
                        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                        It does power up when pressing the power button.
                        I already try the power button while plugin the plug with no result.
                        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                        Could this be an PSU or eMMC issue ?
                        Yesterday, 03:43 AM
                      • tester001
                        PLP-60-48 Single Output LED Power Supply - "chirping" noise
                        by tester001
                        Dear Badcaps forum members,
                        Hope that you are all well!
                        I am a newbie on a mission to figure out the cause of the PSU making a "chirping" noise:
                        Having searched for this symptom online I have found some indication that failed capacitors may be an issue. To help with the troubleshooting, I have tried to isolate the problem and disconnected the PSU from the rest of the device - the chirping remained.
                        I have then found that the whole PSU (apart from a small add-on board) can be replaced, and there is even a datasheet for it: https://cdn.badc...
                        12-06-2023, 06:39 AM
                      • aidanmo
                        Philips 43PUS7506/12 - Loud blown out sound
                        by aidanmo
                        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                        I thought maybe the speakers got damaged, so I replaced them - no dice.
                        • Using the internal speakers, it always happens.
                        • Using the headphone jack, it never happens.
                        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                        02-28-2025, 03:13 PM
                      • Cornito
                        Philips 50PUH6400 bad color and gosting / slow motion on one side
                        by Cornito
                        Hello Team,
                        New issue on LCD panel where I need to find out the cause and the potential solution.
                        This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                        I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                        When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                        I've checked voltages, no issue found comparing right and left side of the panel driver.
                        VHG VGL CKV... are the sames on...
                        03-08-2024, 06:41 AM
                      • spantor
                        Activate power board Philips 40PFH40009/88 tv
                        by spantor
                        Hello partners.
                        Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                        The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                        02-11-2024, 05:07 PM
