Philips 37" LCD 37pfl7662d/05
  • vinceroger69
    • Mar 2012
    • 6714
    #41
    Re: Philips 37" LCD 37pfl7662d/05
    Not conected to anything if you look at the picture theres no wires going to the pins hence Nc.
    • michael dranfield
      • Jan 2016
      • 232
      • England
      #42
      i
      Originally posted by tom66
      Okay, so I ordered the replacement transformer and removed the old one. Well it is very clearly failed; there is a black mark in one side of the secondary winding, which has also burned the PCB silkscreen. It's in the top right corner.
      What causes these transformers to fail? I thought transformers were generally quite reliable.
      I think you will find its the 90 degree bend round the sharp corner that causes the failure .
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        Originally posted by michael dranfield
        i
        As well as heat and age
        • michael dranfield
          • Jan 2016
          • 232
          • England
          #44
          The inverter transformers on darforn boards are particularly troublesome by far the most common problem is a change in resistance of one of the secondary windings causing an inverter out of balance circuit to trigger.the secondary windings consist of 3 or 4 strands of fine wire twisted together and due to thermal expansion on the 90 degree bends round the sharp corners exiting the transformer a single strand can snap hence the change in resistance of the secondary winding .the faulty transformer will usually go high in resistance by one third of the value of all the other transformers.
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            Today, 12:54 PM
          • aidanmo
            Philips 43PUS7506/12 - Loud blown out sound
            by aidanmo
            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
            I thought maybe the speakers got damaged, so I replaced them - no dice.
            • Using the internal speakers, it always happens.
            • Using the headphone jack, it never happens.
            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
            02-28-2025, 03:13 PM
          • Cornito
            Philips 50PUH6400 bad color and gosting / slow motion on one side
            by Cornito
            Hello Team,
            New issue on LCD panel where I need to find out the cause and the potential solution.
            This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
            I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
            When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
            I've checked voltages, no issue found comparing right and left side of the panel driver.
            VHG VGL CKV... are the sames on...
            03-08-2024, 06:41 AM
          • spantor
            Activate power board Philips 40PFH40009/88 tv
            by spantor
            Hello partners.
            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
            02-11-2024, 05:07 PM
