Dumb question from a noob
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    I have a 32" viewsonic (n3251w) i'm working on and the backlight will not work. The power board had insufficient output voltages on the HV side and i couldn't ever pick out the right component. I found a new board at a good price and now the voltages are correct but still no backlight. My question is does the mainboard send a signal to power the inverter or should it be ok if as long as the PS output is ok? I'm getting a little frustrated with it at this point. Inverter doesn't look burned but haven't tested anything except the fuse.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dumb question from a noob
    The inverter is USUALLY controlled from the main board.
    PlainBill
    • rmoody
      Learning Member
      • Jul 2011
      • 262
      Ok after stripping it down and looking at the inverter i put it all back together and found that the backlight actually comes on for maybe a second and shows the picture then black right back out. I'm guessing this is a problem with my main board.
      • rayrod81
        • Oct 2010
        • 205
        More likely an inverter problem.
        • Village Electronics
          OldPro
          • 118
          Bad lamp.
          • PlainBill
            • Feb 2009
            • 7034
            Sounds like two seconds to black. I learned the hard way to do a little testing before jumping to conclusions. A very simple test is to check the voltage on the inverter control pin. It is often labeled On/Off, or Inv_On. If it goes high (typically 3.3 volts) while the backlights are on, then goes low, the main board is shutting down the inverter. If it remains high while the backlights go off, it's an inverter or CCFL problem.
            Another even simpler test is to hook up a video game, DVD player, or even tune to an over the air channel. Select that input by pressing the appropriate button. (On some TVs pressing the Input button advances to the next input). If you can hear the audio while the backlights are off, it's an inverter or CCFL problem.
            PlainBill
            • rmoody
              Learning Member
              • Jul 2011
              • 262
              PlainBill
              Well I was fortunate enough to find a Main Board and an extra set of speakers on ebay for $24 shipped to my door. When it comes in I'll let you know the outcome. I would try the inverter but man that thing is buried deep in this tv. The power board and Main board have to come off followed by a large metal cover with about 40 screws just to get to it.
              • Sir farts alot
                • Jul 2011
                • 3
                Must be the inverter or the CCFL Problem. Some times a bad lamp could cause the inverter to shut down.
                • rmoody
                  Learning Member
                  • Jul 2011
                  • 262
                  IDK, but at this point I hope it's the main board.
                  • rmoody
                    Learning Member
                    • Jul 2011
                    • 262
                    FIXED, turned out it was the inverter. Got one at a decent price so i went ahead and replaced it. Now i have a good power board i gotta sell
                    • x_orange90_x
                      by x_orange90_x
                      01-29-2025, 09:24 PM
                    • Gentian
                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                      by Gentian
                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                      03-06-2023, 07:07 AM
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
                    • eccerr0r
                      A modified sine wave inverter + a grid tie inverter?
                      by eccerr0r
                      If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                      Next thing is trying to charge the batteries using solar power, but that's another issue ...
                      08-31-2023, 09:14 PM
                    • caseyjay_48
                      Sony KDL-46BX450 Inverter Troubleshoot Logic
                      by caseyjay_48
                      I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                      I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                      09-23-2022, 08:08 PM
