Dumb question from a noob
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    I have a 32" viewsonic (n3251w) i'm working on and the backlight will not work. The power board had insufficient output voltages on the HV side and i couldn't ever pick out the right component. I found a new board at a good price and now the voltages are correct but still no backlight. My question is does the mainboard send a signal to power the inverter or should it be ok if as long as the PS output is ok? I'm getting a little frustrated with it at this point. Inverter doesn't look burned but haven't tested anything except the fuse.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dumb question from a noob
    The inverter is USUALLY controlled from the main board.
    PlainBill
    • rmoody
      Learning Member
      • Jul 2011
      • 262
      Ok after stripping it down and looking at the inverter i put it all back together and found that the backlight actually comes on for maybe a second and shows the picture then black right back out. I'm guessing this is a problem with my main board.
      • rayrod81
        • Oct 2010
        • 205
        More likely an inverter problem.
        • Village Electronics
          OldPro
          • 118
          Bad lamp.
          • PlainBill
            • Feb 2009
            • 7034
            Sounds like two seconds to black. I learned the hard way to do a little testing before jumping to conclusions. A very simple test is to check the voltage on the inverter control pin. It is often labeled On/Off, or Inv_On. If it goes high (typically 3.3 volts) while the backlights are on, then goes low, the main board is shutting down the inverter. If it remains high while the backlights go off, it's an inverter or CCFL problem.
            Another even simpler test is to hook up a video game, DVD player, or even tune to an over the air channel. Select that input by pressing the appropriate button. (On some TVs pressing the Input button advances to the next input). If you can hear the audio while the backlights are off, it's an inverter or CCFL problem.
            PlainBill
            • rmoody
              Learning Member
              • Jul 2011
              • 262
              PlainBill
              Well I was fortunate enough to find a Main Board and an extra set of speakers on ebay for $24 shipped to my door. When it comes in I'll let you know the outcome. I would try the inverter but man that thing is buried deep in this tv. The power board and Main board have to come off followed by a large metal cover with about 40 screws just to get to it.
              • Sir farts alot
                • Jul 2011
                Must be the inverter or the CCFL Problem. Some times a bad lamp could cause the inverter to shut down.
                • rmoody
                  Learning Member
                  • Jul 2011
                  • 262
                  IDK, but at this point I hope it's the main board.
                  • rmoody
                    Learning Member
                    • Jul 2011
                    • 262
                    FIXED, turned out it was the inverter. Got one at a decent price so i went ahead and replaced it. Now i have a good power board i gotta sell
                    • eccerr0r
                      inverter H tree driver imbalance in an AC inverter
                      by eccerr0r
                      My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                      11-16-2025, 12:34 PM
                    • x_orange90_x
                      Vizio E55-E1 bad backlights or bad inverter?
                      by x_orange90_x
                      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                      I don't know how exactly to test the inverter itself. Is it...
                      01-29-2025, 09:24 PM
                    • Gentian
                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                      by Gentian
                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                      03-06-2023, 07:07 AM
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
                    • eccerr0r
                      A modified sine wave inverter + a grid tie inverter?
                      by eccerr0r
                      If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                      Next thing is trying to charge the batteries using solar power, but that's another issue ...
                      08-31-2023, 09:14 PM
