Vizio SV470XVT1A LCD No Picture/No Backlight
  • vossen
    • Feb 2013
    Re: Vizio SV470XVT1A LCD No Picture/No Backlight
    909 could you please PM me? The forum won't let me PM anyone until I put some posts in. I need the SV470XVT1A Vizio service manual so I can locate the LVSD cable. Thanks!
    • tentler
      • Sep 2013
      • us
      I have the same model. I have all voltages to the inverter boards and still no backlight. I replaced inverter boards and still no luck. Any help would be appreciated.
      • linkkuru
        • Jan 2014
        Originally posted by 909
        IF you need the service manual, for the Vizio sv470xvt1a, I have it.
        PM me with an email address and I'll send it to you.
        909
        I would also appreciate a copy of the Vizio sv470xvt1a manual. I have a TV that clicks one when turned on, Vizio label turns white, no back light. The manual on/off button only works part of the time. Thanks...Link
        • splitcrete
          • Dec 2012
          • 387
          • usa
          Check the 35-v 470 uf cap under the heat sink The one close to the edge of board.
          • splitcrete
            • Dec 2012
            • 387
            • usa
            Also check the caps on the inverter boards.
            • jeffbrown1475
              • Jul 2014
              • usa
              #26
              909
              I need the service manual for the Visio SV470XVT1A if you still have it. Thanks, Jeff "jeffbrown1475@att.net"
              • afchrisbrown11
                Did anyone ever figure out the faulty components/boards for this. I am having the same issue. Any help is appreciated, Thanks!
                • animefan1919
                  • May 2015
                  I took off most of the boards on my Vizio 470XVT1A, labeling them all and the back of the TV as I went. I thought I was being careful, but when I finally found the burned/overheated component on the final board and started putting boards back in I found a connector on a board that had no corresponding cable. That board is the green one in Tim387s illustration DSC01289.JPG with the large number of capacitors to the right of the metal shroud covered board that has all the in/out connectors on it. I can't make out if the connector on the left top of that board has a plug in it or is left unwired. Mine is empty and I could have sworn all five of them had plugs in them, but I can not find a plug that is orphaned anywhere on the TV. Would someone more knowledgeable tell me if I have goofed and left a cable lying around somewhere?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    its empty in the thread post 3 pic 5
                    https://www.badcaps.net/forum/showth...zio+SV470XVT1A
                    • animefan1919
                      • May 2015
                      Thanks vinceroger69. I looked at the picture and it shows the same socket empty. I was sweating bbs.
                      • peterzade
                        • Sep 2015
                        • usa
                        #31
                        I have the same problem. If i turn it off for a while, it will display a 3"wide horizontal picture and then go off
                        • gavric
                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                          by gavric
                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                          When i click video to start playing picture goes black(like when you change...
                          09-02-2021, 08:55 PM
                        • SS454
                          vizio e650i-a2 backlight flashes then turns off
                          by SS454
                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                          panel: au optronics T650HVN05.4
                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                          08-20-2020, 03:57 PM
                        • ggil44
                          Vizio M65-E0 No Picture, No Sound
                          by ggil44
                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                          09-03-2024, 08:30 PM
                        • maricm
                          Vizio m65-c1 picture flashing on and off on the screen
                          by maricm
                          HI all,
                          hope someone point to the possible issue before I start buying replacement parts.
                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                          Backlight stays on all the time,
                          Sound works fine.
                          screen keeps changing form black to full picture in about 1sec intervals.
                          Picture looks fine with no visible artifacts.
                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                          Disconnecting left and right ribbons on...
                          11-25-2023, 06:32 PM
                        • csmith
                          Vizio D50u-D1 Powers up no picture
                          by csmith
                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                          issue. Set will power up with remote but not power off....
                          07-11-2025, 11:52 AM
