Panasonic TX-76PW60A
  • cods69
    • Oct 2005
    • 92
    Not my personal experience! This is quoted from the latest Australian 'Silicon Chip' mag, from the 'Serviceman's Log' (which is always a great read BTW).
    I will summarize, due to this being a current story and copyrights.
    He received a near new Panny TX-76PW60A (EURO9S chassis) wide-screen for a warranty fix. Something wrong with the width/pincushion correction with some vertical lines which vanished after a few mins.
    .....long-winded comically unsuccessful fix-testing cut here......
    The serviceman eventually noticed C582 (470nF 400V) which he said looked like it had a 'small lump of varnish' on the side of this 'brown polyester' cap.
    He removed it and found it was actually a leak from a small crack in the side of the cap.
    Unfortunately, no mention of cap brands, nor what he used as a replacement.
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Panasonic TX-76PW60A
    Panasonic makes film caps, and they are coated with brown epoxy.
    PeteS in CA
    • Newbie2
      • Sep 2005
      • 885
      That 'small lump of varnish' on this 'brown polyester' cap could be the brown epoxy that PeteS in CA is talking about.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        why would they use film caps in a recent tv?
        • PeteS in CA
          • Aug 2005
          • 3579
          ??? Film caps are usually pretty good. Except for COG ceramic, the tempco and change with applied DC voltage for even X7R can exceed 50% (decrease in capacitance). Z5U and Y5V can exceed 75%.
          PeteS in CA
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            the lump may have been molten poly or mylar coming out of a crack in the epoxy dip.
            they often crack open and spill their molten guts when they fail.
            likely an s correction or yoke return cap.
            • Andre Gilbert
              by Andre Gilbert
              11-20-2024, 08:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
            • Mnawar27
              Panasonic CF-H2AU24EF3 bios locked
              by Mnawar27
              Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
              I need help to remove it,
              thankyou all.
              SN; 2FKCA26876...
              11-16-2024, 08:00 AM
