Samsung UN65KS8000 wont boot, restarts, display damage 💔 Worth a shot?
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Got another TV headed for the dumpster the other day.
    Nice TV although it has those silly One Connect input boxes.
    When TV is plugged into mains you see the backlights flash on amd off a few times then you get red error flashes at the status light. Backlights 'looks' uneven at startup but i have learned that looks are deceiving and they should be tested.
    When i took the back off i unplugged the mainboard and the LEDs came on and stayed on. I then tested each led with my backlight tester and their voltages and amperages all read the same. So this eliminated the backlight as a possible culprit.
    I then reconnected the mainboard and disconnected the 2 LVDS ribbon cables and plugged the TV back in. The reboot error returned. I then removed the harness to the WIFI card as well as the speaker leaving only the power/control button connected to the mainboard. Reboot error still remained.
    This looks like a mainboard issue. I spot tested the MB for shorts on caps but didnt see anything jump out at me.
    I dont know the history of this TV.
    What indi know us that it has a small defect in the corner and im not sure if it would prevent the TV from showing a good picture (or any picture at all) if i am able to solve the issue with the mainboard.
    At least if i get a picture i will be able to better guage the progress of my repair.
    Please let me know what you guys think.
    Pictures provided.
    Thanks in advance!
  • nomoresonys
    • 12335
    • U.S.
    Re: Samsung UN65KS8000 wont boot, restarts, display damage 💔 Worth a shot?
    Not positive but that looks like screen damage.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      Yes i dont recall seeing something like this before. Looks more like desalination than a crack. The real question is will it prevent a picture from displaying?
      • EazyBone
        • Jun 2023
        • 1364
        • United states
        Looks like screen damage and I would guess yes. Did you disconnect one ribbon at a time at the panel boards and not from main board? Part it out and sell the box/cable lol. They go for like 100-200 on ebay
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          I disconnected it at the mainboard... not the panel board. Why do you ask? Is there a difference?
          Good idea regarding selling off the parts. The TV actually doesn't need the box to function like many other One Connect equipped models. It's there solely to accept HDMI and USB inputs.
          • nubinator
            • Jan 2012
            • 37
            I have same model and it also has weird panel damage without cracks. Mine are like black ink blotches around the screen. Even with screen off you can see the areas like its delaminated or something. and yes I sold off the one conect for a nice sum on ebay. Just turn off OCM Support in service menu before you do so you can still use the TV for apps otherwise youre stuck at one connect screen and have to reset eeprom
            • Storyteller12
              • Jun 2020
              • 625
              There are lcd panels and the liquid crystal has gone bad or leaked
              • KYBOSH
                • Oct 2011
                • 581
                • Unknown
                Thank you for this tip! I had not idea that was possible. Where can I find the procedure to do this?
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  Thanks for the insight. This is caused by trauma at that spot correct? Too much pressure/weight at the corner like some when moving the TV and leaning the it on that corner? Or maybe from inserting a tool (thin screwdriver) to remove the back cover?
                  Trying to understand what 'may' have happened so I dont make a mistake like that. When I first turned on the TV to inspect it I dont recall seeing that spot but the backlight never stayed on for more than a second and it was on the floor so its possible i never noticed it.
                  Edit to add:
                  I recorded the TV's behavior as soon as I came across it and it already had the defect. So it wasnt my fault. Still like to know what might have caused this...
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Honestly I’m not sure what causes it. Could be any of the things you mentioned. I know this particular model has issues sometimes with diode packs going bad on the buffer board of the panel. It might be getting hot or shorting out the panel as well causing this. But that’s just a guess
                    • nomoresonys
                      • 12335
                      • U.S.
                      That's probably worth a shot, maybe test those diode packs or take off one test tv, no joy take off the other.
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        Can anyone post a picture of what a diode pack looks like on one of these TVs?
                        Thanks!
                        • csmith
                          • Aug 2014
                          • 46
                          Need expert help on this one, Power light cycles on and off at 6 second intervals, when trying to power up backlights flicker dimly.
                          Unplug mainboard from power supply and backlights work. Ribbon connectors to panel removed same result. Changed mainboard,
                          no difference. Is Panel the issue and if so how to troubleshoot. Thanks in advance
                          • lotas
                            • Jan 2016
                            • 4969
                            • Russia
                            This will not work, you need to first place a jumper on the motherboard between the FB_TRDY_1 and FB_TRDY_3 control points, then you can disconnect one LVDS cable at a time and determine which side you have the problem on.
                            • csmith
                              • Aug 2014
                              • 46
                              Markings on board hard for me read , but I'll find them. Thank You lotas.
                              • lotas
                                • Jan 2016
                                • 4969
                                • Russia
                                Remove the black radiator and take a high-quality photo of this area.
                                • csmith
                                  • Aug 2014
                                  • 46
                                  Here you are, thank you.
                                  • Diah
                                    • Feb 2013
                                    • 6647
                                    you have broken socket the second one from top
                                    • csmith
                                      • Aug 2014
                                      • 46
                                      Not a problem for I have a replacement mainboard, i just used this board for photo lotas asked for.
                                      • lotas
                                        • Jan 2016
                                        • 4969
                                        • Russia
                                        These dots need to be connected...
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Mrsina77
                                          MBA 820-01521-A dropping PP5V_G3S (macbook restarts during boot)
                                          by Mrsina77
                                          I have liquid damaged macbook air 2018. Macbooks restarts after 10s when its trying to boot.
                                          Q7660 was water damaged and I have cleaned everything. It is connected to the U7650 that makes the PP5V_G3S. When its trying to turn on than everything voltage seems fine and than it drops and after 10s its trying to boot again and again.
                                          Anyone to help me to solve it?
                                          Thanks for reply.
                                          07-23-2022, 09:32 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
