HISENSE H55B7500UK has backlight no picture
  • snowangel27
    • Aug 2023
    • 45
    • United Kingdom
    My tv still has backlight when turn on, 12v on tcon board but no picture and 6 flashing red light at power button. I already disconnected each ribbon cable in turn but the screen only had backlight and nothing changed.
  • snowangel27
    • Aug 2023
    • 45
    • United Kingdom
    Re: HISENSE H55B7500UK has backlight no picture
    Update photos and clip(gg drive)
    https://drive.google.com/file/d/1SeU...w?usp=drivesdk
      • 12081
      • U.S.
      Turn it on, look closely at it with a flashlight, hit menu button, see if you see any text on screen.
      • Diah
        • Feb 2013
        • 6343
        LOL.... why flashlight and he have BL working fine ...!!
        you need to test T-CON and Panel as stand alone first..
        disconnect the LVDS from T-CON side.... if the BL come on... then make Jumper from PSU 12 V to T-CON fuse direct... see if the screen lighting up...with full color
          • 12081
          • U.S.
          LOL, my bad Diah, I think I got it confused with this pos sanyo one board I'm fooling with.
          • snowangel27
            • Aug 2023
            • 45
            • United Kingdom
            I already disconnected the LVDS from T-CON side, BL came on and the screen had nothing when i connected 12v to t con fuse
            • Diah
              • Feb 2013
              • 6343
              when every things as original connected... did you have sound ??
              • snowangel27
                • Aug 2023
                • 45
                • United Kingdom
                No, I didn't hear anything
                • Diah
                  • Feb 2013
                  • 6343
                  take out the speaker... and reach the panel edge buffer boards see if the left and right had at the middle U ribbon cable... if yes disconnect it from one half and turn each time
                  • snowangel27
                    • Aug 2023
                    • 45
                    • United Kingdom
                    Which one?
                    • Diah
                      • Feb 2013
                      • 6343
                      you don't have any u ribbon cable... did the tv after blinken stay at blue led on ???? if yes try feed it with HDMI signal from HDMI port with remark of CEC to check if there any sound
                      • snowangel27
                        • Aug 2023
                        • 45
                        • United Kingdom
                        No led on after 6 times flashing@@
                        I already tried all 3 hdmi port and still didn't hear anything
                        • Diah
                          • Feb 2013
                          • 6343
                          i saw your movie.... try to disconnect the WIFI BT module and turn on.. if the same issue you have issue at MB.. emmc dead or Firmware ... try to write firmware again via USB... am sure 5V at USB you have because T-CON 12 V you have measured before... if this didn't help then replace MB or packing it LOL if u have BGA station then refleo main CPU
                          • snowangel27
                            • Aug 2023
                            • 45
                            • United Kingdom
                            Yes, i m having 5v on usb port.
                            I tried to disconnect the WIFI BT module at the first but it didn t help
                            • Diah
                              • Feb 2013
                              • 6343
                              go hard play on MB.. check any low volts you have for emmc or DDR or cpu.... if all fine...take out the heat sink.... and do what you can to heating the cpu to touch again in it place if you did trying flashing the firmware.... good luck
                              • snowangel27
                                • Aug 2023
                                • 45
                                • United Kingdom
                                I used heatgun to heat cpu in 2 mins and nothing happen.
                                Can u give me the firmware to try flashing
                                • Diah
                                  • Feb 2013
                                  • 6343
                                  call hisense and asking for it... they will give you link
                                  • snowangel27
                                    • Aug 2023
                                    • 45
                                    • United Kingdom
                                    To all owner of Hisense here are the customer service Firmware archive
                                    Password : Hisense1234
                                    enjoy
                                    I found this in other topic, can i use it
                                    • Diah
                                      • Feb 2013
                                      • 6343
                                      of course.. its still working link.... go to 55 and then B7500 download all version.. to have them as archive for you
                                      • snowangel27
                                        • Aug 2023
                                        • 45
                                        • United Kingdom
                                        Do i need to check voltage on panel edge buffer boards?
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • petersor
                                          Hisense 58R6E3 Backlight/No Picture Repaired
                                          by petersor
                                          Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
                                          06-07-2024, 04:16 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
