Hisense 58R6E3 Backlight/No Picture Repaired
  • petersor
    • Feb 2020
    • 43
    Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected) then used a thermal camera to find the shorted capacitor. Removed it and didn't bother replacing it since there are many caps in parallel on that rail . . . ."no capacitor, no shorted capacitor" as Sorin likes to say. Back to working.
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Awesome data, thanks for posting. I will continue to post findings like this also to help the futures.
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • curt2199
      Hisense 58R6E3 (Backlights, sounds, no picture)
      by curt2199
      I'm working on a Hisense 58” R6E3 $398 Walmart special Roku TV. I picked it up free as the previous owner just said the picture went black so I assumed I'd be doing LED strip repairs. As it turns out the backlight is working fine, the TV responds to remote signals as I can here the typical Roku menu sound effects. My first thought after some typical voltage checks was a bad t-con board so I ordered an eBay damaged set pull for $5. Swapped it out and no change.
      Before I order a replacement main board, I wanted to see if anyone else had seen similar issues with this set? I pulled...
      08-17-2021, 08:55 AM
    • adamp91gvm
      hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
      by adamp91gvm
      as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
      09-10-2025, 12:13 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • TVGuy419
      Hisense 75R6E3 No Picture
      by TVGuy419
      I replaced the backlights on this Hisense TV and the LEDs were showing on certain images. Drove me nuts, so pulled it apart, got new LEDs and put it back together. Now I don't have a picture. TV came apart very easily both times and I was very carful with the panel. I've replaced all the boards for good measure and still have the same issue. Unhooking either side of TCON board still gives me a blank screen with backlights and sound. Is it really possible the panel is junk just from taking it off with suction cups and gently placing it back in place?
      11-09-2023, 06:38 AM
