My tv still has backlight when turn on, 12v on tcon board but no picture and 6 flashing red light at power button. I already disconnected each ribbon cable in turn but the screen only had backlight and nothing changed.
HISENSE H55B7500UK has backlight no picture
Tags: None
Re: HISENSE H55B7500UK has backlight no picture
Update photos and clip(gg drive)
https://drive.google.com/file/d/1SeU...w?usp=drivesdk -
Turn it on, look closely at it with a flashlight, hit menu button, see if you see any text on screen.Comment
LOL.... why flashlight and he have BL working fine ...!!
disconnect the LVDS from T-CON side.... if the BL come on... then make Jumper from PSU 12 V to T-CON fuse direct... see if the screen lighting up...with full colorComment
LOL, my bad Diah, I think I got it confused with this pos sanyo one board I'm fooling with.Comment
you need to test T-CON and Panel as stand alone first..
I already tried all 3 hdmi port and still didn't hear anythingComment
i saw your movie.... try to disconnect the WIFI BT module and turn on.. if the same issue you have issue at MB.. emmc dead or Firmware ... try to write firmware again via USB... am sure 5V at USB you have because T-CON 12 V you have measured before... if this didn't help then replace MB or packing it LOL if u have BGA station then refleo main CPUComment
I tried to disconnect the WIFI BT module at the first but it didn t helpComment
go hard play on MB.. check any low volts you have for emmc or DDR or cpu.... if all fine...take out the heat sink.... and do what you can to heating the cpu to touch again in it place if you did trying flashing the firmware.... good luckComment
I used heatgun to heat cpu in 2 mins and nothing happen.
Can u give me the firmware to try flashingComment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by petersorQuick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...3 Photos
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... - Loading...
