EU55JS9000T black screen and sound good
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    #81
    Re: EU55JS9000T black screen and sound good
    I have few time now to read back all, but since inductors shows no apparent power supply problems, and the hawk p that is the main processor i think, and it is heating a bit, then probably there is cpu soldering problem, i think it is not sending image to the tcon, the tcon that controls backlight on the basis of the image content, sends an almost black signal level to it (see back the 0,04v on p dim)..
    • totof
      • Feb 2017
      • 186
      • france
      #82
      Yes, I also thought about that, a bit like a certain laptop motherboard. This could be any component on the chain (Hawk-P, Hawk-US or Hawk-N)
      The only thing that could make me think that it is something else is that the backlighting is cut off immediately after connecting the cable while the Hawk components have just been powered and are not yet initialized and operational.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        #83
        i cannot know the complex architecture of such a tv set due to the lack of manuals, but i guess the boot sequence and screen driving sequence is different if you connect the OCB at hot or at cold, i think on the back of tv there is a second main board with something like a subtitute cpu with few tasks..
        • lotas
          • Jan 2016
          • 4900
          • Russia
          #84
          Samsung has implemented this way, even on regular TVs, when the motherboard is disconnected, the backlight will be on constantly and when a faulty motherboard is connected, the backlight will go out, and here, like you, there may be a problem with the eMMC (the firmware cannot load).
          • Diah
            • Feb 2013
            • 6614
            5 pages right now... and the answer was at POST #4 & #8
              • 12332
              • U.S.
              #86
              So what's up, is it solved or what?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4543
                • Italy - Milan
                #87
                Lotas, first post states sound is good, freetnt tv is audible, so no software problem for me...
                as per diagram in post 82 Hawk N is responsible of driving TCON and therefore backlight levels, but there is also an SPI flash memory connected to it that can be polluted..
                • totof
                  • Feb 2017
                  • 186
                  • france
                  #88
                  No it's not solved (unfortunately)
                  The TV works well, I can hear the sound from the TV (TNT tuner source). The sound comes about 10 seconds after plugging in the OCB cable.
                  So I don't think it's a firmware issue.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4543
                    • Italy - Milan
                    #89
                    not the main firmware but the spi one yes maybe
                    • totof
                      • Feb 2017
                      • 186
                      • france
                      #90
                      I can extract the contents of the spi but personally I won't know how to do anything with it
                      • Diah
                        • Feb 2013
                        • 6614
                        ONE BOX CONNECT... are the heart of Video and Audio wave Signal... Main boards CPU just process it to feed Panel... if Video wave Zero value... screen remain black for ever. even with out Connect box. end.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4543
                          • Italy - Milan
                          #92
                          must to find a source of the content and rewrite it, not extract anything
                          • totof
                            • Feb 2017
                            • 186
                            • france
                            #93
                            Here is the dump of the SPI flash of the OCB card.
                            Maybe one day it will be useful to someone on this forum.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4543
                              • Italy - Milan
                              #94
                              your document speaks about 2 spi roms, to be aware of which one to process..
                              • totof
                                • Feb 2017
                                • 186
                                • france
                                #95
                                Yes there is also a EEPROM on the OCB board and a SPI on the TV mainboard.
                                Here are the dumps of these CI.
                                A lot of 00 on the mainboard TV SPI.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4543
                                  • Italy - Milan
                                  #96
                                  i watched better your block diagram, i see now the separation Ocb/back board, things short, i suspect bad ocb to tv connector solderings.. reflow them all with little new tin.. both ocb & tv sides
                                  • totof
                                    • Feb 2017
                                    • 186
                                    • france
                                    #97
                                    I have already checked the continuity of all the signals with a multimeter with the cable plugged in.
                                    No problems detected
                                    • lotas
                                      • Jan 2016
                                      • 4900
                                      • Russia
                                      #98
                                      Here I found dump OC eprom and spi from "48". Try it, maybe you'll get lucky.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4543
                                        • Italy - Milan
                                        #99
                                        the best thing you can do is to connect a pc to the debug port and see the log, other than this you can try to access service menu through debug port and do a service reset..
                                        • totof
                                          • Feb 2017
                                          • 186
                                          • france
                                          #100
                                          Thank you lotas, I will try tomorrow
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • totof
                                            LG 43UF640V backlight good but black screen and no sound
                                            by totof
                                            Good morning.
                                            I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                            I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                            In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                            HVDD : 7,28...
                                            04-13-2024, 11:37 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
