EU55JS9000T black screen and sound good
    • 12206
    • U.S.
    #61
    Re: EU55JS9000T black screen and sound good
    Another thing that's easy to try if those things your looking at check out ok, is take connector CN301 and CN801 off and try it, will be no wifi or sound of course. just wondering if that bit of less power required would make a difference, then would maybe have a better idea of where to look.
      • 12206
      • U.S.
      #62
      It's too bad that you don't have another tv to try that ocb on.
        • 12206
        • U.S.
        #63
        https://www.ebay.co.uk/p/12061435673
        • totof
          • Feb 2017
          • 157
          • france
          #64
          Sometimes it can be the components in a circuit that can make things seem shorted, like if there's a resistor in circuit across it, it may read short and be ok, that's why you get the best results off the board.
          I agree with you.
          This short circuit capacitor is suspicious but I don't know where the origin is. There are definitely voltages on all the inductors, however I don't know if they are all correct.
          To check if there is an image I planned to disconnect the PWM signals from the TCON board to inject a voltage of 1V directly onto the backlight control board. What do you think about this test and should a DC voltage be injected?
            • 12206
            • U.S.
            #65
            Did you get a reading on that cap in ohm mode? test as in post #57.
              • 12206
              • U.S.
              #66
              Originally posted by totof
              I agree with you.
              I'm not sure how that works.
                • 12206
                • U.S.
                #67
                I do see a backlight operation test in your training pdf from the first post.
                  • 12206
                  • U.S.
                  #68
                  Testing Backlights
                  1. Remove CN803 (Main to SMPS) and CN9003
                  (Main to Micro Dimming Board) to activate Back Lights.
                  Both connectors must be removed to light backlights.
                  2. Check each of the 16 circled components above in each
                  L and R quadrants for approx. 95VDC by connecting the p
                  lus lead of the multi meter to either side as shown on left (
                  BB9101) and negative meter lead to chassis ground.
                  3. If any read high (approx 160VDC) a string of LED
                  Backlights are open (defective panel). If a voltage is low,
                  remove the LED panel connector & test again. If it stays
                  low replace defective SMPS.
                    • 12206
                    • U.S.
                    #69
                    Above is from your training pdf, there's pictures there too.
                    • totof
                      • Feb 2017
                      • 157
                      • france
                      #70
                      OL in ohm mode on multimeter. No short cut.
                      Yes the backlighting works but it turns off immediately (<0.2 sec) as soon as the OCB cable is plugged in.
                      The P_DIM1..16 signals from TCON board falls to 0,36V, BL_ON is still good (4,7V)
                      The Tcon test works well (see post #22) but only when ocb is not connected
                      Testing Backlights
                      OK, I will try this test
                      • totof
                        • Feb 2017
                        • 157
                        • france
                        #71
                        My backlighting control board is not exactly the same as that in the document on post #1, the connectors are the same but the components are different.
                        At the terminals of the 16 diodes I measure 59V on one side and 20V on the other with the reference on the chassis.
                          • 12206
                          • U.S.
                          #72
                          https://www.youtube.com/watch?v=ymvyxlWdEck
                          https://www.youtube.com/watch?v=1QigP2qkv0M
                            • 12206
                            • U.S.
                            #73
                            Why would a capacitor read OL?
                            If the capacitance value is within the measurement range, the multimeter will display the capacitor's value. It will display OL if a) the capacitance value is higher than the measurement range or b) the capacitor is faulty.
                              • 12206
                              • U.S.
                              #74
                              So if you are getting a reading, NOT OL on all your other capacitors, then that one is bad.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4363
                                • Italy - Milan
                                #75
                                It's total waste of time and riskful to test backlight, since in Screen test everything works then your defect is 100% in the couple OCB+main board (let's call it so...)
                                  • 12206
                                  • U.S.
                                  #76
                                  Well if you already did a backlight test that passed, don't try anything experimental, like you described.
                                  • totof
                                    • Feb 2017
                                    • 157
                                    • france
                                    #77
                                    I read OL for capacitor in ohm mode, in capacitance mode I read 1 microfarad.
                                    Yes I agree with you.
                                      • 12206
                                      • U.S.
                                      #78
                                      Now read, check the other similar capacitors in the area, leave them in circuit, DO they also show OL??
                                      • totof
                                        • Feb 2017
                                        • 157
                                        • france
                                        #79
                                        Last week-end I have checked all capacitors on the data lanes of the ocb cable and all are good (100 nF). I have checked this capacitors on main board side and on ocd side.
                                        Attached photo of the OCB board to the connector to the motherboard
                                          • 12206
                                          • U.S.
                                          #80
                                          I don't like to but I give up, we seem to have a communication error.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • totof
                                            LG 43UF640V backlight good but black screen and no sound
                                            by totof
                                            Good morning.
                                            I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                            I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                            In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                            HVDD : 7,28...
                                            04-13-2024, 11:37 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • VcemPzd
                                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                            by VcemPzd
                                            Hello everyone !
                                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                            04-28-2025, 10:14 AM
