Hannspree T280H not turning on
  • cschappa
    Craig
    • Sep 2023
    • 8
    1st Post here guys. I have a T280H that the cat knocked over. Everything else was fine before the fall, but now there is no display. There is a yellow LED that pulsates dim to bright.
    I have taken out the power supply, R0800-0805-060.
    I tried to test the pin outs 12v, see pic, which reads 0.00
    I do have 5v.
    Also, I noticed, the 2 metal heat sinks, checking the voltage between the 2 of them reads ~60v, but I am not sure if that is normal.
    I have looked at another post, similar PS, but a little different.
    Thanks in advance for any recommended suggestions.
    Craig
    • 12086
    • U.S.
    Re: Hannspree T280H not turning on
    Maybe the screen is broken, were any cables loose, look the screen over carefully with a flashlight.
    • cschappa
      Craig
      • Sep 2023
      • 8
      I just checked the screen with a flashlight, it all looks the same, no cracks or bubbles. The cables all look to be intact.
        • 12086
        • U.S.
        Is the input set correctly, might have bumped it.
          • 12086
          • U.S.
          Are you testing it with everything plugged in or is that cable unhooked?
          • cschappa
            Craig
            • Sep 2023
            • 8
            Testing with PS disconnected from everything, except main power.
            • cschappa
              Craig
              • Sep 2023
              • 8
              When TV is powered on, the yellow light would turn blue.
                • 12086
                • U.S.
                Test it with everything hooked up as normal, see what you have on those same voltages you checked.
                  • 12086
                  • U.S.
                  Can try a simple reset, unplug tv for a few minutes then press and hold power button on tv for 30 seconds, then plug it in and try it.
                    • 12086
                    • U.S.
                    Go ahead and heat up those capacitors on your powerboard for a couple minutes with a hairdryer, then try it.
                      • 12086
                      • U.S.
                      If nothing broke and all connections are good, kinda thinking maybe a marginal capacitor gave up.
                        • 12086
                        • U.S.
                        Suppose it could have loosened a solder joint so check the joints on powerboard.
                        • cschappa
                          Craig
                          • Sep 2023
                          • 8
                          So, everything is reconnected, I tried to heat the board with hair dryer, and measured leads with meter.
                          12v = 0
                          5v = 0
                          5vsb = 5.2
                          The large brown cap, 450v 120uF reads 169v and does not change when power button is pressed.
                          • lotas
                            • Jan 2016
                            • 4474
                            • Russia
                            Most likely, your power supply is only in standby mode; in order for it to go into working mode, it needs to give a command - this must be done by the motherboard (3-5V) to turn on the β€œremote” pin.
                              • 12086
                              • U.S.
                              Ok, so try powerboard as stand alone, prolly easiest way is unhook cable from powerboard to mainboard on mainboard side, leave it off for test, trace wires back and jumper #1 remote pin and #7 5vSB pin, so you are jumping thru the UNPLUGGED connector. Then plug power cord in and see if you have those missing voltages and see if the backlights come on.
                              • lotas
                                • Jan 2016
                                • 4474
                                • Russia
                                Just connect through a 1 kOhm resistor.
                                  • 12086
                                  • U.S.
                                  Resistor is good practice, a safety precaution, not needed if there is no mistake in making connections.
                                  • lotas
                                    • Jan 2016
                                    • 4474
                                    • Russia
                                    It is always needed in such cases, firstly, it is not known what voltage is needed on the β€œremote” 3v or 5v, and secondly, it (the resistor) limits the voltage supply current.
                                      • 12086
                                      • U.S.
                                      Actually it's not worth debating, so go for the resistor, some have had unreliable results because of using the wrong size resistor, using the right size is fine.
                                      • cschappa
                                        Craig
                                        • Sep 2023
                                        • 8
                                        I was able to jumper #1 & #7, I couldn't find a 1kohm resistor.
                                        No backlight, also no 12v or 5v.
                                        • Sparklingx
                                          HP 450 g1 keeps turning on even tho shutdown/sleep
                                          by Sparklingx
                                          HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                          09-23-2024, 12:34 AM
                                        • khelane
                                          Satellite PRO A50-A Not turning on after turning off Windows
                                          by khelane
                                          Hello
                                          A device with specifications
                                          Toshiba Satellite PRO A50-A is here to replace the hard drive.
                                          The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                                          The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                                          04-20-2023, 06:28 AM
                                        • Rabit
                                          VX3276-2K-mhd-2 Random Turning off
                                          by Rabit
                                          Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                                          When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                                          This can be signs of bad capacitors causing overheating PSU ?
                                          06-17-2024, 09:30 AM
                                        • shakib200
                                          Dell latitude E7240 not turning on if adapter plugged in
                                          by shakib200
                                          Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
                                          03-31-2024, 12:55 PM
                                        • questore
                                          HP OMEN-X 17T-AP000 not turning on
                                          by questore
                                          Hello Everyone
                                          I have the laptop mentioned in the title that is turning on then turning off after a few seconds. (fan spinning)
                                          Board number is:
                                          DA0G3CMBCH0 Rev H
                                          I have not found any boardview or schematic.
                                          I have found that GPU line is 0.0 Ohm shorted, but the VRM mosfets are not shorted.
                                          YES indeed the short is 0.0 Ohm in resistance mode.
                                          I have lifted all the four GPU coils and found that the GPU line is 0.0 Ohm shorted.
                                          After this I have injected 0.9V and the board drawes 0.56A
                                          The problem is That no matter how much time I inject...
                                          09-18-2023, 02:00 PM
