Please, help: HP Elitebook 1030 G2 keeps crashing and turning on automatically
  • Zilicon
    • Nov 2020
    • 165
    • Nigeria
    i've been working on the above PC for some time now, but the fault remains unsolved.
    Behavior:
    less than 2 weeks after the battery and keyboard of the pc were changed, the pc started crashing and restarting on its own. it keeps doing that at approximately an hour intervals, at times, it becomes shorter than that.
    When it crashed, there was no BSOD of any kind; the power button did not misbehave; the pc did not overheat either.
    what I have done:
    cleaned the ME of the BIOS firmware, changed the thermal paste, removed all peripheral devices- (keyboard, trackpad, Wi-Fi card, fingerprint. power button), used the pc on battery alone, used it on charger alone.
    the problem persisted.
    suddenly, the pc started working fine, it worked for 2 weeks, the problem started again
    I went to the event center to check the crash report, the report indicated that there was no power button misbehavior, there was no overheating, neither was there a bug.
    But in the kernel power part, it reported event ID: 41, the level is critical.
    it stated this in the overview: "The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly."
    Please, what can i do, i'm lost.
    I discovered that if the pc was left for days without turning it on, when turned on, it will work fine for a long hours, eventually it will start its problem at some point.
    below is the copied report
    - System
    - Provider
    [ Name] Microsoft-Windows-Kernel-Power
    [ Guid] {331c3b3a-2005-44c2-ac5e-77220c37d6b4}
    EventID 41
    Version 9
    Level 1
    Task 63
    Opcode 0
    Keywords 0x8000400000000002
    - TimeCreated
    [ SystemTime] 2025-10-29T04:46:59.3888332Z
    EventRecordID 41120
    Correlation
    - Execution
    [ ProcessID] 4
    [ ThreadID] 8
    Channel System
    Computer DESKTOP-H6RDQ9Q
    - Security
    [ UserID] S-1-5-18
    - EventData
    BugcheckCode 0
    BugcheckParameter1 0x0
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress 0
    PowerButtonTimestamp 0
    BootAppStatus 0
    Checkpoint 0
    ConnectedStandbyInProgress false
    SystemSleepTransitionsToOn 0
    CsEntryScenarioInstanceId 0
    BugcheckInfoFromEFI false
    CheckpointStatus 0
    CsEntryScenarioInstanceIdV2 0
    LongPowerButtonPressDetected false
    LidReliability false
    InputSuppressionState 0
    PowerButtonSuppressionState 0
    LidState 1
  • reformatt
    • Feb 2020
    • 1691
    Was this a keyboard only, or palmrest that you replaced? If it was palmrest, I would compare the the old and new together, especially if you sourced it off Aliexpress. I had an Asus a while back that was brought to me randomly shutting off after a palmrest replacement. Turns out this was not quite the correct one (there were two different versions for the same model) and there was a conductive foam pad for grounding that was shorting onto the PCB. So I'd be looking for places where the board is shorting out.
    • Zilicon
      • Nov 2020
      • 165
      • Nigeria
      thank you for your response.
      I was not the one who replaced the parts. the parts that got replaced were just the keyboard and the battery. the problem persisted even with the battery and keyboard disconnected.
      • reformatt
        • Feb 2020
        • 1691
        You misunderstand. You'll need to take out the motherboard and inspect for any areas where the board may be shorting out to the chassis. I'm not saying the keyboard or battery are faulty.
        • Zilicon
          • Nov 2020
          • 165
          • Nigeria
          oh!
          thank you. yes i have done that. there was no grounding of any part of the PCB
          • Boardview and Schematic Bot
            MSI Modern 14 A10RAS-1030 Notebook 14 Specification for Upgrade or Repair
            This specification for the MSI Modern 14 A10RAS-1030 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 A10RAS-1030 boardview and 14 A10RAS-1030 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:00 PM
            NVIDIA GeForce GT 1030 Schematic & Board View
            The GeForce GT 1030 was an entry-level graphics card by NVIDIA, launched on May 17th, 2017. Built on the 14 nm process, and based on the GP108 graphics processor, in its GP108-300-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GT 1030. The GP108 graphics processor is a relatively small chip with a die area of only 74 mm² and 1,800 million transistors. It features 384 shading units, 24 texture mapping units, and 16 ROPs. NVIDIA has paired 2,048 MB GDDR5 memory with the GeForce GT 1030,...
            10-01-2024, 02:42 PM
            HP EliteBook x360 1030 G7 Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the HP EliteBook x360 1030 G7 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G7 boardview and 1030 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
            09-06-2024, 08:40 PM
            HP EliteBook x360 1030 G7 + 2UK37AA + H3T50AA Ultraportable Specification for Upgrade or Repair
            This specification for the HP EliteBook x360 1030 G7 + 2UK37AA + H3T50AA Ultraportable can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G7 + 2UK37AA + H3T50AA boardview and 1030 G7 + 2UK37AA + H3T50AA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-06-2024, 08:10 PM
            HP EliteBook x360 1030 G4 + LaserJet Pro M15w Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the HP EliteBook x360 1030 G4 + LaserJet Pro M15w Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + LaserJet Pro M15w boardview and 1030 G4 + LaserJet Pro M15w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
