Hannspree T280H not turning on
  • cschappa
    Craig
    • Sep 2023
    • 8
    1st Post here guys. I have a T280H that the cat knocked over. Everything else was fine before the fall, but now there is no display. There is a yellow LED that pulsates dim to bright.
    I have taken out the power supply, R0800-0805-060.
    I tried to test the pin outs 12v, see pic, which reads 0.00
    I do have 5v.
    Also, I noticed, the 2 metal heat sinks, checking the voltage between the 2 of them reads ~60v, but I am not sure if that is normal.
    I have looked at another post, similar PS, but a little different.
    Thanks in advance for any recommended suggestions.
    Craig
    • 12206
    • U.S.
    Re: Hannspree T280H not turning on
    Maybe the screen is broken, were any cables loose, look the screen over carefully with a flashlight.
    • cschappa
      Craig
      • Sep 2023
      • 8
      I just checked the screen with a flashlight, it all looks the same, no cracks or bubbles. The cables all look to be intact.
        • 12206
        • U.S.
        Is the input set correctly, might have bumped it.
          • 12206
          • U.S.
          Are you testing it with everything plugged in or is that cable unhooked?
          • cschappa
            Craig
            • Sep 2023
            • 8
            Testing with PS disconnected from everything, except main power.
            • cschappa
              Craig
              • Sep 2023
              • 8
              When TV is powered on, the yellow light would turn blue.
                • 12206
                • U.S.
                Test it with everything hooked up as normal, see what you have on those same voltages you checked.
                  • 12206
                  • U.S.
                  Can try a simple reset, unplug tv for a few minutes then press and hold power button on tv for 30 seconds, then plug it in and try it.
                    • 12206
                    • U.S.
                    Go ahead and heat up those capacitors on your powerboard for a couple minutes with a hairdryer, then try it.
                      • 12206
                      • U.S.
                      If nothing broke and all connections are good, kinda thinking maybe a marginal capacitor gave up.
                        • 12206
                        • U.S.
                        Suppose it could have loosened a solder joint so check the joints on powerboard.
                        • cschappa
                          Craig
                          • Sep 2023
                          • 8
                          So, everything is reconnected, I tried to heat the board with hair dryer, and measured leads with meter.
                          12v = 0
                          5v = 0
                          5vsb = 5.2
                          The large brown cap, 450v 120uF reads 169v and does not change when power button is pressed.
                          • lotas
                            • Jan 2016
                            • 4614
                            • Russia
                            Most likely, your power supply is only in standby mode; in order for it to go into working mode, it needs to give a command - this must be done by the motherboard (3-5V) to turn on the β€œremote” pin.
                              • 12206
                              • U.S.
                              Ok, so try powerboard as stand alone, prolly easiest way is unhook cable from powerboard to mainboard on mainboard side, leave it off for test, trace wires back and jumper #1 remote pin and #7 5vSB pin, so you are jumping thru the UNPLUGGED connector. Then plug power cord in and see if you have those missing voltages and see if the backlights come on.
                              • lotas
                                • Jan 2016
                                • 4614
                                • Russia
                                Just connect through a 1 kOhm resistor.
                                  • 12206
                                  • U.S.
                                  Resistor is good practice, a safety precaution, not needed if there is no mistake in making connections.
                                  • lotas
                                    • Jan 2016
                                    • 4614
                                    • Russia
                                    It is always needed in such cases, firstly, it is not known what voltage is needed on the β€œremote” 3v or 5v, and secondly, it (the resistor) limits the voltage supply current.
                                      • 12206
                                      • U.S.
                                      Actually it's not worth debating, so go for the resistor, some have had unreliable results because of using the wrong size resistor, using the right size is fine.
                                      • cschappa
                                        Craig
                                        • Sep 2023
                                        • 8
                                        I was able to jumper #1 & #7, I couldn't find a 1kohm resistor.
                                        No backlight, also no 12v or 5v.
