Hannspree T280H not turning on
  • cschappa
    Craig
    • Sep 2023
    • 8
    1st Post here guys. I have a T280H that the cat knocked over. Everything else was fine before the fall, but now there is no display. There is a yellow LED that pulsates dim to bright.
    I have taken out the power supply, R0800-0805-060.
    I tried to test the pin outs 12v, see pic, which reads 0.00
    I do have 5v.
    Also, I noticed, the 2 metal heat sinks, checking the voltage between the 2 of them reads ~60v, but I am not sure if that is normal.
    I have looked at another post, similar PS, but a little different.
    Thanks in advance for any recommended suggestions.
    Craig
    • 12206
    • U.S.
    Re: Hannspree T280H not turning on
    Maybe the screen is broken, were any cables loose, look the screen over carefully with a flashlight.
    • cschappa
      Craig
      • Sep 2023
      • 8
      I just checked the screen with a flashlight, it all looks the same, no cracks or bubbles. The cables all look to be intact.
        • 12206
        • U.S.
        Is the input set correctly, might have bumped it.
          • 12206
          • U.S.
          Are you testing it with everything plugged in or is that cable unhooked?
          • cschappa
            Craig
            • Sep 2023
            • 8
            Testing with PS disconnected from everything, except main power.
            • cschappa
              Craig
              • Sep 2023
              • 8
              When TV is powered on, the yellow light would turn blue.
                • 12206
                • U.S.
                Test it with everything hooked up as normal, see what you have on those same voltages you checked.
                  • 12206
                  • U.S.
                  Can try a simple reset, unplug tv for a few minutes then press and hold power button on tv for 30 seconds, then plug it in and try it.
                    • 12206
                    • U.S.
                    Go ahead and heat up those capacitors on your powerboard for a couple minutes with a hairdryer, then try it.
                      • 12206
                      • U.S.
                      If nothing broke and all connections are good, kinda thinking maybe a marginal capacitor gave up.
                        • 12206
                        • U.S.
                        Suppose it could have loosened a solder joint so check the joints on powerboard.
                        • cschappa
                          Craig
                          • Sep 2023
                          • 8
                          So, everything is reconnected, I tried to heat the board with hair dryer, and measured leads with meter.
                          12v = 0
                          5v = 0
                          5vsb = 5.2
                          The large brown cap, 450v 120uF reads 169v and does not change when power button is pressed.
                          • lotas
                            • Jan 2016
                            • 4620
                            • Russia
                            Most likely, your power supply is only in standby mode; in order for it to go into working mode, it needs to give a command - this must be done by the motherboard (3-5V) to turn on the “remote” pin.
                              • 12206
                              • U.S.
                              Ok, so try powerboard as stand alone, prolly easiest way is unhook cable from powerboard to mainboard on mainboard side, leave it off for test, trace wires back and jumper #1 remote pin and #7 5vSB pin, so you are jumping thru the UNPLUGGED connector. Then plug power cord in and see if you have those missing voltages and see if the backlights come on.
                              • lotas
                                • Jan 2016
                                • 4620
                                • Russia
                                Just connect through a 1 kOhm resistor.
                                  • 12206
                                  • U.S.
                                  Resistor is good practice, a safety precaution, not needed if there is no mistake in making connections.
                                  • lotas
                                    • Jan 2016
                                    • 4620
                                    • Russia
                                    It is always needed in such cases, firstly, it is not known what voltage is needed on the “remote” 3v or 5v, and secondly, it (the resistor) limits the voltage supply current.
                                      • 12206
                                      • U.S.
                                      Actually it's not worth debating, so go for the resistor, some have had unreliable results because of using the wrong size resistor, using the right size is fine.
                                      • cschappa
                                        Craig
                                        • Sep 2023
                                        • 8
                                        I was able to jumper #1 & #7, I couldn't find a 1kohm resistor.
                                        No backlight, also no 12v or 5v.
