Sony xbr-75x900f 6 red blink
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    #61
    Re: Sony xbr-75x900f 6 red blink
    Check all the solder. Do you have voltage on your blue board now, going in and out?
    It only gets 12v from LED driver. Nothing for voltage ever hits the fuse
    Caps don't turn on, the IC chips start to get hot, and the cpu chips or whatever start to get hot also per thermal imaging and then just get that blinking code and they shut down
      • 12276
      • U.S.
      #62
      So where does it stand, have you done the powerboard stand alone test and did it pass?
        • 12276
        • U.S.
        #63
        Here's Bobby doing a stand alone test, I have also done it on sonys, prove the powerboard then can eliminate it from being a suspect: https://www.youtube.com/watch?v=EC4d8sCeS4w
          • 12276
          • U.S.
          #64
          Then move right to the next board and try to prove it.
          • zomi
            • Nov 2011
            • 509
            #65
            if u disconect that cable
            nothing happens ?
            it should cycle through the leds doing a self check
            • EazyBone
              • Jun 2023
              • 1353
              • United states
              #66
              nothing happens ?
              Nothing happens that's different. TV power is hit, supplies ALL correct voltage on main power board. Bl-ERR goes to .6volts then within a couple seconds goes to 3.3 volts. I have tried disconnecting the main board from PSU and jumped BL on Pwr ON and TCON on. When doing this all correct volts happen, BL never turns on either and this cycle never changes at all. It does the exact same thing every time. Except for when I disconnect the TCON cables from MB to tcon and the MB to LED driver, then the TV turns "on" at least I have sound anyway. But still nothing anywhere changes.
              The LED PSU never supplies the 35 or 70v (not sure cause never happened) to the LED driver board. It does get 35 v on some of the rails at startup and then BL err happens and the voltage drops. It's steady for a bit
              • EazyBone
                • Jun 2023
                • 1353
                • United states
                #67
                By prove it, do you mean force the on voltage for second PSU? I don't know how to do that to the second board. This is what I get on LED PSU output. And these numbers only change after 5 seconds by dropping to zero after TV detect error and want to flash red.
                  • 12276
                  • U.S.
                  #68
                  These ones with 2 or 3 of every board are complicated, maybe check all the solder joints on the other powerboard, might have some bad ones.
                    • 12276
                    • U.S.
                    #69
                    I absolutely hate these xbr's, still have my pos xbr that needs eMMC probably at least, maybe more.
                      • 12276
                      • U.S.
                      #70
                      Saw a video of Nick struggling with an xbr mainboard, he had to change out the eMMC, another ic and the hdmi ic.
                      • Diah
                        • Feb 2013
                        • 6438
                        you were hurry to put back the screen back... because with out screen the tv and BL would work if every things good..
                        6 blink BL... you changed them but you didnt have the BL tested before the screen... so now its usless to find the issue... if one or ribbon LED damaged or lost connection will drive you to same issue... you were very hurry and this way cant solve TV repair....
                        for clean trouble shooting and repair my way will be start from zero.. screen out
                          • 12276
                          • U.S.
                          #72
                          Tear it back down, these tvs aren't that great anyway, picture quality is pretty shitty, if it were me, it has become a quest to figure out this hair pulling-out mystery OR you could just it.
                          • Diah
                            • Feb 2013
                            • 6438
                            85 size i take screen out alone... its not that complex if you have the correct suck cups
                              • 12276
                              • U.S.
                              #74
                              May have gotten bad backlights, happens sometimes.
                                • 12276
                                • U.S.
                                #75
                                Yep, I agree Diah, need full access to everything.
                                • Diah
                                  • Feb 2013
                                  • 6438
                                  all possible... LED. wrong connection... bad ribbon...at the end TV will work and BL too with out screen.
                                  • EazyBone
                                    • Jun 2023
                                    • 1353
                                    • United states
                                    #77
                                    I can easily tear the TV down again. Taking screen off is intimidating but not impossible.bhow am I supposed to test the LEDs all the way at the end? Flip it up and just plug it in again? Okay fair enough.
                                    Diah, how do i test the LEds if it's all broken down. Or the ribbons?
                                      • 12276
                                      • U.S.
                                      #78
                                      I believe he means for you to test it with full access to backlights and without the screen/panel hooked up.
                                      • lotas
                                        • Jan 2016
                                        • 4753
                                        • Russia
                                        #79
                                        Not all Sony TVs will have backlighting without a connected panel (matrix).
                                          • 12276
                                          • U.S.
                                          #80
                                          Do you know if that's true for this model?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
