Philips 65PUT6121 - no backlight
  • Rubenlily
    • Aug 2023
    • 37
    • Sweden
    Hey guys,
    I have picture with flashlight but no backlight. Logo comes on quickly with low light before disappearing. When checking behind the tv I see backlight turning on in some holes before turning off and that's when the room is pitch black. Impossible to see otherwise. That explains the logo barely visible before disappearing. Don't know about sound but it should be fine. TV stays on.
    Here are some pictures and numbers taken with TV on.
    PIN1,2,3=VIN 33V
    PIN4,5,6 =GND 0V
    PIN7 =+18V 12V ???
    PIN8=BL-ON 3.2V
    PIN9=DIM 2.8V
    PIN10=ADIM basically 0
    PIN1=+VLED1 33V
    PIN12=+VLED2 33V
    PIN2,6,7,11=NC 2 and 11 = 33V, 6 and 7 = 3.8V
    PIN3,4,5=-VLED1 3.8V
    PIN8,9,10=-VLED2 3.8V
    So PIN7 shows 12V instead of 18V.
    Should I open up completely and check the strips? I don't have a LED tester and if some LEDs are broken or burnt it should show right?
    Please help me
  • Rubenlily
    • Aug 2023
    • 37
    • Sweden
    Re: Philips 65PUT6121 - no backlight
    [ATTACH]310233[/ATTACH]
    [ATTACH]310234[/ATTACH]
    [ATTACH]310235[/ATTACH]
    [ATTACH]310236[/ATTACH]
    [ATTACH]310237[/ATTACH]
    • notallbad
      • Oct 2012
      • 1183
      how old is the tv, probably at least 2 yrs old, so at a guess the leds will need replacing soon anyway and for around £25 you can get a full complete brand new set. But highly suspect leds are the cause.
      Connect an external source with sound playing so you can confirm the tv is on and working but the fact you can see a faint image already proves this really!
      How did you measure the led voltages? black probe to gnd, chassis?
      What voltages do you get on pins 1, 2, 11 and 12 with led connector removed?
      I think you will find 8 strips with 14 leds per strip, see photo. And a pair of led wires will drive 2 strips, guessing each pair of strips will be connected in parallel.
      • R_J
        • 9514
        +32 volts is the raw supply for the led circuit, If the led's are working, this voltage will be boosted to a higher voltage, but when there is even one bad led, the circuit will go into protection and shut down. So you likely have one or more bad led's in the panel.
        If you check that +VLED voltage as you turn on the tv, you might see that voltage come up for a second.
        • Rubenlily
          • Aug 2023
          • 37
          • Sweden
          It's from 2016. I tried playing from my laptop some music but since I couldn't see shit when trying to navigate on source I gave up on playing sound. I might just connect it to the tv outlet and see if I get some sound from there.
          Black probe to chassis.
          I didn't try voltages with panel disconnected. Will it make a difference? Since I suspected it was the strips I packed up the TV with all screws and everything.
          Also I think some voltages should be 0 and not 3.8. I probably didn't notice my multimeter jumping to mV when checking some pins...
          • Rubenlily
            • Aug 2023
            • 37
            • Sweden
            Thanks for the reply. Makes me more confident to order strips.
            • notallbad
              • Oct 2012
              • 1183
              Ideally you need to strip the tv down to access the led strips to confirm you are ordering the correct ones though I havent really had any issues ordering according to the panel i.d.
              Same tv model can have different panels and hence different led strips.
              Remove the rear panel to confirm the panel, will be a label attached to the metal chassis with the panel number and use to cross reference to the led strips compatibility.
              • Maalobs
                • Jun 2016
                • 120
                • Sweden
                Also, you can download the service manual from this page:
                https://www.electronica-pt.com/esque...ileinfo/69941/
                • EazyBone
                  • Jun 2023
                  • 1303
                  • United states
                  I just repaired a Phillips with this exact symptom. It was one LED. And no I couldn't identify which light was out after opening it. It didn't look burnt. I had to LED test every individual one. LED tester is best way imo to confirm without having to open it up. Some people here say it's unreliable because of not enough mamps to "confirm" but it's never failed me yet.
                  • Rubenlily
                    • Aug 2023
                    • 37
                    • Sweden
                    I have a new problem. I'm just replacing the strips when I see the panel cabel is burned. Should it be fine or should I get a new cable?
                    • Rubenlily
                      • Aug 2023
                      • 37
                      • Sweden
                      Please check my latest post. I'm soon done with replacing the LEDs and don't wanna have done it for nothing lol
                      • Rubenlily
                        • Aug 2023
                        • 37
                        • Sweden
                        I don't have led tester. Just replacing all strips
                        • Rubenlily
                          • Aug 2023
                          • 37
                          • Sweden
                          Fuck me the cable is total burned. Have to get a new one... hope I don't have to replace the contact too................
                            • 12076
                            • U.S.
                            Damn that's fried, I wonder what caused it.
                            • EazyBone
                              • Jun 2023
                              • 1303
                              • United states
                              I'm gonna go with electricity. That'd be my guess
                              But yea that's pretty nuts. Haven't seen that yet
                              • William1967
                                • Nov 2017
                                • 203
                                • Netherlands
                                Solder the cable on the pcb, cables are not sold by Philips.
                                • ohren
                                  Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                                  by ohren
                                  I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                                  The setup is basically:
                                  Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                                  Transistor is switching the 3.5 V supply on the power board....
                                  12-05-2024, 11:10 AM
                                • ovrax
                                  Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                  by ovrax
                                  First of all, please excuse me as I'm quite new to this field.
                                  I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                  I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                  The Ambilight works perfectly and stays on.
                                  No sounds.
                                  Thanks in advance.
                                  08-25-2024, 04:33 AM
                                • bohaboha
                                  PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                  by bohaboha
                                  when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                  Do I disconnect the plug from the power supply, no backlight
                                  Thought the backlight would light up when you remove the plug from the power supply but no
                                  What could be wrong if both halves work separately?​...
                                  03-07-2025, 09:45 AM
                                • groomit
                                  Philips 50PUS7363/12 Backlight but no picture
                                  by groomit
                                  I'm having trouble with above mentioned TV. Bought it defect.
                                  Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                  Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                  I can see backlight, but screen stays black.
                                  What I've tried:
                                  - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                  - Disconnect left side...
                                  11-22-2024, 02:43 PM
                                • malekservis
                                  Philips 58PUS8536/12 Backlight ok, no image
                                  by malekservis
                                  the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                                  Any information would be appreciated....
                                  08-07-2024, 07:48 AM
