Samsung BN44-007676A power supply
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Found my first burnt power supply!
    Now I have no idea what I'm doing lol.
    So I found where the most "burn" is and circled it from the component and I've been testing things and found that d9002c diode is good and testing .45 and it's connected to b9008. This is where more of the burn mark is shown on the board. First of all does anyone know what b9008 is? And second how am I to test this?
    Is there something around the area that I should test? Kind of a big discoloration around this area.
    I'm trying to replace pieces instead of the board and up my game bed tonight and this is as far as I got. Thanks
  • CapLeaker
    Leaking Member
    • 8351
    Re: Samsung BN44-007676A power supply
    As long as the power supply works, never mind the darkened area. This darkened spot men’s nothing, as the discolouration on the board is from the heat from the diodes, not from exploded parts (carbon).
      • 12328
      • U.S.
      B9008 looks to be a ferrite bead, probably fine, tests same as a fuse or jumper, should show continuity.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        Oh, I didn't mention sorry. The power supply doesn't work properly. It shows 8v varying where it should be 13v constant at all the pints. The stby is also about 2.4. but okay will keep tewtint board
        • R_J
          • 9623
          This is normal, If you force the power ON, you will have a steady 13v.
          Read the information on the corner of the board
          STB:8v
          On:13v
          There is no separate STANDBY voltage, this is an always on power supply
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            STB:8v
            On:13v
            Hmm I see maybe I was incorrect on this. How would I force the power on? Jump something?
            • CapLeaker
              Leaking Member
              • 8351
              Plug in the backlights, while keeping the main board removed. Plug it in and the backlights should come on so does everything else.
              You also can take a few 1k ohm resistors and jumps stby to PSon, BLon maybe some DIM.
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                STB:8v
                On:13v
                Oops forgive me I did something wrong. It's not 8v on standby, it's actually 3.3 on standby and the voltage for each pin is jumping all around. Even where it says 8 v for standby that pin is also 3.3 ... 3.2... 3.4... 3.5... etc so yes something with power supply.
                Back to testing board lol
                • R_J
                  • 9623
                  It may be as simple as CM809 and CM814 are bad, as in open and not charging to keep the ic operating.
                  Check that D9001c and D9002c are ok and not shorted. If they are not shorted, check what voltage you get on D9001c Cathode, it could be around 330v but is likely less given the state of the 13v
                  Check the voltage across one of the main caps CP806 or CP807, this will tell you if the pfc circuit is working
                  Post the ic number of ICM801S It might be a FA6A20N or similar
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    Will check tonight!
                    • EazyBone
                      • Jun 2023
                      • 1362
                      • United states
                      Took out each capacitor from the board and checked capacitance and all are reading the correct uf within 5 percent.
                      Checked d9001/2 and not shorted.
                      Icm801 I have picture kind of hard to see as I had to scrape some silicone. Don't even know what this is lol.
                      Tested mosfets from drain to source in diode mode. Are the first two bad mosfets?
                      I been learning how to test them and shouldn't they be OL like others?
                      Mosfet cold side
                      MBRF10150CTL
                      Dm851c
                      Starts zero climbs to 3v slowly
                      Mosfetcold side
                      Dfrf10a60cta green
                      Dm853c
                      .434
                      Mosfetcold side
                      Dfrf10a60cta orange
                      Dm854c
                      OL
                      Mosfetcold side
                      3n50nz
                      Q9001c
                      OL
                      Mosfetcold side
                      3n50nz
                      Q9002c
                      OL
                      Mosfet hot
                      Kf9n50
                      Qm801cs
                      OL
                      Mosfet hot
                      Kf9n50
                      Qm803cs
                      OL
                      Two more mosfer cant read letters
                      Both OL hot
                      Next step anyone? And my mosfets are bad yes? YouTube doesn't answer me lol.
                      Also all the mosfets tested in continuity mode don't test short.
                      I'm gonna figure this out lol
                      Thanks all!!����️����������
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • cheeky2
                        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                        by cheeky2
                        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                        06-15-2025, 05:12 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
                      • Cookybaby
                        Samsung UN60ES6500FXZA Power Supply Issue
                        by Cookybaby
                        Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                        I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                        Make: Samsung
                        Model: UN60ES6500FXZA
                        Power Supply P/N: BN44-00525A
                        Symptoms: The TV was...
                        08-20-2023, 12:26 PM
