Vizio VW42lHDTV10A no pix, no sound, won't turn off
    Re: Vizio VW42lHDTV10A no pix, no sound, won't turn off
    0707 is probably the datecode.
    if it was the voltage, it would be directly behind the 1084, with a dash in between (like 1084-33 for 3.3V or 1084-18 for 1.8V)
    i bet is an adjustable version of the 1084 type regulator..
    edit: ha!
    http://www.alldatasheet.com/datashee...GMT/G1084.html
      I just tested it with the power on and got 5.2 volts input with 2.7 volts output. So it could be adjusting the output voltage
        Well I finally located the correct service manual for my Visio VX42LHDTV10A and I found another bad chip, the U6 chip (which is an AP1513 stepdown converter according to Digikey) On pin #2 I get 1.6 volts instead of the required 1.8 volts. I'm wondering if maybe one of the failing other "U" chips may have something to do with it. That all came right after I placed the order on Digikey so now I have to either find one locally or place another order. I did not trust the first manual anyway because it was not for this model.
        http://search.digikey.com/scripts/Dk....dll?Selection
          The number should be amc1117 (f0705j) under it. The number I gave was the part number on the faulty board and I couldn`t find it either.
          I replaced it with one of these (amc1117)
          I just replaced another on a soyo mainboard that would not power on.
            Did the cpu fan come on but there was no post beep sound? I have a board that only booted when it felt like it, changed the capicitors and now it does not even finish booting (I wonder if it could be the cmos).
              If your referring to the U9 and U33 chips, I did get them ordered but the U6 chip is different.
                i have the same problem...could you assist me with it?
                  could anyone tell me what the digi-key pt# for u9 is? its labeled k1117s15 with 734 under those numbers.
                  thanks.
                    thanks.
                    AP1117E15GDICT-ND
                    PlainBill
                      On your Vizio VW42lHDTV10A where did you find it at ?
                      I have the same set as you but can't find the correct
                      service manual. I have been looking for three days
                      with no luck, can you point me in the right direction?
                        Use IE8 at
                        and click on the Get Manual button.
                        --- begin sig file ---
                        --- end sig file ---
                          Thanks for the help it's the right one
                          but does not have the Main Board Circuit Diagram
                          It's Listed in the Appendix but the Appendix is missing from the manual.
                          I am a older disabled electronics tech
                          So I was trained to follow circuit diagram's with test points and following the circuit to find the problem, So I am going to have a problem fixing this thing.
                          Thanks again
                            I am fighting a similar issue with a VW32LHDTV10A, no pix, no sound, no backlight, front indicator turns white. Does any know where I can find schematics for this? I have found a service manual but no schemats. So far the unit will power on normally part of the time however I ran the tv for an extended period yesterday (about 6 hours) and it quit. I haven't tried to see if will power up again.
                              Do a search on this web site for VW32lHDTV10A or VX32lHDTV10A
                              or VW42lHDTV10A or VX42lHDTV10A
                              There is plenty of people with the very same problem, most of them have bad caps
                              on the power supply or main board.
                                You all solved my problem! See post #39 here:
                                https://www.badcaps.net/forum/showth...t=13792&page=2
                                  i have vizio vx42lhdtv10a
                                  bought it other day for $5
                                  tv powers on with backlight only....wont power off
                                  no pic..no sound....nothing
                                  voltages from ps all test good
                                  researched and found out very common issue.(so common that they sell these on ebay specifically saying for vizio repair lol) ...and it could be a voltage regulator on main board U33...i checked voltages per youtube video and mine tests bad just as his did...so im hoping once replaced tv will be fixed
                                  its under $1.00 for the part...
                                  will update when i get part
