Snap in Capacitors
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Snap in Capacitors
    FIRE!
    ah, fun! i hope nobody got hurt... pics?
    sigpic
    (Insert witty quote here)
    • lauriloo
      • Jun 2010
      • 6
      FIRE!
      No, I wasn't hurt. Glad I wore sunglasses! When I saw the cap jump, I backed away and then it exploded in flames. It exploded so hard it ended up jammed into the heat sink next to it so I had to pull out enough guts to loosen it up. You can see the dent on the top where it was wedged. One pic is the guts I pulled out and the other pic is the shell that remains. I think the fire burned up most of the oil because the surrounding board was mostly covered with tissue and metal bits.
      I ordered replacements from Digi-key (thankfully we are both in MN) and I hope that will fix my tv.
      • Scenic
        o.O
        • Sep 2007
        • 2640
        edit: lol just noticed this useless post is my post #900
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          well, to the book of recapping rules, add:
          "if it hisses, BACK OFF AND PULL THE PLUG! NOW!!!"
          damn. got the fireworks going. c hegge would be proud (he loves to throw bad caps in fires; see his sig)
          gives new meaning to the joke known as hongkongflyapart, LLC!
          sigpic
          • lauriloo
            • Jun 2010
            • 6
            yeah, that's how I looked!
            Really hope the power surge that tripped my house breaker didn't fry anything else on the tv. Is this likely? Nothing seems wrong to the naked eye or nose but I haven't exposed every board to look at it, either. All the connectors that were plugged into the board look perfectly normal.
            • lauriloo
              • Jun 2010
              • 6
              #26
              Also add "If you really must troubleshoot capacitors on a live tv, wear safety glasses"
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #27
                lauriloo; that's pretty cool
                What was the brand of the capacitor?
                • lauriloo
                  • Jun 2010
                  • 6
                  #28
                  The infamous Samwha brand that is plaguing lcd tvs.
                  • seanc
                    • Nov 2008
                    • 1319
                    #29
                    Oh yes, the remaining bulging capacitor definitely = toast.
                    Glad you're OK - hopefully after replacement everything will be working fine
                    • lauriloo
                      • Jun 2010
                      • 6
                      #30
                      Replaced the caps myself (first time soldering a board!) and the two snap in fuses that were blown. The tv has been on for five hours so far, no hissing or issues whatsoever. yay!
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        WOW. After such a cap failure like that it would be a good idea to check the power diodes fuses and current limiting resistors BEFORE applying power for the first after a recap job.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          good. now you see why many of us keep our eyes out for dead flatscreens on craigslist and in dumpsters, they are often a case of blown samwha's/capxons... a recap later and they are as good as new, most likely much better.
                          sigpic
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Originally posted by mwturtle1
                            I have an LG LCD tv (47LC7DF-UK) the picture only comes up after numerous times turning the set on and off. I hear buzzing coming from the SAMWHA capacitors (450WV 150uF) and wonder if these are snap-in capacitors. The name is confusing and I think that I can replace them by pulling them out and pushing new ones in. However I looked at the back and see the soldered parts and wonder if I am just delusional. Does anyone have any input? Thank you!
                            'Snap-in' is just a way to hold them in place until soldered.
                            Mann-Made Global Warming.
                            - Dr Seuss
                            • dhack61
                              • Aug 2010
                              • 33
                              #34
                              New Cap Bulging
                              I had or maybe still have the same problem with the same 47LC7DF-UK after seeing the pics I noticed 3 of my 2200uf caps bulging / split, so I ordered 5 2200uf panisonic 5000hr caps from Digikey. After replacing these the set came back on and functions. But there is one that popped after I installed it. So thinking it was my installation I replaced it again. Turned the set on and it worked but after letting it run for several hours I noticed the same cap location was bulging. since I'm a Newbie I was wondering what is the major cause of a new Cap going bad so quick. Under voltage or Over or a short.
                              Maybe its time for a new board but spending 10 bucks compared to 120 is more my speed.
                              Dhack
                              • seanc
                                • Nov 2008
                                • 1319
                                #35
                                Overvoltage, capacitance being too low or installed backwards.
                                What series of Panasonic did you buy?
                                • dragon3x
                                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                  by dragon3x
                                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                  power on.
                                  Here are some examples :
                                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                  switching supply area).
                                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                  than 6.3 V.)
                                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                  I replaced capacitors with aluminum-polymer.
                                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                  03-21-2025, 02:46 PM
                                • slybunda
                                  AA and AAA battery charger capacitors?
                                  by slybunda
                                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                  it has inside:
                                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                  2 x 470uf 16v LZ105c branded as G.Luxon
                                  not heard of these brands are they any good?
                                  iv attached photos of the charger and the board inside for an idea on the type of...
                                  12-24-2023, 04:41 AM
                                  by sam_sam_sam
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • Ady2017
                                  Are there any datasheets available for Elna RJG capacitors?
                                  by Ady2017
                                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                  05-25-2025, 02:19 PM
                                • ctroxtell
                                  Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                  by ctroxtell
                                  I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                  01-03-2025, 08:57 PM
