Sonos Playbase S11 dead. No led at the front
  • waakye
    • Dec 2018
    • 340
    • Electronada
    Good days guys,
    First of all I want to thanks all members of badcaps. This site and its members have help me troubleshoot and repair tv.
    My issue is a Sonos Playbase S11 that completely died on me. Fuse check out ok. No indication of burn on the power supply board. The two big caps are showing 135vdc. I can't seem to find a schematic anywhere.
    I need your help once again.
    Thanks in advance.
    Images are attached
  • waakye
    • Dec 2018
    • 340
    • Electronada
    Re: Sonos Playbase S11 dead. No led at the front
    Any help guys.
      Canadian AC Voltage is 120VAC, correct? If it is then the Main filter caps should have about 165VDC measured between the + and - legs of the main filter cap.
      What is the P/N of that SMPS IC, U15?, that drives the power MSOFET on the heatsink?
      • waakye
        • Dec 2018
        • 340
        • Electronada
        Hi budm thanks for replying. That's correct canadian AC voltage is 120VAC. U15 P/N is NCP 1937B1G.
        Thanks again for your help.
          So recheck the DCV of the main filter cap again, the cap will be charged up to the peak Voltage of the 120V RMS, 120V x 1.414 = about 169VDC. So may be your meter is not calibrated or error in measurement.
          • waakye
            • Dec 2018
            • 340
            • Electronada
            I double check with another multimeter and am reading 160.3vdc on the main caps.
            • CapLeaker
              Leaking Member
              • 8132
              That is o.k. probably your mains are 110-115V.
              • waakye
                • Dec 2018
                • 340
                • Electronada
                Is odd because the power led on the Playbase is not on. There is no switch to turn it on. You just connect the Playbase to 120vac outlet and the the front led turns on.
                • waakye
                  • Dec 2018
                  • 340
                  • Electronada
                  Are there any schematic of this power supply board around. Could someone help to troubleshoot the circuit.
                  • waakye
                    • Dec 2018
                    • 340
                    • Electronada
                    A more zoom in pictures below.
                    Thanks again
                    • waakye
                      • Dec 2018
                      • 340
                      • Electronada
                      I guess am on my own on this one.
                      • waakye
                        • Dec 2018
                        • 340
                        • Electronada
                        Any help guys!
                        • Zinge
                          • Apr 2021
                          • 19
                          • Poznan
                          I have the same one. Problem
                          Does anyone know how to solve it? Maybe it's the software?
                            Any help guys!
                            If you measure the DCV between the two legs of any one of the 3 lytics green caps that are glued together, do you get any Voltage when the AC is applied to the board? Be real careful not to touch anything in the hot, so to be safe you may want to plug the AC cord into GFCI outlet.
                            • waakye
                              • Dec 2018
                              • 340
                              • Electronada
                              Thanks budm for replying. Below are my observations:
                              I have AC applied to the power supply circuit and the each one of the 3 lyrics caps are measuring 13.25VDC and it jumps to 14.53VDC and it keeps cycling continuous from 13.25VDC to 14.53VDC.
                              Thanks again
                                1) So the power supply is not dead then, that power supply is an always on power supply, it will run 24/7 as long as it is plugged into the AC outlet.
                                2) What is the DC Voltage rating as printed on the bodies of those 3 caps?
                                3) There are four lytics caps on the cold side, so check and see if they have any DCV on the two legs of each cap, also tell us the Value and Voltage rating of those 4 caps.
                                • waakye
                                  • Dec 2018
                                  • 340
                                  • Electronada
                                  Hi budm. Thanks for the quick reply.
                                  1) If the power supply is not dead then that means the logic board is toast?
                                  2) the voltage rating on the 3 caps are 35V
                                  3) I verified the voltage on the four lytics caps on the cold side and all four reads 13.25VDC then goes to 14.53VDC and keeps cycling between the above values. The DC voltage rating on the caps are 50V.
                                  Last edited by waakye; 04-29-2021, 09:04 PM. Reason: Typo lytics instead of lyrics
                                    The board you have is the power supply/Amplfier board.
                                    Can we see the main logic board next?
                                    • waakye
                                      • Dec 2018
                                      • 340
                                      • Electronada
                                      Hello budm,
                                      Below are the pictures of the logic board as requested.
                                      Thanks for your help in this.
                                      • Zinge
                                        • Apr 2021
                                        • 19
                                        • Poznan
                                        I'm sorry I got into your topic. I didn't have any output voltage from the power supply
                                        There was a short circuit (0Omh) on the three Green capacitors
                                        As a diode, there is a mosfet Q4. It's been burned down.
                                        As I replace it I will say or do it
                                        PS/
                                        Author of the topic check the main voltages on the board (RAM,FLASH,CPU)
                                        • Andreasbest
                                          HP 800 G2 DM front right USB dead
                                          by Andreasbest
                                          Hello.
                                          I received a lot of HP 800 G2 DM this week, during testing we found one of these has dead one USB in the front right, there is no visual damage and contact cleaner didn't work.
                                          How can i verify if it's a connector OR motherboard problem to proceed accordingly ?
                                          Thank you!
                                          09-11-2023, 10:21 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
