the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Behemot
    • 4845
    • CZ
    #781
    Re: the gutless, bloated, and fried power supply hall of shame
    Works…but how far? No way that glass diode as one-way rectifier can do >1 A on spikes. And look at the soldering…
    • RJARRRPCGP
      • Jul 2004
      • 6301
      Originally posted by SIDMX
      FSP F350-A went seppuku!
      PSU spec is more like a 2003!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • mariushm
        • May 2011
        • 3799
        #783
        Originally posted by Jooo
        Chinese 1$ including shipping phone charger.
        Brand is TJ Courier Charger, specs 5v 500ma.
        Surprisingly, this thing works.
        That's bad... how cheap and crappy can they go....
        It's worse than the charger I got as basket filler for an order, which I reviewed here: http://www.youtube.com/watch?v=YLjojTnkJq8
        At $1.67, it's much better than yours but still crap.
        • Jooo
          • Oct 2011
          • 222
          • Finland
          #784
          The casing is actually identical to this one. This was from Ebay though.
          And no, I'm not going to use it.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            #785
            apevia? 700w
            yeah right.
            my guess is 300 without a kaboom.
            this turd was bought by a friend of the shops roomates against everyones advice.lasted just short of a year.i wanted to see how far it would go.
            model atx-cb700w
            • LDSisHere
              • May 2012
              • 727
              • U.S.A.
              #786
              The way the caps are attached to the mains input is very......interesting. Safety must have been their main concern followed closely by wanting to put out a quality product that would easily do its' full rating.
              The important question is did the original buyer learn their lesson?
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                YoungYear do make their model numbers double what they design their units to put out, so ATX-600 would be spot on for 300W.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #788
                  just what i told him it was good for.
                  the funny part is i googled atx-cb700w review and landed on his freshly posted review on newegg!
                  damm right a 300w unit with the ocp rigged up will make a nice space heater.....till the kaboom!
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #789
                    nice lead dress there huh?
                    sleeving those cap leads would have cost about 1/10 of a cent!
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Power Star PS-650
                      So Power Star, 650W huh? Ohhhh they meant at -25*C ambient But at a realistic temperature....250W cause of those 13007's. Even if it had 13009's, that transformer could pump out maybe 300W?
                      The NTC thermistor looks pretty pitiful
                      The rectifiers are a joke with 12V = 16A, 3.3V = 20A, 5V = 20A. I found it interesting how they used a PI filter on the 3.3V rail but put a jumper for the 5V and 12V PI coil slots. So maybe your RAM won't fry?
                      The 5VSB transformer is tiny! And using the 2 transistor design, I'm sure that area would run pretty hot.
                      The only words of praise this unit gets, is that ugly WAM fan moves a lot of air while being quiet, and the bearing was well lubricated
                      Not sure who OEMs it but on the PCB reads "ATX-320LY1" I imagine you could get this design up to 320W safely with the right parts
                      Chinese worker 1: I know this thing is unreliable and all....but how can we make it less reliable?
                      Chinese worker 2: I dunno...maybe make that hot minimum load resistor physically touch that low quality H.Q. cap?
                      Chinese worker 1: Genius!
                      Last edited by c_hegge; 10-25-2013, 08:45 PM. Reason: Fixed Title at user's request
                      • PeteS in CA
                        • Aug 2005
                        • 3578
                        • USA, Unsure of Planet
                        #791
                        Pretty standard 200-250W TL494 clone based, 25-50KHz half bridge design. Even a mere 250W would cook the O/P caps or the O/P inductor cores. Assuming the main transformer core didn't saturate, with a resulting in a loud noise, bright flash, and unpleasant smell.
                        PeteS in CA
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          The only good about it is it looks like it has proper Y capacitors ... not regular, unsafe, ceramic capacitors.
                          Muh-soggy-knee
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: Power Start PS-650
                            Originally posted by Pentium4
                            Not sure who OEMs it ...
                            If you look at the fan, you can tell that the OEM is Mary. Because it has a little Wam.
                            • cheapie
                              null
                              • Jul 2010
                              • 849
                              I know I've heard that somewhere before...
                              Originally posted by c_hegge (on jonnyGURU)
                              It's Mary. How do I know? Look at the fan shot. It has a little Wam
                              Sorry, I couldn't resist.
                              Originally posted by Oklahoma Wolf (on jonnyGURU)
                              You've been reading too many of my reviews
                              I think I've been reading too many as well.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Yeah, but we're not all on JG too.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  Originally posted by kc8adu
                                  apevia?
                                  Whhuuuutt?? I had nothing to do with this... I swear!
                                  300 milliwatts...
                                  model atx-cb700w
                                  Real far- out da window and into the dumpster!
                                  Cal, you funny- I got a good laugh from your "WAMs" after a rotten week. Thanks!
                                  "pokemon go... to hell!"
                                  EOL it...
                                  All style and no substance.
                                  guilty,guilty,guilty,guilty!
                                  guilty of being cheap-made!
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    #797
                                    so it goes WAM! when it fails?
                                    power star.
                                    turn on the power and WAM! stars come out?
                                    • cheapie
                                      null
                                      • Jul 2010
                                      • 849
                                      No, it goes "WAM!" when you throw it at the wall after it blows up your hardware.
                                      Actually, I think you're right. It would probably crumple and float away if you threw it at the wall.
                                      • lti
                                        • May 2011
                                        • 2546
                                        That's what I was thinking.
                                          master hoarder
                                          • May 2008
                                          • 12164
                                          #800
                                          Re: Power Star PS-650
                                          Yes, very important for your SDRAM to have clean power!
                                          Oh wait, it's not 1999 anymore?
                                          so true
                                          Those Chinese PSU names are funny. Though still not as funny as PowMax, IMO.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
