the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by momaka
    You mean you didn't pull any components off of it?? Not that there is much in there, but stilll... shame shame shame
    No, for me, scrapped means dissasembled and salveged, etc...
    Ummm.... wrong guy?
    Okay, close enough. He's my Romanian neighbor after all
    LOL!!! Ooops
    momaka, mariushm, momaka, mariushm ... easy to confuse between the two xD
    Originally posted by Wester547
    Thanks for the explanation. I think you once found a 1000uF, 16V CapXon KM that bloated on its own in the -12V output of a Bestec... perhaps that self-regulating linear circuit is the reason?
    Maybe the PSU was heavily loaded, but the -12v was not, so it rose to over 16v and slowly killed the capacitor?
    Muh-soggy-knee
    • Rulycat
      • Apr 2010
      • 724
      #702
      Originally posted by Behemot
      Saturn caps We can blow you to Saturn and beyond! Isn't that great slogan?
      I know a few girls who use this slogan... I'm not sure that they're in the capacitor business though.
      • Behemot
        • 4845
        • CZ
        #703
        You associate with strange people, sir
        • c_hegge
          • Sep 2009
          • 5219
          Oh, Deer Me! Another Deer, It was branded "Mirage", rated at 500W. It's similar to the A-Power in Post 685. Let's have closer look at it.
          2A four diode treatment - check
          Tiny 330uF input caps - check
          13007 Switchers - check
          Very thin heat sinks - check
          EI-33 transformer - check
          Junk caps - check
          Two 3A fast recovery diodes on a bracket for the 12V rail - check
          Tiny secondary toroid coils - check
          No-name sleeve bearing fan with no oil in the bearings - check
          Big hot load resistors next to the secondary caps - check
          And I think that about covers it. Horrible design from the ground up.
          Sorry about the horrible picture quality. All I had was my tablet
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Oh man that is horrible. Does the fan still spin?
            Not able to supply a useful load in spec - check
            Interesting, it looks like all of the Su'scon caps are good. Did this thing kill the motherboard it was connected to?
            Also, can you post a picture of the label?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Lots of YC (planet) caps in that PSU...
              sigpic
              (Insert witty quote here)
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Yuck. I'm surprised they wasted input filtering on this thing. Those are actually decent looking Y caps
                • c_hegge
                  • Sep 2009
                  • 5219
                  Yes, it does. It doesn't have any odd sounds either, although I've seen those same fans fail lots of times before
                  I noticed that. It looks like Yang Chun are worse than Su'Scon. No, it didn't take the board with it. I replaced it with an In Win IP-S400EQ3-2 and the PC was fine.
                  No, I don't have the label. I peeled it off and tossed it before I took the pics. I transplanted the innards of a Dell H305P-00 PSU into its case.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    I'm surprised, and judging by the dust it ran for a long time. A drop of oil and it might last a while assuming the motor isn't on its way out
                    That's embarrassing. Although I think the Su'scon also would have failed had they been on the 5VSB
                    Nice! The case must have lots of holes in it. Is it not one of the classic flimsy aluminum-esque cases?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      The case wasn't too bad. It had plenty of ventilation (similar vent structure to the one in post 685), and even screw holes for a front 80mm fan (which I installed, after cutting out the area in front of it)
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        #711
                        more openings to let the sparks/flames leave.
                          master hoarder
                          • May 2008
                          • 12168
                          #712
                          Yeah, that's a big one on the list .
                          Had a PSU like that. The lack of PI coils and missing caps made the PSU put out too much ripple even when powering a Pentium II PC!
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            That's pathetic! Was it a Deer as well? Let me guess, one cap per rail <2200μF
                              master hoarder
                              • May 2008
                              • 12168
                              #714
                              Yeah, it was my LC-B300ATX. 2200uF for the 3V and 5V rails, 1000uF for the 12V rail. But no PI coils. Hence the ripple. I added the PI coils and more caps in it right now. Haven't posted a picture nor tested it yet with a computer, but I'm sure it's better.
                              • PeteS in CA
                                • Aug 2005
                                • 3578
                                • USA, Unsure of Planet
                                #715
                                250W continuous would entail some risk of an incendiary event. 500W? For how many picoseconds?! I also noticed it has what appear to be safety agency rated Y caps (2200pF, perchance?), and also a common mode input inductor and a somewhat puny looking inrush limiting thermistor (were the rest of the thing not so pathetically wimpy and it really could supply 500W continuous, that thermistor might do double duty as a night light).
                                PeteS in CA
                                • pc7fan
                                  • Aug 2013
                                  • 52
                                  That's a real crap in a sack there! Saturn logo fan, these fail too frequently...
                                  The board is scorched... Fire hazard! This PSU belongs to
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    That's exactly where it went, except for the case
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3578
                                      #718
                                      Maybe those cheap junk fans could be used to clear solder flux fumes when you do solder work. Or maybe as a fan for test loads. Finding "replacements" won't be difficult.
                                      Technoid folk tend to have a strong packrat instinct.
                                      PeteS in CA
                                      • pc7fan
                                        • Aug 2013
                                        • 52
                                        I agree with you, the fans are good enough only if we oil them, they can last a while, I'm actually very surprised that crappy power supply ran for that long on a computer!
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          Pixxo PL-500RPG
                                          Weak Pixxo PSU made by Key Mouse. Looks pretty bad overall but it could be worse. The input caps are 820uF, I will have to see if they're actually 820uF. BR is 4A, those 2 Y caps are not safety approved. Uses fake Fairchild 13009 switchers.
                                          Main transformer is pitiful. Besides the input all the caps are ChengX.
                                          All the secondary silicon uses 20A schottky's for each rail. None of the rails have the option to add another in parallel. The toroids are small, missing caps on the secondary filtering. At least it has PI coils though... Fan is branded "kemex"
                                          Oh and look at the 5VSB transformer, there's a cut lead leg under the transformer sticker
                                          250W on a good day? Surely not 500W says Dr. Evil
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
