the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4923
    • New Zealand
    #741
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by DeanCollins
    hmmm can I get a second confirming that its just glue?
    That sucks as it is the only obvious thing I can see.
    Looks very much like glue to me. They typically use glue on big capacitors and other large parts during assembly.
    Many times a fault is not visually obvious. Capacitors can also dry out, causing the same failure but no visible signs. Only way to check for sure is with an ESR and capacitance meter.
    -David VanHorn
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      #742
      Glue/RTV is also used for mechanical stability under shock and vibration.
      PeteS in CA
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Originally posted by Pentium4
        Same picture as in the badcaps photo gallery
        They have the Fairchild F, with no dash through the F and they just look cheap. I will post a picture of them later tonight
        Ahh yes, I have seen those! I pulled a pair of 13007's and 13009's out of a pair of YueLin YLP-013's. I just called them "Jairchild" as I could not find any manufacturer information.
        In fact, I just found them:
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Mine actually look different though, I couldn't for the life of me get a good picture of them with my phone but this is the best pic I got
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            They are definitely fairchild parts you have there.
            Muh-soggy-knee
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              It's weird though, the one you can't see on the left has a different style F than the one on the right.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Like this one? That is a toshiba made transistor.
                Muh-soggy-knee
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  This thing came in a case. CWT, you should be ashamed! This thing is so bad. No input filtering, 330uF input caps (They're actually 220uF) 13007's, one of the smallest main transformers I've seen in an ATX PSU, 16A for 3.3V and 5V. 10A for 12V. hardly any filtering, tiny output coils. Look at the grounding wire for the transformer This thing is just horrible.
                  • dmill89
                    • Dec 2011
                    • 2534
                    Surprisingly the Sun-Pro built Thermal Master's are actually built better.
                    https://www.badcaps.net/forum/showth...Thermal+Master
                    CWT really should be ashamed.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Yeah, you won't hear this anywhere else: "The Sun Pro is built better in every way!"
                      • c_hegge
                        • Sep 2009
                        • 5219
                        I presume it came out of a CoolerMaster case. In which case (pun intended), they too ought to be ashamed.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Yes you are right. What do you think it could do? I think this is a rare instance where the transformer would saturate before the 13007's would blow LOL
                          • PeteS in CA
                            • Aug 2005
                            • 3578
                            #753
                            Very shortly before, I would add. That said, wh-e-e-e-e-ere's the BEEF? There's hardly any there, there. 250W would be pushing your luck with that one. At least it's light ...
                            PeteS in CA
                            • lti
                              • May 2011
                              • 2546
                              That might be even worse than that 420W Okia (also built by CWT).
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4923
                                • New Zealand
                                #755
                                That design seems to be popular... I've seen it in ColorsIT and Excel PSUs too, 120 and 80mm fan versions.
                                -David VanHorn
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  No beef! It's funny because if every one of the rectifiers on the 3 main rails was pushing their rated amperage, it would be just a hair over 250W
                                  Might be...at least this one has two toroids!
                                  Were they CWT as well?
                                  *general question* How come fast recovery rectifiers tend to have a higher peak repetitive reverse voltage compared to schottky's? Or is this not something that is very important if you were to replace a fast recovery rectifier with a schottky?
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I'd give it 200W without blowing up, but nothing at all with the ripple in spec.
                                    • lti
                                      • May 2011
                                      • 2546
                                      The Okia had room for pi filters on all outputs and didn't have that one random strand of wire coming out of the transformer for grounding. How is that supposed to work?
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3578
                                        #759
                                        I was going by the heatsinks, and was a bit over-generous, maybe. I considered guestimating 235W, a common rating back in the late 90s.
                                        PeteS in CA
                                          master hoarder
                                          • May 2008
                                          • 12164
                                          #760
                                          Please double-check tell me this really is NOT the grounding wire! If it is, it would be absolutely ridiculous. Maybe a bad joke on CWT's part?
                                          Also, notice the text under the warnings on the label.
                                          "As sealed stick was removed,..."
                                          Hilarious!
                                          IMO, that main traffo won't handle more than 150W. Come on, it's the size of a quarter!
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
