the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
    master hoarder
    • May 2008
    • 12175
    #321
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by Pentium4
    I'll recheck tomorrow. I'm pretty sure it was a 30A part for the 5V though
    Even better. It's probably a SBL3040PT or SBL3045PT. You can add some serious capacity to the rails of a PSU with this component. The only place where you likely won't be able to use it is on the 12V rail of half-bridge PSUs. Single and double-transistor forward converter design PSUs can use it on the 12V rail though.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      #322
      Do half-bridge PSUs have more of a limit in what voltage their rectifiers can handle on each rail or something? ^
        master hoarder
        • May 2008
        • 12175
        #323
        No, but the reverse voltage the PSU puts across the rectifier is much higher (usually at least 2 times the voltage of the rail on which the rectifier is on - i.e. 10V on the 5V rail, and 24V on the 12V rail). With high load, the voltage spikes can be even higher. Therefore, you need a rectifier that can withstand the high reverse voltage. A SBL2040PT can withstand up to 40V reverse voltage. The reverse voltage spikes on the 12V rail may actually jump that high in some cases under high PSU load.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          It's 30A. I'll look for a PSU where it can fit, I have a few 30A parts lyin around
          • tleu8472
            • Dec 2011
            • 36
            #325
            2theMax VP350R. Seems to have a complete transient filter stage. Pair of Capxon 680uF primaries. Tiny heatsinks though. Junk or a keeper?
            • Behemot
              • 4845
              • CZ
              #326
              Seems to be able to do like 300-350 W. But the input caps seem rather small for 680 uF to me.
              Just wanted to ask about this heatsinsk too. They have rather small area at first sight, but I think I can help it by bending the fins. On the other hand, it is thicker than the usuall thin crap with more fins. Do you think it will be better for cooling?
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                #327
                Bending the fins you can improve somewhat the air flux. Any improvement is always good.
                The thickness won´t help too much after the thing reachs a steady state of heat transfer. Good for transient variations, though.
                  Essentially* with fan cooled power supply thermal design, you don't care how thick your heatsink is, because when almost all of the cooling comes from the air flow, you just need more surface area. Bending the fins like that is essentially getting free extra surface area for the same metal cost, plus a little extra mechanical work, but nothing compared to making the heatsink bulkier.
                  *There's a lot of complex theory that I don't understand but essentially the thickness only helps with fanless (i.e. static) cooling. Obviously it will have a dissipating effect so will work regardless of airflow, but will have limited extra benefit when airflow is introduced. A thicker heatsink may also allow for greater transients as it has higher thermal capacitance (yes, there is such a thing as thermal capacitance, along with thermal resistance.) Greater thermal capacitance means the heatsink takes longer to reach a specific temperature. The energy eventually gets dissipated though, but over a longer period of time.
                  • Behemot
                    • 4845
                    • CZ
                    #329
                    Yeah but by bending it you improve heat trasfer into air by a great margin, and also the heat flows with smaller resistance into the fins.
                    On the thin heatsinks I believe the heat cannot even flow into the fins properly so they are cold all the time and the lower part with transistors and/or rectifiers is hot than.
                    • tleu8472
                      • Dec 2011
                      • 36
                      #330
                      Why does this PSU only have one toroidal coil in the secondary filter stage? I have typically seen two in most power supplies?
                        I guess it doesn't use a magamp for the 3.3V, but runs it directly off the transformer.
                        • Behemot
                          • 4845
                          • CZ
                          #332
                          What are the transistors and rectifiers inside? Seems like 13009 and some TO-220, if they are shottkies, than it's definitelly better than it seems on first look…
                          • rogfanther
                            • Jul 2006
                            • 458
                            • Brazil
                            #333
                            In the transfer of heat by convection, the flux is proportional to surface properties, area , and the fluid properties / speed of movement.
                            Bending the fins so that the fluid ( air ) can move freely over them improves the transfer from the aluminum surface to the air. Fins much close to each other "trap" hot air between them. The movement of heat inside of the fins won´t improve if they are bent ( could be decreased, as the corner would create a resistance, like in electricity ) .
                            As the transfer of heat by conduction ( inside the fins ) also depends of its transversal area, a too thin dissipator would also hamper heat transfer ( Q = k.A.DeltaT, where k is a coeficient that depends of the material, and A is the transversal area to the heat flux.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #334
                              Definitely a keeper!
                              • tleu8472
                                • Dec 2011
                                • 36
                                #335
                                Primary switcher is a ST P10NK60Z. I can only make out the 3.3v rectifier which is a MBR3045.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #336
                                  Lets keep it simple, nobody is interested in convection here, we are talking about fan-cooled PSUs. What I am talking about here is with this type of heatsinks, half of their surface almost does not get in contact with air, so it cannot transfer any heat to air, right? If you bent it, you make obstacle and slow down the air a little, on the other hand, transfer much more heat into it because you simple add surface area which was almost unusable before.
                                  One part of the area (lenght) is same in both cases, but the thickness can be double or even tripple. That means double or tripple heat conduction. Or otherwise, thinner heatsinks mean worse conduction, so, we can keep the fins cool (as they have big surface enough and we pump enough of air through it), but as long as heat couldn't be transferred so effectivelly from source (transistor/bridge), temeperature (delta T) on the hot end increases. Because the amount if heat (Q) is the same. (or, in reality, even higher the higher the delta T).
                                  So, what I am basically dealing with is, whether like twice or tripple the crosscut has higher impact on hot end than 50 % higher fin area. In reality, the crosscut may be much greater than 2-3times on thick heatsinks, because if you have seen latest crappy heatinks, the part with fins is made from 50% thinner material than the rest (where transistors/bridges are attached to)!!
                                  • rogfanther
                                    • Jul 2006
                                    • 458
                                    • Brazil
                                    #337
                                    Yes, we are saying the same thing in different ways. While the external area of the heatsink remains the same, with the fins alls grouped near themselves the air cannot move between them and take the heat away. Bending them so that air is free to move around and away of them improves heat transfer.
                                    The higher fin area has higher impact in the final heat transfer. The precise amount would need to be calculated.
                                      The weird thing is, there's a limit to the number of fins for optimal efficiency. It turns out that heatsinks wouldn't be best with a theoretically infinite number of fins - they'd work worse.
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        #339
                                        I'm interested in convection cooling!
                                        So thick heatsinks are ultimately the best for heat transfer in PSUs, like those found in older Hipros, Newton Powers, Liteons, and Deltas? I would think that thinner heatsinks would get hotter because while they do transfer heat they do not do so as effectively by way of more limited surface area, and as stated before me, too many fins isn't necessarily good. If anything else, though, I thought thicker heatsinks hugely help mediocre capacitors last much longer than usual, though well built voltage filter circuits and overbuilt rectifiers can do just that, along with fans that blow copious amounts of air. I also think vents on the side and large vents on the back and bottom help too....
                                        It's true though, I think, airflow from the fan helps worlds more than heatsinks do, that's why PSUs overheats and fail so hard when the fan fails, even components mounted to heatsinks...
                                        My only issue with thick heatsinks is that sometimes they might almost take "too much" space: so much so that other components not mounted to the heatsink or hidden under the thickness of it may not be as easy to cool. Not only that, but they might limit how much air is blown out of the case from the PSU fan. Given that PSUs are built in less space now adays, I can understand the move to thinner heatsinks but better airflow (120mm-140mm fans mounted on the bottom for more effectual cooling, though that's a problem for sleeve bearing fans). Ultimately, more or less, it's about increasing efficiency so less power and heat is "squandered" or "lost". The same reason why FSP have 80%+ efficient PSUs with unimpressive heatsinks.
                                        As for the PSU, I think one toroidal coil and two ferrite coils for the PI filter is fine: it's a transistor forward design so it's more effective. Remember that toroidal coils can get warm, and it seems there is a decent amount of coils on the primary.
                                        I've always wondered, though... how would a pair of 13009s (TO-220 or TO-3P/TO-247 as some of them are) compare to the rectifier shown (STP10NK60Z)? Especially since this is a forward rather than bridge PSU...
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          I have a PSU just like that (a 430W Thermaltake). That PSU actually uses DC-DC conversion from the 5V rail, which is why there is no separate toroid coil for the 3.3V rail. The part for it on the heat sink is a MOSFET.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
