the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
    master hoarder
    • May 2008
    • 12168
    #341
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by tom66
    I guess it doesn't use a magamp for the 3.3V, but runs it directly off the transformer.
    It's possible, but this is very rare. I've actually seen that only in a cheap CWT-built Cyberlink with a tiny EI-28 transformer.
    If you don't see a second choke on the secondary side, *most* of the time you can assume the 3.3V rail is regulated in with a MOSFET and a 431 shunt regulator.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      #342
      Originally posted by Wester547
      I'm interested in convection cooling!
      So thick heatsinks are ultimately the best for heat transfer in PSUs, like those found in older Hipros, Newton Powers, Liteons, and Deltas? I would think that thinner heatsinks would get hotter because while they do transfer heat they do not do so as effectively by way of more limited surface area, and as stated before me, too many fins isn't necessarily good. If anything else, though, I thought thicker heatsinks hugely help mediocre capacitors last much longer than usual, though well built voltage filter circuits and overbuilt rectifiers can do just that, along with fans that blow copious amounts of air. I also think vents on the side and large vents on the back and bottom help too....
      Thick heatsinks, along with a lot of area exposed to moving air, would be the best. But then you include engineering constraints, space, and mostly cost, and that has to be reduced.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        #343
        If 3.3v is generated from a MOSFET in PSUs that don't have a secondary coil (that is to say, there is only one toroidal coil on the secondary), does that mean...
        In a Hipro 300W that has only, say (mine):
        2x MBR3045PT in parallel (2x30A/OnSemi/TO-247)
        1x P40NF03L (STMicroelectronics/TO-220AB N-Channel StripFET Power MOSFET/40A/30V reverse voltage/0.020 ohm)
        1x MBR20100CT (1x20A/OnSemi/TO-220AB)
        Does that mean the P40NF03L is not the rectifier for the 3.3V rail but what it's generated from because of the lack of a secondary choke/coil and that it's only 1x30 for the 5V rail (rather than 2x30), 1x30 for the 3.3V rail, and 1x20 for the 12V rail (there's also a 7805 voltage regulator from STMicroelectronics for the -12V rail on another heatsink)? There are also four ferrite coils for the PI filters.
        • Behemot
          • 4845
          • CZ
          #344
          Isn't it DC-DC from, say, 12 V than?
            master hoarder
            • May 2008
            • 12168
            #345
            IDoes that mean the P40NF03L is not the rectifier for the 3.3V rail but what it's generated from because of the lack of a secondary choke/coil and that it's only 1x30 for the 5V rail (rather than 2x30), 1x30 for the 3.3V rail, and 1x20 for the 12V rail
            I'm not familiar with that 300W HiPro, but I have the 250W HP-P2507F3P and that is indeed the configuration I have (except that mine has a 40A rectifier on the 5V rail... IIRC).
            I don't think the 7805 is for the -12V rail, though. Most likely it's a 7912 (a -12V regulator) or if it really is a 7805, then it has to be for something else.
            There are 2 common ways to get the 3.3V rail with the MOSFET:
            1) Put a very strong rectifier for the 5V rail and use the rectified 5V rail to generate the 3.3V rail with the MOSFET.
            2) Have a separate rectifier for the 3.3V rail (the DC output is usually higher than 3.3V... more like 4V or maybe even higher), then a simple filter for it, and finally use a MOSFET to regulate it to 3.3V.
            My HiPro above is like 2). I also have a cheap Raidmax 380W PSU built by Sun Pro that uses 1). Both can be equally good methods if designed properly.
            Nope. At least not for the PSUs that use methods 1 and 2 above (those methods, however, do use the 12V rail to drive the MOSFET).
            I think I've seen some high-end PSUs that actually do DC-DC from the 12V rail for both the 5V and 3.3V rails.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              #346
              It's the HP-P3527F3 I posted a while ago. I want to know what it means for the 3.3V rail and 5V rail power wise at that point - there are two 30A TO-247 parts in parallel on one end and the 40A Power MOSFET/voltage regulator on another, and on the back of the heatsink a 20A part for the 12V rail. This PSU doesn't have a second choke on the secondary so 3.3V is generated from that 40A voltage regulator. Does this mean 30x1 for 3.3V and 5V? Or is it more complicated than that?
              • Behemot
                • 4845
                • CZ
                #347
                You don't really watch the market, do you guys? Basically all todays higher-end PSUs use DC-DC from single very powerfull 12V rail. How else would you achieve close to 90% efficiency, right (also note that blade servers and this stuff uses this for a long time - single higher-voltage rail with huge efficiency). Thats why it came to my mind in the first place, it would be only reasonable to find it in business class-PSUs (like most Hipro OEMs are)
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  #348
                  Well, note that my Hipro has a manufacture date of March of 2006 (and it's an old design since it has a -5V rail, which I think 7805/7905 is for judging by its position), and I'm sure momaka's is older than that...
                  I guess my question more simply is, do those MOSFETs/voltage regulator (in my case, a 40A/30V reverse voltage one) that generate 3.3V on PSUs that don't have a second choke on the secondary contribute at all to the amount of power the 3.3V rail can provide (assuming there are two other 30A 45V reverse voltage rectifiers very close to each other and one other 20A 100V reverse voltage one as in this case), or are they just there as a voltage regulator and even as a protection circuit of sorts?
                    master hoarder
                    • May 2008
                    • 12168
                    #349
                    Without underside pictures, I really can't say. But it's very likely either method 1 or 2 I mentioned above. If it's method 1, then the 2 rectifiers are in parallel and 3.3V rail is produced by the MOSFET regulating down the 5V rail to 3.3V. If method 2 (like my HiPro) then one rectifier is for 5V and other is for 3.3V.
                    Not a whole lot, no.
                    I did look at a JhonnyGuru review a few years ago and I remember how he pointed out that the PSU transformer didn't really have outputs for 5V and 3.3V rails but rather they were produced from the 12V rail via DC-DC buck regulator. And since it was VRMs, there were poly caps in there.
                    I wouldn't be surprised if in the future they come out with a PSU that produces a single powerful 24V rail that is then regulated down via DC-DC buck regulators for 12V, 5V, and 3.3V. Of course the -12V will still have to come out from it's own transformer winding.... unless they either remove the -12V from the ATX spec or the PSU manufacturers produce -12V rail with a capacitor-diode charge-pump circuit (like they do on the t-con of LCD monitors).
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      #350
                      3.3V can't be generated or regulated from/by any sort of PI filter coil (since it is an inductor and/or choke of the sort), can it, even if there's four of them (and if they're profuse in individual coils however small) and one toroidal coil (I know PI filter coils are noise suppressors)? And a power MOSFET transistor (or voltage regulator as some call them) can't be used as a rectifier, correct? ^^;
                        Heh, I'm still in favour of moving to 36/40V computers.
                        • Wester547
                          • Nov 2011
                          • 1268
                          • USA.
                          #352
                          This might sound dumb, but just to be sure, do PSUs that use the DC-DC from 5V method to generate 3.3V (via another MOSFET with no dedicated rectifier for the 3.3V rail) have separate filtering capacitors for the 3.3V and 5V rail or do they share the same set of capacitors? ^^;
                          • mariushm
                            • May 2011
                            • 3799
                            #353
                            It depends on the power supply.
                            Modern designs use DC-DC converters to generate 5v and 3.3v from 12v, this way the power supply can deliver almost all its rated power on 12v if needed and if the 3.3v and 5v are not used.
                            They're separate in the large majority of designs.
                            There were a few power supplies based on old designs that had a lot of current on 5v, sometimes even close to 35-40A on 5v - the companies adapted the design to use a dc-dc converter to generate 20-25A from that 5v. This gave them more room for 12v output.
                            It doesn't make these more efficient or better imho.
                            You still need capacitors for ripple filtering on all rails, no matter if you use dc-dc converters or not.
                              master hoarder
                              • May 2008
                              • 12168
                              #354
                              It can. On group-regulated power supplies with the 2 chokes on the secondary, you'll see a small 3rd choke *usually* between the secondary heat sink and the main transformer. This is what regulates the unrectified 5V rail down to about 3.3V.
                              A choke/inductor is simply a low-pass filter in a circuits that allows DC to pass and attenuates or completely removes AC (depending on inductor turns, core, etc). On the rectified (DC) side of a rail, it only removes noise and ripple. On the AC side, like that 3rd choke I mentioned, it can attenuate the AC to lower values. In the case of a power supply with 2 chokes, the 3rd choke attenuates the AC coming from the 5V pins on the main transformer and brings it down closer to 3.3V. This AC is then rectified into DC just like the other rails and you get 3.3V.
                              A MOSFET is a MOSFET. It can be used to regulate voltage but calling it a "voltage regulator" is not quite correct (it really depends on the circuit).
                              And no, a MOSFET can actually be used as a rectifier. PSU's that use MOSFETs instead of rectifiers are called "synchronous rectifier" PSUs. They are highly efficient. Many OEM laptop power adapters use this topology due to its efficiency. The PS3 power supplies also use that topology. That's why they are so small and don't require much cooling. A PS3 PSU is not even half the size on an ATX PSU, yet it can do 32A on the 12V rail (just shy of 400W) without much cooling or big heat sinks.
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                #355
                                ^ Very informative, and that's certainly more power than the 170W (14.2A) on my Xbox 360's 12V rail, a lead free, push-pull topology, 175W (total) PSU from Hipro. :P (it only otherwise has 1A on the 5VSB rail). That has a small fan internally, though. I still worry about capacitors in power bricks and AC adapters, though, since I know OEMs don't have the best choice of capacitors and I know they'd benefit highly from more airflow, IE a fan over them.
                                But... I don't understand how that 40A N-channel MOSFET transistor plays no role in providing power for the 3.3V rail in my Hipro, then... I understand it uses DC-DC conversion from the two 30A parts on the 5V rail but I don't understand why they'd place a 40A part as something to generate 3.3V from (rather I don't get why they just wouldn't use something smaller if it plays no part in giving 3.3V power in that method of generating/regulating it). As stated, there's one toroid coil and four PI filters on the secondary. I guess what I'm saying is, though 3.3V does not have its own rectifier but a regulator and DC-DC conversion from 5V, I don't get why it can't get any power from the power MOSFET regulating it even if it uses the 5V circuit totally to achieve the combined power. ^^;
                                • pdavid
                                  • Jan 2011
                                  • 279
                                  • Hungary
                                  #356
                                  I've looked into some brand new Kolink psus that came with oem cases. Amazing...
                                  One has no model number or anything the other is a Kolink CHS-450
                                  -no graetz bridge just four 2amp diodes
                                  -fake primary caps, real capacitance is 220uF
                                  -no brand 13007 switchers
                                  -2n60 fet for standy
                                  -fake, tiny el-33 trafo
                                  -label claims 5V-25A; 3.3-14A; 12-26A. Diodes are SB2045; SB1640; F1020
                                  -no pi filter, some secondary caps.
                                  -awg 20-22 wires
                                  Strangely one has some emi filtering and connectors instead just plain soldered wires.
                                  The pc cases are also horribly made, you can cut your fingers practically anywhere. The overall builld is paper thin mess.
                                  Avoid.
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    #357
                                    It's EI-33 not EL-33.
                                    One of the members here is a common victim of the reverse mistake.
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      #358
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #359
                                        At least it does not have diode treatment for +12 V. That's progress, no?
                                        • pdavid
                                          • Jan 2011
                                          • 279
                                          • Hungary
                                          #360
                                          Of course, that's the 26 amps right there! And to think one of my coworker has got one of these to save some cash...
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
