replacing schottky diodes on a AV power supply
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi guys, i have a power supply with a shorted SR320 schottky diodes which is in parallel. Only 1 shorted while another is ok. So i removed the faulty one, the power supply is working fine now. SR320 is 3A 20V. I was thinking can i remove both diodes and replace SR340 as 1 diode as it is 3A 40V? Because i dont have SR320. Or can i replace both with SR340?
    • 31294
    Re: replacing schottky diodes on a AV power supply
    neither, your going to need 6A at 20v, not 3A at 40v
    parallel diodes double the current, not the voltage
    if you check my Ryobi charger thread, i replace a couple of diodes with a 25A to220 package part
    • DjKrish
      • Oct 2012
      • 354
      • SG
      6A 20V, noted, will try that. Cause i fitted the 3A 40V diodes, no power at all. When i fit back the single 3A 20V, its working again.
        • 31294
        higher voltage is fine - infact with schottky's you really want 10x the running voltage.
        https://www.badcaps.net/forum/showthread.php?t=54038
          That does not make any sense.
          What exactly did you put in?
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Its a home theaters SMPS. I know, it doesn't makes any sense either. But i dont know, i took out the old one, put in 2 new SR340, power on, no power. Pull out again, put in the old SR320 diode, its working and i was like LOL
            • DjKrish
              • Oct 2012
              • 354
              • SG
              I tried the following.
              1 piece of SR340
              2 piece of SR340
              1 piece of SR320 and 1 piece of SR340
              None works. If i pull all and put only 1 piece of SR320, it works. Sighs
                What happen if you test the SR340 and compared to the SR320 with you meter?
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  SR320 - 15.33v
                  SR340 - 5.56v
                  No wonder theres no power when i put SR340. I wonder why
                    • 31294
                    i dont understand where you got the numbers,
                    test the diodes with your diode-test on the meter - both directions.
                    • DjKrish
                      • Oct 2012
                      • 354
                      • SG
                      test on V mode while power on.
                      while take off from board, these are the reading on diode mode
                      sr320 - 0.343v
                      sr340 - 0.164v
                        • 31294
                        the sr320 looks fucked for a schottky - thats far too much voltdrop
                        probably damaged - just not as much as the other one.
                        • petehall347
                          • Jan 2015
                          • 4450
                          • United Kingdom
                          both should be vf 0.55
                          https://cdn.badcaps-static.com/pdfs/...5f72338fd7.pdf
                            • 31294
                            that's at max current, they generally meter at about 0.18 on a meter
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Theoretically that's correct.
                              However, if the diodes are not built on the same physical die (as is the case here, where O/P has two separate diodes wired in parallel on the PCB), then one diode will run hotter than the other. When that happens, the forward voltage of the hotter diode will drop further, making the the circuit "prefer" to push more current through that diode, which will in turn heat up the diode even more. If this continues, thermal runaway may eventually kill the diode if the circuit has the capacity to push a sufficiently large current through it.
                              Because of that, I agree with what STJ suggested: use a single 6 Amp (or higher) diode/rectifier (and preferably Schottky type for lower losses.)
                              That's the maximum expected voltage drop at the rated current of the diode (3 Amps). Most multimeters push much much less than that when testing components (typically in the order of a few uA to maybe a fraction of a mA max.) As such, the Vf will appear much lower. Figure 3 in the above datasheet shows Vf for any given current from 0.1 Amps to rated surge current. You can see that for 0.1 Amps of current, the Vf is around 0.2V for SR320-340. So with a multimeter, the Vf should likely show even lower value... though depending on multimeter quality/design, that may not always be the case.
                              • DjKrish
                                • Oct 2012
                                • 354
                                • SG
                                This is the section. Output is 12V.
                                  So when you install SR340 you say you no longer get the switched B12V?
                                  When that happens, what Voltage do you get at the Cathode of SR340 with ref to circuit ground?
                                  Is switched B31V present when that happen?
                                  Can you also provide the full PDF of the service manual?
                                  • DjKrish
                                    • Oct 2012
                                    • 354
                                    • SG
                                    Heres the pdf file.
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      Sorry, heres the PDF file
                                      • DjKrish
                                        • Oct 2012
                                        • 354
                                        • SG
                                        SR340 - 5v plus
                                        SR320 - 12v plus
                                        B31V present
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
