RYOBI-one charger
    • 31250
    RYOBI-one charger
    these green things are shit, they die after less than 2 years.
    u-tube is full of people trying to fix them.
    (i fix them for good)
    the main problem is similar to the vestel psu's - parallel diodes.
    one shorts - blows the smd fet, damages the protection zener.
    • 31250
    Re: RYOBI-one charger
    so lets fix the bastards so they wont disrespect us again!
    replace the fet with IRFR5505PBF
    replace the diode with BZT55C18
    replace the 2 diodes with a single MBR40250G on a customised heatsink with an insulating kit.
    finish it with resoldering anything cracked, removing glue, and a full recap with FR,FC,YXJ and a BXW primary (instead of capxon)
      • Jul 2011
      • 6070
      So does it work as good as new
        • 31250
        it works better than new - it does not get hot over the diode(s) now.
        i replace a pair of 5A diodes with a 40A diode on a heatsink - you expect it to fail?
          • Jul 2011
          • 6070
          Thanks for posting this I have 5 of them charger and recapped three of them so far
          What was the problem with it
            • 31250
            problem is the 2 big diodes fail and blow stuff up - if you have that model with 2 big MBR5200 diodes, replace them with a big diode on a heatsink before one fails.
            i know there is another version of this charger with a single diode on a big heatsink that has other problems.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I have one of these. Build quality seemed OK externally. Good to know it isn't quite so good inside and I will keep an eye on it.
              • sulc
                • 9
                • EU
                I'm repairing same charger. It came to me with broken primary (diodes, mosfet, pwm ic, gate resistors) and shorted secondary diodes + mosfet. I have replaced all parts and now its pumping (secondary voltage rises to about 30V, then restart, red led blinks). For regulator mosfet i used:
                http://www.farnell.com/datasheets/19...648.1413390707
                Any ideas?
                  • 31250
                  voltage is over, did you check all the resistors etc?
                  also did you replace the zener across the fet?
                  the only other thing, i think there was a 431 voltage reference that may be bad.
                  • sulc
                    • 9
                    • EU
                    TL431 was replaced, all zeners are ok (not shorted). I also replaced optocoupler. Can somebody check primary gate resistors? I replaced both but i want to be sure they are correct..
                    • sulc
                      • 9
                      • EU
                      Some pictures...
                        • Jul 2011
                        • 6070
                        I am watching this post carefully i have a few of these changers
                        Please keep us informed thanks
                          • 31250
                          Originally posted by sulc
                          Tall zeners are ok (not shorted)
                          they may not be operating at the marked voltage.
                          you either need a zener tester of some kind, or just replace them.
                            • 31250
                            btw, you need to check every resistor around the switching controller.
                            when you blow that chip, some resistors get damaged.
                            and make sure your new heatsink isnt touching anything.
                            there is a reason i cut one side off mine!
                            • sulc
                              • 9
                              • EU
                              Anyone has values for SMD zeners?
                                • 31250
                                the only one that gets blown afaik is across the surface-mount fet, it's 18v.
                                i posted the datasheet
                                voltage is printed on them anyway.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8340
                                  nice fix stj!
                                  • sulc
                                    • 9
                                    • EU
                                    That one I replaced with right one just to be sure (old one has knee at about 18V when testing so it seems it was good).
                                    • simonmpoulton
                                      • Aug 2012
                                      • 12
                                      • united kingdom
                                      Got same problem with my charger - the mosfet looks like it blew up far worse than pictured. Have replaced mosfet, zener diode and the pair of diodes with MBR40250G. IC1 also looks burned however - does anyone know the part code for this?
                                      • R_J
                                        • Jun 2012
                                        • 9607
                                        Post a picture of it, it might be a SG6848, Is there a model number on the charger?
                                        • Dvsr
                                          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                          by Dvsr
                                          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                          After replacing the caps I started testing out the speaker. It seemed...
                                          09-10-2025, 10:20 AM
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
