Charger circuit to replace Alkaline D-Cells with NIMH AA cells
  • Ponchojack
    • Mar 2020
    • 15
    So here's the challenge...........
    I have a Grundig radio that uses SIX D-Cell alkaline batteries. A somewhat pricey affair to replace these things when they run out. I can't blame the radio, it sips power and the batteries last a long time. The unit also has a 9V wall wart adapter.
    What I want to do is replace the six D-cells with six AA rechargeables using those plastic battery adapters. I have no doubt it will work fine and the batteries will last a respectable amount of time.
    I guess I could take the AA batteries out and put them in a charger when they run down, but what would be the fun in that?
    No, I want to have the unit recharge the batteries while the 9V adapter is plugged in. Even one better, use a 12V source or adapter.
    The challenge is what circuit is required to do this correctly?
    Any takers out there for this challenge?
    Poncho
  • Ponchojack
    • Mar 2020
    • 15
    Re: Charger circuit to replace Alkaline D-Cells with NIMH AA cells
    A first thought.....what about using this smart charger? https://www.banggood.com/Black-Ni-MH...p-1640958.html
    Then rewire the EXT power plug in the radio with zener diode to limit voltage to the radio circuitry while the adapter is plugged in charging the batteries.
    Will this work?
      • 31248
      your first issue, will the radio run o.k. at 7.2v
      because 6x1.5 = 9v but 6x1.2 = 7.2v
        • 31248
        another option is to use a couple of 18650's with a BMS board and a TP5100 charger board to recharge them from 9-20v input
          • Jul 2011
          • 6070
          To me this would be a better option
          Than this
          Will this work?
          Here is the reason why I have not had very good success use this type of charge
          First problem is that if want a charge indicator ( LED light ) it messes with the circuit sometimes it does not matter that use one is used or not the charge curve are shit with this type of chargers to being with any way
            • 31248
            this is reasonable,
            it will charge in 10 hours with ikea 2400ma AA's from a usb cable!
            https://www.banggood.com/1-8S-1_2V-9...p-1625308.html
              The bad part of trying to charge batteries connected series, you can have bad cell, I.E. shorted cell or open cell, and not all the cell will have the same cell Voltage.
              I would try with 18650 and TP4056 with protection feeding a boost converter.
              http://www.icstation.com/5pcs-micro-...e-p-12734.html
              But you will have to watch out if those converter may cause interference issue with radio reception.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                had lots of devices using packs of NiMH/NiCd/Pb in series back in the day and nobody complained...
                  • 31248
                  nobody complained till they leaked anyway!
                  having said that, even after about a decade, nobody on any forum has seen an eneloop leak!!
                  • Ponchojack
                    • Mar 2020
                    • 15
                    Thanks guys fro the quick replies. On the 1.2 vs 15 volt issue. This should not be an issue. Most devices are designed to handle it since traditional D-cells will drop from 1.25 to 1.0 volts over their lifetime. The device is typically designed for the 1.2 volts. NimH tend to frun flat for most of their power curve.
                    I'm assuming the the 18650 idea would use 3 cells with buck regulator?
                    I would need to look into the charger. Also not sure how to do the physical fit. The nice part of AA batteries, they make cheap converters to fit. The batteries are easily removed for checking or replacement if one goes south. I've not had to deal with isolation issues before, will the idea of a Zener diode work?
                    • Ponchojack
                      • Mar 2020
                      • 15
                      The TP5100 idea is interesting especially if the radio will run on 2 18650 cells. I'll have to hook it up to my PS and see hoe well it works at 8.4 volts
                        • 31248
                        7.2v, not 8.4
                        8.4 is fully charged, 7.2 is average.
                        and 5-6 is considered depleted.
                          • 31248
                          i was thinking 2 cells in series for 7.2v directly connected with a bms/protection board, and disconnected via the switch in the power-jack when charging (via an internal TP5100 board between the jack and bms)
                          • Ponchojack
                            • Mar 2020
                            • 15
                            Stj, thanks for the good idea. I'm going to try it. I'll let you guys know how it goes.
                            Poncho
                              • Jul 2011
                              • 6070
                              One option would be to use 18650 batteries that have a buck converter built in them but they are a little pricey but you do get decent run time out of them but you would need the adapter change them from AA batteries to D size
                                • 31248
                                NOOOooooooo...
                                any buck/boost convertor in a radio will trash the reception!
                                • dbuergi
                                  DIY: Modified smart charger for all types of batteries
                                  by dbuergi
                                  sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                  Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                  My first work was to bring my Samsung watch battery back to life with was not recognized...
                                  07-18-2025, 03:17 AM
                                • carrzkiss
                                  Cyberpower cps1500avr not charging batteries
                                  by carrzkiss
                                  Hello, all.
                                  Cyberpower Battery Backup Unit.
                                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                  Checking the voltage, it was down to 22v.
                                  I quickly removed everything...
                                  06-15-2024, 02:10 PM
                                • flat-earther
                                  how to prevent a connected charger from draining battery when not charging?
                                  by flat-earther
                                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                  So the battery is backfeeding the charger and being drained.
                                  How can I prevent...
                                  08-07-2025, 01:04 PM
                                • xeejem
                                  NIMH quick charger no power
                                  by xeejem
                                  Hope everyone is doing well here. I have been troubleshooting on why my charger isn't giving any charge. At the TNY IC, I did a volt test on pin 2 with closest capacitor ground lead and it is giving 0 volt. Pin 4 and ground is giving around 2v. The capacitor is getting 160v from what I can tell. Those big diodes are tested on board. I don't find any shorts. Do you know how else I can find the culprit? Please bare with my lack of skills....
                                  08-29-2024, 04:54 PM
                                • Johndill
                                  Dell Inspiron 7567 LA-D993P odd charger issue
                                  by Johndill
                                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                  Here are the tested scenarios:
                                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                                  11-16-2022, 10:55 PM
