NIMH quick charger no power
  • xeejem
    • Aug 2024
    Hope everyone is doing well here. I have been troubleshooting on why my charger isn't giving any charge. At the TNY IC, I did a volt test on pin 2 with closest capacitor ground lead and it is giving 0 volt. Pin 4 and ground is giving around 2v. The capacitor is getting 160v from what I can tell. Those big diodes are tested on board. I don't find any shorts. Do you know how else I can find the culprit? Please bare with my lack of skills.
    • Jul 2011
    • 6070
    The “TYN” ic chips have a very high failure rate so I would recommend replacing and replacing the capacitor next to the switching power supply transformer and next to TYN ic chip
    • R_J
      • Jun 2012
      • 9623
      The TNY277 is very likely bad, and L1 coil is likely open as well, also change C4. C2 doesn't look that good in the picture so I might just change C1, C2 & C4
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
