Tecnoware FAL501FS12 does not turn on
  • falcontech
    • Oct 2013
    • 470
    • italy
    #81
    Re: Tecnoware FAL501FS12 does not turn on
    Yes ok
    • CapLeaker
      Leaking Member
      • 8133
      check Q3 and Q4 plus the components in that area
      • falcontech
        • Oct 2013
        • 470
        • italy
        #83
        Ok thank you
        • CapLeaker
          Leaking Member
          • 8133
          basically pin 8 and 13 are driving Q3 and Q4. Then it goes through tranformer t2 and drive the big transistors Q1 and Q2. It continues through transformer T1 and then all gets rectified on the secondary (low voltage side).
          • falcontech
            • Oct 2013
            • 470
            • italy
            #85
            ok thanks tomorrow i try
            • falcontech
              • Oct 2013
              • 470
              • italy
              #86
              I looked at the circuit, q3 and q4 are the transistors that I have already replaced so they are new I saw that nearby there are capacitors that I have already replaced and diodes but they are all good, the visible resistances are good
              • CapLeaker
                Leaking Member
                • 8133
                r11 and r12 are good too? check the winding on the transformer and if all checks out ok, we have to go to the next stage.
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #88
                  please if you can tell me what these resistances are on my photo, I have a little trouble understanding that scheme thanks
                  • CapLeaker
                    Leaking Member
                    • 8133
                    check again Vcc on pin 12 on the KA7500, and then measure each voltage rail, while turning the PSU on and off again on each rail. I am looking to see if the PSU actually tries to come on but is getting held back or something is open. I am looking for minimal voltages on any of the output rails -12V, +12V, -5V, +5V and 3.3V.
                    • falcontech
                      • Oct 2013
                      • 470
                      • italy
                      #90
                      ok tomorrow i will try what you asked me now i am not in front of the psu
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #91
                        I did the tests you asked me, I have no output voltage except for the 5v standby, nothing on -12 +12 -5 +5 +3.3, on pin 12 I always have about 16.50, I have a equal power supply working and I saw that on pin 12 we have more than 18 volts
                        • falcontech
                          • Oct 2013
                          • 470
                          • italy
                          #92
                          In a while I try to invert the two heatsinks with all the components even if they don't give me any short problem. I also eliminate this doubt.
                          • CapLeaker
                            Leaking Member
                            • 8133
                            those 18V on pin 12... is with the PSU on. What do you get with the PSU off?
                            • falcontech
                              • Oct 2013
                              • 470
                              • italy
                              #94
                              Hi Caps I solved, it was those two resistances that I highlighted on the photo, looking at the working power supply I noticed that they were different, someone before me had replaced them by mistaking the value ... all ok thanks now I have to repair another one, there we hear on another thread THANK YOU
                              • CapLeaker
                                Leaking Member
                                • 8133
                                Very good find! We would not be able to find it, like you did. It's always harder to repair something that someone else had worked on before. You are getting good at it and soon be helping rather asking for help!
                                • falcontech
                                  • Oct 2013
                                  • 470
                                  • italy
                                  #96
                                  thanks my friend to you for your patience, however I opened another thread for another atx more or less the same, I explained them all the tests already done, I'll wait for your valuable advice
                                  • PNI E.
                                    Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                    by PNI E.
                                    Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                    03-17-2025, 04:23 AM
                                  • madsox
                                    Harman Kardon AVR 171S - standby led lights up, does not turn on
                                    by madsox
                                    Greetings!
                                    Thank you in advance for your understanding, I am writing to you through a translator.
                                    A Harman Kardon AVR171S amplifier was given.
                                    The history of the machine is as follows:
                                    It was faulty when I bought it, I want to fix it.
                                    I replaced the HDMI switch and one of the DAC ICs in it.
                                    After that it worked without a problem.
                                    I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                    The cooling was faulty, I will fix this later.
                                    I switched it to standby mode, waited for...
                                    09-24-2022, 10:46 AM
                                  • pajdek
                                    Lenovo Y700-17ISK turn on and off
                                    by pajdek
                                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                    09-20-2023, 02:49 AM
                                  • Doodle43
                                    Samsung LN32B540 - won’t turn on but gets standby power
                                    by Doodle43
                                    My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                    It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                    05-26-2020, 12:02 PM
                                  • Adenitz
                                    Troubleshooting Vestel TV, has standby, but cannot turn ON
                                    by Adenitz
                                    I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                    Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                    Both boards are shown in the attached photos.
                                    What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                    12-27-2023, 03:43 AM
