Tecnoware FAL501FS12 does not turn on
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8330
    Re: Tecnoware FAL501FS12 does not turn on
    I guess that mystery is solved now.
    • falcontech
      • Oct 2013
      • 477
      • italy
      #42
      Hi
      I changed the resistances, now the voltage on the large capacitors has stabilized, but the power supply still does not start, I try to change some capacitors and I update you
      • falcontech
        • Oct 2013
        • 477
        • italy
        #43
        I replaced all the capacitors, even the small ones under the heatsinks, except one under the heatsink of the secondary that I did not have (220uf 50V) but still not showing signs of life, I checked the schotty diodes and they are good no signs of short, I have always and only 5v standby, what do i do?
        • falcontech
          • Oct 2013
          • 477
          • italy
          #44
          on pin 12 of the KA7500 I have 16.5 volts
          • R_J
            • Jun 2012
            • 9592
            Pin# 12 (vcc) is supplied by the standby transformer, Check the voltage on the driver transformer (arrowed) Also check the voltage on the two transistor bases.
            What is the number on the other ic in the secondary?
            Use the Secondary Ground to check all voltages on the secondary side (black probe on ground)
            This schematic might be close.
            • falcontech
              • Oct 2013
              • 477
              • italy
              #46
              ok, I have to put the black tip on the mass and test with the red one the points you have indicated to me? if I'm not mistaken the second ic is lm339n for safety in a while I look
              • falcontech
                • Oct 2013
                • 477
                • italy
                #47
                I don't understand what the secondary ground is
                • R_J
                  • Jun 2012
                  • 9592
                  You don't understand the difference between the primary side of the power supply and the secondary?
                  The primary side is connected to the mains high voltage and could be deadly if you don't know what you are doing.
                  • falcontech
                    • Oct 2013
                    • 477
                    • italy
                    #49
                    absolutely, you did not understand me, I know that well, I want to understand how to manage the tester's test leads on the indications you gave me, as I asked you, should I put the black test lead on the mass and with the red test test the points indicated on the photo? it's a test I've never done
                    • falcontech
                      • Oct 2013
                      • 477
                      • italy
                      #50
                      See the picture
                      • R_J
                        • Jun 2012
                        • 9592
                        Yes this is correct placement of the probes, The schematic in post#45 should be closer to your power supply
                        • falcontech
                          • Oct 2013
                          • 477
                          • italy
                          #52
                          ok,If it can be useful, the second ics is an lm339ld
                          • falcontech
                            • Oct 2013
                            • 477
                            • italy
                            #53
                            Then with the power supply in standby the voltages are these
                            Driver transformer (yellow arrow) 1,50v
                            B 2.25v
                            E 1.50v
                            B 2,25v
                            With the power supply running
                            Driver Transformer (Yellow arrow) 1,85v
                            B 1.50v
                            E 1.47v
                            B 1.52v
                            • falcontech
                              • Oct 2013
                              • 477
                              • italy
                              #54
                              what should i check now?
                              • R_J
                                • Jun 2012
                                • 9592
                                That voltage for the driver transformer (arrow) is low, look at the schematic (R12 2.7k) and follow the line on your board, it should have 16v on one side of that resistor. Also check the 2 transistors and the diodes connected to that drive transformer.
                                • falcontech
                                  • Oct 2013
                                  • 477
                                  • italy
                                  #56
                                  Transistors and resistors on the secondary or primary? forgive me but on that scheme I understand very little because it is not structured like my atx, sorry and have patience thanks, if you want I send you a photo without heatsinks
                                  • R_J
                                    • Jun 2012
                                    • 9592
                                    A picture without the heatsink would help, The transistors to check are on the secondary (I marked the emitters with a E, and the base with a B and the collectors with a C. The transformer on your board (under the yellow arrow) is T2 on the schematic.
                                    This part of the schematic is closer to your board than you can see.
                                    • falcontech
                                      • Oct 2013
                                      • 477
                                      • italy
                                      #58
                                      Okay, now I'll send you a photo without heatsinks
                                      • falcontech
                                        • Oct 2013
                                        • 477
                                        • italy
                                        #59
                                        here she is
                                        to the eye it does not seem to me that there are open resistances
                                        • falcontech
                                          • Oct 2013
                                          • 477
                                          • italy
                                          #60
                                          I checked the diodes and they are good, the resistances are good too, the transistors are c945, I tried the first one and I have the same value on E and C (i.e. about 618), on the other I noticed a strange thing about C gives me 618 on E 360, what do you say?
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • madsox
                                            Harman Kardon AVR 171S - standby led lights up, does not turn on
                                            by madsox
                                            Greetings!
                                            Thank you in advance for your understanding, I am writing to you through a translator.
                                            A Harman Kardon AVR171S amplifier was given.
                                            The history of the machine is as follows:
                                            It was faulty when I bought it, I want to fix it.
                                            I replaced the HDMI switch and one of the DAC ICs in it.
                                            After that it worked without a problem.
                                            I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                            The cooling was faulty, I will fix this later.
                                            I switched it to standby mode, waited for...
                                            09-24-2022, 10:46 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Adenitz
                                            Troubleshooting Vestel TV, has standby, but cannot turn ON
                                            by Adenitz
                                            I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                            Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                            Both boards are shown in the attached photos.
                                            What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                            12-27-2023, 03:43 AM
                                          • Doodle43
                                            Samsung LN32B540 - won’t turn on but gets standby power
                                            by Doodle43
                                            My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                            It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                            05-26-2020, 12:02 PM
