Tecnoware FAL501FS12 does not turn on
  • falcontech
    • Oct 2013
    • 477
    • italy
    #61
    Re: Tecnoware FAL501FS12 does not turn on
    can you tell me if this transistor can be problematic?
    • R_J
      • Jun 2012
      • 9592
      I do not know if there is a problem with the transistors, If they were shorted they usually burn the 10Ω (next to the driver transformer) or the 1.5K (next to the small diode near the white plug and fuse)
      The KA7500 has vcc but also needs to be turned on, If it is turned on and working, it will output drive waveforms to the two small transistors connected to the T2, these small transistors drive T2 which drives the two primary transistors.
      • falcontech
        • Oct 2013
        • 477
        • italy
        #63
        so what do I do? of course I try to change them, if that is not the problem how do I proceed?
        • R_J
          • Jun 2012
          • 9592
          Change what? the transistors? the ic? Have you tried reinstalling ALL the parts and see if the power supply works? The power supply might not try to turn on because it does not see any voltage on the +12v or +5v supplies.
          While you have the main primary transistors removed I would change those 2 small electrolytic caps near Q7 and Q8 They are the same ones listed on the schematic as C7 and C6or8? (10µf/50v)
          • falcontech
            • Oct 2013
            • 477
            • italy
            #65
            of course I tried, every time I change some component I put everything back and try again, I am making attempts, otherwise I was not here to ask you for help, my knowledge stops at bad capacitors and burnt schotty mosfets and diodes, at the bridge rectifier, in short those common things, since I can't go further I'm asking for help, maybe my culture on switching power supplies will be wider
            • falcontech
              • Oct 2013
              • 477
              • italy
              #66
              already done, the capacitors have all been changed, they are all new, later I try to change the npn transistors, if it doesn't work it could be one of the ics?
              • R_J
                • Jun 2012
                • 9592
                Do you get any voltage on the +5 or +12 (even 1or2v) when you turn on the power supply?
                There is 16 volts on the KA7500 pin 12 which is good. There should also be part of that voltage (10~12v) going to the drive transformer, I traced the path so can you check the small diode next to the 1.5k and the 1.5k and the 100Ω (in green square) I also marked the schematic
                • falcontech
                  • Oct 2013
                  • 477
                  • italy
                  #68
                  no, I don't have a minimum voltage in the outputs even on the 3.3v ... then summing up, I have to check the goodness of those components that you reported to me and see if I have 12v on that yellow track? sorry if I ask you but I'm using the translator and it's not always clear
                  • R_J
                    • Jun 2012
                    • 9592
                    Is there any other voltage on the KA7500? I know pin 12 has 16 volts but what about the other pins?
                    • falcontech
                      • Oct 2013
                      • 477
                      • italy
                      #70
                      I only checked pin 12 as it was recommended to me, what other pins should I check?
                      • falcontech
                        • Oct 2013
                        • 477
                        • italy
                        #71
                        about post # 68 you didn't reply to me if I understood what to do or not
                        • R_J
                          • Jun 2012
                          • 9592
                          I only asked if there was a small amount of voltage on the 12 volt line to see if the power supply tried to start and maybe shut down. It is not that important now.
                          It is important to have voltage on the drive transformer. That voltage supplies the collectors of the two 2sc945.
                          On the KA7500, check pins 16 and 15
                          • falcontech
                            • Oct 2013
                            • 477
                            • italy
                            #73
                            ok in a while I reassemble everything and check, I want to change the two transistors now that I have disassembled them and there is one that does not convince me
                            • falcontech
                              • Oct 2013
                              • 477
                              • italy
                              #74
                              I reassembled everything, I replaced the transistors but did not want to know how to turn on, on pin 15 we have 4.99 volts on pin 16 2.80 volts
                              • falcontech
                                • Oct 2013
                                • 477
                                • italy
                                #75
                                I have practically changed all the components, it is driving me crazy
                                • falcontech
                                  • Oct 2013
                                  • 477
                                  • italy
                                  #76
                                  but now on the transformer I have 6.50 volts when it is on, 1.50 volts in standby
                                  • R_J
                                    • Jun 2012
                                    • 9592
                                    That is good, It could be that the KA7500 was damaged when the transistor failed.
                                    Do you see any voltage on the +12 or the +5 when you first turn on the power supply?
                                    • falcontech
                                      • Oct 2013
                                      • 477
                                      • italy
                                      #78
                                      no, I don't see anything but nothing, there is no shadow of tension, I tried to replace the ka7500 with a tl494 taken from a working power supply but nothing does not start, could it be lm339?
                                      • falcontech
                                        • Oct 2013
                                        • 477
                                        • italy
                                        #79
                                        i tried to change also lm339 nothing moves, tell me what i can try now it has truly become a mystery
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8330
                                          maybe mark on the picture or schematic what you changed. Just by trying to catch up on this thread it makes my head spin!
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • madsox
                                            Harman Kardon AVR 171S - standby led lights up, does not turn on
                                            by madsox
                                            Greetings!
                                            Thank you in advance for your understanding, I am writing to you through a translator.
                                            A Harman Kardon AVR171S amplifier was given.
                                            The history of the machine is as follows:
                                            It was faulty when I bought it, I want to fix it.
                                            I replaced the HDMI switch and one of the DAC ICs in it.
                                            After that it worked without a problem.
                                            I watched a movie using the amplifier, and at the end the amplifier got really hot.
                                            The cooling was faulty, I will fix this later.
                                            I switched it to standby mode, waited for...
                                            09-24-2022, 10:46 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Adenitz
                                            Troubleshooting Vestel TV, has standby, but cannot turn ON
                                            by Adenitz
                                            I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                            Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                            Both boards are shown in the attached photos.
                                            What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                            12-27-2023, 03:43 AM
                                          • Doodle43
                                            Samsung LN32B540 - won’t turn on but gets standby power
                                            by Doodle43
                                            My Samsung LN32B540 never turned back on after I had to turn off the power at the mains at house. It won't turn on, but the red standby led lights up when it is plugged in. If I hold down the power on the remote, the standby light turns off which I think means it is trying to turn on, but there's no sound or backlight. If I try to turn it on/off from the power button on the TV instead, it doesn't do anything at all.
                                            It was plugged into a surge suppressor and was off (on standby) when I turned off the power,, so I don't know if it got a power surge or was on its way out anyway. I...
                                            05-26-2020, 12:02 PM
