Re: APC Smart-UPS float voltage experiment
Personally, I think the perfect float voltage is 27.27 volts. It should be high enough to stay out of the sulphation issue and gentle enough to make the batteries last a long time.
I have a SU300NET and added a potentiometer as a replacement to the R118 resistor so that I could adjust the voltage with a screwdriver. The original batteries were more then 2 litres low on electrolyte due to an improperly high float voltage (just short of 28 volts).
While you're in there be sure to check out R38 & R43 - it's really common for those resistors to fry, fry and fry. The OEM spec for them is 1/4 watt 470 ohm but most folks replace them with 1/2 watt units as a means of future-proofing
Much thanks for posting up your piece here - it got me started on this quest as I have a mint SU3000 and I just bought new batteries and want to see them last many years
