Powering up a Car Antenna a "different" way
  • Welchs101
    • Sep 2008
    • 979
    Hi, I have a friend who has this car antenna and he uses it to open / close his chicken coop. Anway, the operation of the antenna which ihave included pictures of below works in the following way:
    Using a 9V batter to make antenna "function":
    1)Attach black wire to negative terminal of 9v battery
    2)Attach red wire to positive terminal of 9v battery
    3)take green wire and touch positive terminal of battery. When you touch green to positive the antenna "goes up". If i remove the green wire from positive lead antenna comes down.
    My friend wants this operation to change. Instead of going up he wants the antenna to come down when i touch green to positive terminal.
  • R_J
    • 9549
    Re: Powering up a Car Antenna a "different" way
    You can try reversing the wires on the motor, that might work, it is just a simple relay that drives the motor but there will also be upper and lower limit switches and they may have diodes across them which might need to be reversed also.
    The limit switches are needed to stop the motor from running once the antenna has reached the inner or outer limit.
    • Welchs101
      • Sep 2008
      • 979
      Question1: What is the "thing" on the printed circuit board that is a rectangular greyish like box?
      Question2: Why is it that when the green wire is "removed" from the + voltage of the battery that the antenna has "power" to move?
        • 31044
        box is a relay, a magnetic switch.
        the relay reverses the motor wiring to change direction, and the motor stops at the ends because of limit switches.
        • R_J
          • 9549
          There are likely diodes across the limit switches so when a limt is reached the switch opens the circuit to the motor, so to enable the motor to operate when the voltage is reveresed, a diode is placed across the limit switch, this allows the reverse voltage to run the motor untill the switch closes. There will be two limit switches so you would need to reverese the diode dirction on both switches.
          You can't just reverese the motor connections because of the diodes across the limit switches.
          • Welchs101
            • Sep 2008
            • 979
            where do you think the diodes might be? all i see is this thing (see picture)
            • R_J
              • 9549
              They would be across the switch contacts. if they are not used it may not be as simple as reversing the motor wires.
              • Welchs101
                • Sep 2008
                • 979
                i cant find any diodes any where. I did try flipping the wires to the motor but this did not seem to work.
                also, i noticed that the "gold" circular thingy in my previous post turns every so often when the antenna is going "out/up". Once fully up it stops turning. When i remove power from the green wire gold thingy turns more and then finally stops. I some how thing its this gold thingy that is "switching" the voltage but i am not sure how.
                anyone know how this thing is supposed to work?
                • R_J
                  • 9549
                  The gold thing is the switch, it is a rotary switch. Because of the gear setup, simply reversing the motor won't work because it will try and run against the mechanical end of the travel.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    post a pic of relay wiring .
                      • Jul 2011
                      • 6040
                      Try this unsolder the motor leads and see if the motor will run in both directions BUT do NOT let it run very long because you might damage the gearbox if it was not meant to run backwards
                      • R_J
                        • 9549
                        It would seem the only reason for switching the direction would be because when the green wire has power applied, the antenna is extended and the relay is energized and drawing current.
                        You might be able to reverse the power leads going to the board, that should cause the antenna to extend when power is applied and stop at the extended limit, Then to retract the antenna all you need to do is connect the green wire to the negative of the battery which will energize the relay.
                        • Retro-Hipster
                          Tinkerer
                          • Apr 2019
                          • 125
                          Hmmm..... From what I could trace visually Sir, if you reversed the red and black wires, you would then need to touch the green wire to the NEGATIVE of the battery. Give that a shot. You may want to check the relay model and just verify that the datasheet doesn't show any diodes in the package first though. You'd normally expect a diode across a relay, so it's wierd that there don't appear to be any on that board. It might be internal on that relay...
                          “Men always seem to think about their
                          past before they die, as though they were
                          frantically searching for proof that they
                          truly lived.”
                          – Jet (Cowboy Bebop) -
                          • redwire
                            • 3910
                            The limit switch is what latches power and keeps the motor running until it reaches an endstop. Not SPDT but it shorts the two ends until an endpoint. No need for diodes then.
                            Schematic might look like this, I assume a PTC is stashed in there too.
                            • Welchs101
                              • Sep 2008
                              • 979
                              switched red and black keeping black wire on negative terminal and red on positive terminal. touching green wire to negative terminal does make motor turn to "lower" the antenna. However, when i remove green wire motor does not turn to "raise" antenna.
                              Also, redwire can you explain the picutre you sent. Not sure i understand it.
                                • Jul 2011
                                • 6040
                                If your drawing is correct then that would explain what you are seeking
                                you would have to run the motor to end of travel before you can get it to travel in other direction to change the status of the limit switch
                                • redwire
                                  • 3910
                                  With nothing to the relay coil (green), see the diagram- it shows power can flow to the motor until the antenna-down limit-switch upper contact opens and disconnects the motor power.
                                  With the limit-switch now at one end (its upper contact open and lower one closed), the only way the motor can get power is if the relay is pulled in (with power on green wire). This gives reverse polarity power to the motor, so the antenna can go up.
                                  If power to the relay (green wire) is removed too soon, i.e. the antenna only made it half way up, the motor reverses and continues to move the antenna down.
                                  So the green wire seems to be an "antenna up" wire that needs power for the whole time the motor is going up. The limit-switch always disconnects power to the motor at either end.
                                  You want to flip this "My friend wants this operation to change. Instead of going up he wants the antenna to come down when i touch green to positive terminal. "
                                  You'd have to rewire the relay contacts so defaults to moving the antenna up, not down. I'll have to draw it later but I think 4-wires to move - swapping the NC and NO connections?
                                  • Welchs101
                                    • Sep 2008
                                    • 979
                                    hi redwire, i dont totally understand but i need to read you explanation a few more times with the picture in front of me.......one qustion i do have is what for wires need to move and where move them to? i can take another picture of the relay and motor if this helps.
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      i am enclosing the front and back views of the antenna showing how the wires are connected.
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        Really sorry but i guess i just dont understand the drawing. For example, com1 and com2. They are switches and they appear to be somehow involved/connected with the blue dotted line........what does this mean?
                                        What are N/C and N/O?
                                        • Zibbo
                                          Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
                                          by Zibbo
                                          Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
                                          Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
                                          12-27-2024, 12:20 AM
                                        • Hondaman
                                          Single-channel antenna?
                                          by Hondaman
                                          Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
                                          I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
                                          Years ago I made a "T"...
                                          11-18-2024, 01:14 AM
                                        • Chaks
                                          Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                                          by Chaks
                                          TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                                          The specs says ...
                                          High antenna efficiency 868MHz ISM Band
                                          5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                                          The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                                          1. Should I Fix it with a glue.
                                          2. Should I fix it with a double side adhesive tape
                                          3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                                          12-09-2024, 11:06 AM
                                        • SolomonMan
                                          Antenna...
                                          by SolomonMan
                                          All,
                                          I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
                                          There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
                                          Since we moved in, 8 years ago,...
                                          10-05-2023, 02:37 PM
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
