Antec AR300 psu, loud squeal, no power
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Antec AR300 psu, loud squeal, no power
    10v 1w zener.
    • Sylvester
      • Nov 2006
      • 67
      I've now got the caps and hopefully the correct zener, the pads are loose due to the heat, the red line shows where the pad connects to, what's the best way to mount this diode? I don't think it would be very stable if mounted as it was originally, so I was thinking of mounting it on the bottom of the pcb, there's just enough clearance to do this. The other pad in yellow is easily soldered to the leg next to it for strength (both common)
      Originally Posted by Harvey
      that's assuming you can guess the value of R29
      Yes its appears to be damaged as well, any ideas?
      There's also one other problem of space, the 4700uF 6.3v EEUFM0J472L I got is slightly larger in diameter and is will be hard up against a heatsink.
      • lucky13
        • Aug 2007
        • 412
        I suppose you can strip off some wire insulation and dress it on the zener diode leads and solder it on the solder side.
        Use meter to check for shorts before power up.
        And check operation w/o mobo or anything of value just in case....
        • Sylvester
          • Nov 2006
          • 67
          Think my biggest problem is R29's value.
          • lucky13
            • Aug 2007
            • 412
            Yep, that R29 is going to be a problem.
            Can you do a macro shot of it?
            You should also post a pix of the Antec label here. In case someone come axross this post, they can compare their label against yours to see if there is a match.
            Then, they still need to open it up and look at the solder side if they are into recapping.
            Just come in and bump the post once in awhile to attact attention.
            • Sylvester
              • Nov 2006
              • 67
              I think I can blow the R29 picture up a bit more.
              The psu did do some damage to the mobo after all, it took out the sound chip.
              • Brian C
                • Dec 2006
                • 156
                #27
                You may try to draw the schematic and figure out the resistor value.
                • PSUtech
                  2ManyHobbies
                  I know this an old thread but if any one needs this info:
                  CWT-300TLP REV B
                  EC11 4700UF 6.3V 10X30MM FUHJYYU
                  EC6 EC7 1000UF 10V 8X15MM TEAPO
                  EC12 3300UF 6.3V 10X20MM TEAPO
                  EC18 1000UF 16V 10X20MM FUHJYYU
                  EC15 EC16 2200UF 10V 10X20MM KOSHIN
                  EC17 330UF 16V 6.2X13MM KOSHIN
                  EC14 470UF 16V 8X15MM FUHJYYU
                  EC13 330UF 25V 8X15MM FUHJYYU
                  EC3 22UF 50V 5X10MM FUHJYYU
                  EC4 100UF 50V 8X13MM TEAPO
                  R29 5.6 OHM 1206
                  ZD4 1N4746 18V 1W ZENER
                  U11 7912CV -12V LINEAR REGULATOR
                  I just got in a bunch of these in with problems so if anyone needs other part values let me know
                  • ukvince
                    Learning
                    • Jun 2011
                    • 31
                    #29
                    PSUtech ...
                    That info is very useful .... thank you for taking the time to post it.
                    • need_info
                      • Mar 2020
                      • 9
                      Here we are a few years later and AR300 power supplies still need help. I am rebuilding one and need help in identifying the value of SMD capacitor C18. The cap is open and since they are "unmarked", well I am stuck. I am hoping someone still has a working supply that they can measure C18's value. I know it is somewhat of a big ask; and I wouldn't if I could find another way to get the value. Jon
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        #31
                        Hi Jon and welcome to BCN!
                        Given this thread has last had a reply in 2011 (12 years ago), there's probably a slim chance anyone still participating here would have this PSU... but who knows, of course.
                        Do you have a multimeter at your disposal? If yes, we may be able to deduce the value of C18 simply by knowing how it's connected in the circuit. Looking at pictures earlier in the thread and also this one, C18 appears to be on the primary side, connected to the optocoupler through resistor R26 (470 Ohms) and then goes through a few resistors and connects either to small transistor Q5 or the Gate/Base of the larger transistor on the heatsink (it's a bit hard to tell from the pictures from other posts... so if you could provide further pictures, that would be very helpful. Just please attach them to the forum using the built-in attachment feature, so the images are hosted here and not on an external website.)
                        With your multimeter, can you verify if one side of C18 connects to primary-side ground (the negative lead of the big capacitor on the primary side)?
                        If yes, I suspect C18 may not be entirely critical (probably there for when the 5VSB circuit is running completely unloaded.)
                        This PSU appears to be made by Channel Well Technology (CWT), but the 2-transistors 5VSB self-oscillating circuit they used here does not seem too similar to their ISO -line designs. However, looking at my collection of 5VSB schematics, the closest that might resemble something like your 5VSB circuit is from a HEC Orion HP585d I posted here:
                        https://www.badcaps.net/forum/attach...1&d=1578459617
                        ^ On that one, your C18 would likely correspond to the 0.47 nF ceramic capacitor connected to the Base of the smaller PN2222A transistor in the above schematic.
                        Now, I also have a Deer DR-250ATX PSU's 5VSB schematic (that I have not posted on BCN yet), which also appears very similar to the HEC Orion HP585d 5VSB circuit. On that one, the capacitor has a value of 2.2 nF... but the series resistor corresponding to R26 is only 100 Ohms. So I suspect the higher capacitance used in the DR-250ATX 5VSB is due to the lower series resistance (100 Ohms) after the optocoupler... whereas on the HP585d, it's the same 470 Ohms as your R26.
                        That being said, I think there's a good chance a value of 0.47nF to 1 nF should work OK... or maybe even up to 2.2 nF.
                        Either way, just beware that if everything is not perfectly right with these 2-transistor 5VSB circuits, they tend to blow up a lot of parts. So double-check all of the other parts in the circuit before powering it up. I'm sure you probably already found many other parts bad. The main take-away is to make sure the output capacitors on the secondary side of the 5VSB (EC6 & EC7), as well as the "startup" / "critical" capacitor (EC4) are all good.
                        And even if everything checks out OK, it would still be a good idea to use a series incandescent light bulb in series with the PSU's AC Live to limit the current / power going into the primary side, in case there is still something wrong with the 5VSB circuit. This could save you from blowing up fuses and many other parts.
                        The series incandescent bulb "trick" is detailed here:
                        https://www.badcaps.net/forum/showpo...51&postcount=6
                        and here:
                        https://www.badcaps.net/forum/showpo...4&postcount=70
                        Use 40-60 Watt bulb at first... and if needed, then maybe jump to 100 Watts.
                        Since incandescent bulbs can be hard to find above 40 Watts, you could also use something like a 60-72 Watt Halogen... or 2x 35W halogen bulbs in parallel (equivalent to a 70W Halogen)... OR, 2x 40W appliance incandescents in parallel (equivalent to 80 Watts incandescent.)
                        Let us know what you find.
                        • need_info
                          • Mar 2020
                          • 9
                          Hi momaka, thanks for all of the help/information. I would like to answer your questions with some confidence; so I am looking at the pcb and trying to see exactly how c18 fits into the picture. I will get back when that work is done. Jon
                          • need_info
                            • Mar 2020
                            • 9
                            hi,
                            Took a couple of photos. Not sure what you were looking for so ask away.
                            The two missing diodes are: D9 FR103, D8 1N4004. Some other components have not been replaced yet. Most of the ECnn have been replaced.
                            Jon
                              master hoarder
                              • May 2008
                              • 12170
                              • Bulgaria
                              #34
                              Hi Jon,
                              Thanks for the good quality pictures, they really help trace the circuit out.
                              Give me a day or two, and I'll try to draw out a schematic for this 5VSB circuit, based on your pictures. Hopefully that might make it easier to understand some of the values.
                              But in any case, it looks like C18 is indeed a low-value capacitor, somewhere in the low nF range (again, 0.47 to 2.2 nF likely.)
                              R29 also seems to have obliterated, taking the trace along with it. But I think the 5VSB can be tested without R29 and D9 for now, as it appears these are for the primary side aux. supply (which provides power to the main PS PWM controller on the primary side.)
                              D8 and the burned Zener diode next to EC3 need to be replaced, though.
                              • need_info
                                • Mar 2020
                                • 9
                                It appears that ZD3 is trashed. However, I have no idea what it's value is either. Maybe this is a hopeless idea to make it whole again?
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  • Bulgaria
                                  #36
                                  Nah, can't let that stop us (yet.)
                                  According to post #21 by kc8adu, ZD3 = 10V, 1W Zener
                                  ... which sounds about right.
                                  Anyways, I drew a schematic (finally) and will scan it tomorrow when I get a chance, then upload it here.
                                  Meanwhile, if you could provide part #'s for the following below (so I can complete my schematic a little more), that would be awesome
                                  R22
                                  R23
                                  D7
                                  C16
                                  Q5
                                  R28
                                  C17
                                  TO-220 transistor on the heatsink
                                  • need_info
                                    • Mar 2020
                                    • 9
                                    hi,
                                    I have attached my shot (hold the laughter please) at a schematic fragment and my spreadsheet of relevant parts. (The transistors attached to the heatsink are hard to see; I'll work on it and the other parts for identification.)
                                    thanks, Jon
                                    • need_info
                                      • Mar 2020
                                      • 9
                                      Mo, here is the way I read the components requested:
                                      R22 red, black, green...gold: 2M 5%
                                      R23 green, blue, orange...gold: 56K 5%
                                      D7 LT 5323/UF1007
                                      C16 TL/222M/1KV: 2.2nF
                                      Q5 KN/2222A/438
                                      Q6 UTC/2SA684/RJ0A
                                      R28 violet, green, silver...gold: 0.75 5%
                                      C17 J525/222/XCK: 2.2nF
                                      TO-222 FB F02/FQPF/5N60C
                                      if these don't make sense or you want something else, please let me know, Jon
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        #39
                                        Awesome!
                                        Below is a schematic of the Antec AR300 5VSB circuit I was able to draw from the pictures provided so far.
                                        To anyone reading, please note that I don't have this PSU in front of me, so don't assume the schematics are 100% accurate. If anything, I drew the secondary side in a rush, so some components may not be placed right (R34, R31, C19.) The primary side should be mostly right, though. It seems to resemble the circuit of the HEC Orion PSU I linked to earlier in post #31 and some other 5VSB circuits I've drawn before.
                                        Some interesting observations:
                                        This 5VSB circuit has two (2) primary-side auxiliary outputs - one for its own feedback loop (generated by D8 and filtered by EC3), and one for the PWM controller of the main PS (generated by D9 and filtered by EC4, with ZD4 serving as OV protection), which I labeled "Pri. Aux." on the above schematic.
                                        Note that you don't need to have the Pri. Aux. circuit working to have the 5VSB working. In other words, for anyone troubleshooting this PSU's 5VSB, you can still get 5VSB output, even if R29 & D9 are completely removed from the circuit. In fact, it's preferable to have those components removed while troubleshooting the 5VSB. Once 5VSB operations has been successfully restored, then R29 and D9 can be replaced back in the circuit.
                                        Regardless of the repair steps taken, make sure EC3, EC6, and EC7 are in GOOD HEALTH before powering on the 5VSB circuit. EC3 is the startup & "critical" cap of the 5VSB circuit. If it goes high ESR, the voltage on the output may start rising... or alternatively, ZD4 may get burned out, along with resistor R29.
                                        As always, I recommend to use an incandescent / halogen bulb in series with the PSU's live AC input to prevent component damage if something was missed and/or not replaced by mistake.
                                        • need_info
                                          • Mar 2020
                                          • 9
                                          Mo, great schematic and accompanying notes. And just from the pictures. Jon
                                          • aidanmo
                                            Philips 43PUS7506/12 - Loud blown out sound
                                            by aidanmo
                                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                                            • Using the internal speakers, it always happens.
                                            • Using the headphone jack, it never happens.
                                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                            02-28-2025, 03:13 PM
                                          • mon2
                                            Crate guitar amp with extremely loud static on power on (no input)
                                            by mon2
                                            Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                                            07-18-2025, 06:40 AM
                                          • RetroComputingGrotto
                                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                            by RetroComputingGrotto
                                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                            What component(s)...
                                            02-03-2025, 06:00 AM
                                          • justice171
                                            Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                                            by justice171
                                            Hello Badcaps Members,
                                            I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                                            I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                                            When I use Lenovo PC Diagnostics App I get results as 01000
                                            Here are the details:
                                            • Model: Lenovo ThinkPad E15 Gen 2
                                            • Board Numbe
                                            10-01-2024, 09:19 PM
                                          • eliemgh
                                            lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                                            by eliemgh
                                            lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                                            09-27-2024, 02:40 AM
