Lenovo E15 Gen 2 Keeps Beeping Loud Noise
  • justice171
    • Feb 2018
    • 109
    • South Africa
    Hello Badcaps Members,
    I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
    I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
    When I use Lenovo PC Diagnostics App I get results as 01000
    Here are the details:
    • Model: Lenovo ThinkPad E15 Gen 2
    • Board Number: GE4B0/GE5B0 (NM-D011)
    • CPU: Intel Core i5 11th Gen
    Attached is a video link showing the issue. Any ideas or suggestions on what might be causing this would be greatly appreciated!
    Thanks in advance!
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    I guess this issue runs in Thinkpad E15 Gen 2
    Had exactly same thing with few of them and have not figured out how to fix them. Also had units playing random and kind of interrupted / corrupted sounded beep codes with no post or display..
    I tried reflashing BIOS and EC but it did not help.
    With or without memory module it makes same thing
    Worth to discuss possible solutions here
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Consumption of 0.23A is perhaps indicating presence of 3.3V/5V/1.8V /1.2V rails unless there is some short.
      VCCSA present.(The name may be different in schematic)?
      • justice171
        • Feb 2018
        • 109
        • South Africa
        Consumption of 0.23A is perhaps indicating the presence of 3.3V/5V/1.8V /1.2V rails unless there is some short.
        Lol, You are the genius man (The System Agent Voltage (Vccsa) of (0.9​ - 0.8)V was not present I've removed the heatsink, and BOOM 0.9V present, the laptop is ON.
        Somehow the heatsink is creating a short.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Use kapton tape to insulate the heatsink touching the VCCSA regulator area.
          • tomodachi
            • Apr 2012
            • 610
            • Turkey
            Thanks mcplslg123 for solution
            • trepachka
              • Oct 2022
              • 456
              I can confirm I have come across several of these with exactly the same issue: a loud obnoxious unrelenting tone. The tone would go away temporarily if pressed on the motherboard around the heatsink area sometimes. When removing the heatsink, the tone would go away. Solution by mcplslg123 is what fixes the issue.
              • huzo
                • Sep 2014
                • 187
                • CROATIA
                this didn't work for me...neither the other bios dumps...
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 499
                  • somewhere in europe
                  keep in mind that this can indicate cold solder joints under the cpu/pch as well. this happens very often on "modern" lenovo machines due to the bad solder quality.
                  • trepachka
                    • Oct 2022
                    • 456
                    Earlier today I had encounter with another motherboard with identical issue, same music pattern. Previous suggestion by mcplslg123 that worked for me before didn't work this time. Indeed, when pressed in certain areas with a finger, the sound goes away and the motherboard boots just fine. In this case, I used a heat gun @ 480c for about 2 minutes working on and around the cpu/pch chip area, occasionally pressing on the top and bottom left corners of the chip. After the motherboard cooled off, I had the notebook fired up and so far it ran all day without making that sound. I did try to flex the computer to see if the problem rears its ugly head and so far no problems. Just keep in mind, the musical tone occurs only at motherboard startup. Once the computer boots, you can't reproduce the issue.
                    So, I think you are right it's cold solder joints under the cpi/pch and they are only responsible for getting the cpu to start. Once the cpu kicks in, those colder joints do not affect cpu performance.
                    • bomber8596
                      • Nov 2018
                      • 38
                      • Italy
                      It worked for me too. In this case I used a slightly different method, preheated the card to 100 degrees to avoid stressing the integrated circuits and with hot air at 370 degrees wind 60% for a minute I acted in rotation at about 5 centimeters away from the CPU and for another minute I lowered the torch to 2 centimeters always maintaining a slow rotary movement. thanks bro
                      • tomodachi
                        • Apr 2012
                        • 610
                        • Turkey
                        Update
                        Only way to fix this is to reballing CPU
                        Done many since my last post, none of them returned so far
                        • Kiwoz
                          • Dec 2024
                          • 4
                          • Italien
                          Originally posted by tomodachi
                          Update
                          Thanks for your update. Reballed the CPU like you said and it works like a charm!
                          • Laboratorio JG
                            • Apr 2025
                            • 29
                            • Colombia
                            Originally posted by justice171
                            Lol, You are the genius man (The System Agent Voltage (Vccsa) of (0.9 - 0.8)V was not present I've removed the heatsink, and BOOM 0.9V present, the laptop is ON.
                            You're absolutely right. I put heat tape on it and it stopped beeping and gave a video. Thanks for the info.
                            • eliemgh
                              lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                              by eliemgh
                              lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                              09-27-2024, 02:40 AM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                              Lenovo 3000 Series Schematic
                              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                              3000 C100 laptop with Braille keyboard
                              Lenovo 3000 C
                              C100, C200 - 15-inch XGA screen
                              Lenovo 3000 N
                              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                              N500 - 15.4 inch screen.
                              Lenovo 3000 V
                              V100, V200 - 12.1-inch WXGA models
                              Lenovo 3000 G
                              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                              10-04-2024, 06:05 AM
                              Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                              09-06-2024, 06:40 AM
                              This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                              09-06-2024, 06:06 AM
