Weird issue with parallel Li Ion (need help with board design!)
  • audiomodder
    • Dec 2017
    • 54
    Hey all-
    So I have a very strange issue I need help with. It has to do with connecting 2 of these in parallel:
    https://www.ebay.com/itm/10pcs-LiPol...53.m1438.l2649
    They have a protection board for each of them, the DW01-P (attached).
    I am using this to power a small audio / video device that consumes < 2A from the both of them (total). There was a lot of background noise / audio rippley distortion crap that went away only when I plugged in the USB charger (!)... OR, I found out, when I only have one battery connected. They are fighting each other in parallel (even though they balanced out a long time ago).
    I think the li-ion PCBs are confusing each other and going into over discharge protect (ODP) mode and then back on ever few milliseconds. It's weird and I've never seen this before.
    Any ideas on what I could do? Some kind of filter or balancer IC would be great.
    Re: Weird issue with parallel Li Ion (need help with board design!)
    Do you have the scope to look for what kind of noise you are getting from the batteries and at the audio output?
      • Jul 2011
      • 6037
      What happens when you only use one battery do you have the same problem
        • Jul 2011
        • 6037
        Originally posted by audiomodder
        Hey all-
        Some time you can put the protection in parallel and it works but sometimes for some reason they will not work together
        Have you ever solder on these types boards before it can be done but you have to VERY CAREFUL doing this
        The first thing you need to make sure of is that you take your time and do not be in a hurry
        There are two ways to do this
        One is to take the protection boards off of both batteries ———->
        PLEASE MAKE SURE that you have the the positive terminal of both batteries and the negative terminals of both batteries facing the same way BEFORE you solder the terminals together otherwise you are going to have very BIG mess on your hands if you not have this right and it will happen very very fast the battery pouchs will explode
        I know I had it happen to me once a good thing they were very small batteries it could have been very very bad
        Then use only one protection board
        One very important note the positive terminal on these batteries is very easily broken off the part you can solder and the part of terminal that is left you cannot solder to them then you are out of luck
        Unless you have a battery spot welder to weld a piece battery tabbing so you can solder it again
        Second way to do this is take the protection board off of only one battery
        But if you do it this way you need to get some heat shrink tubing that big enough to put the two batteries together before you start soldering them together
        And really you should do this either way you choose to put the batteries together
        I have put these types of batteries together in parallel with the protection boards sometimes it works with out any problems and sometimes it does not work
        You can have the same type of problem if you put them in series they will power the device but you can not change the batteries
        It all depends on what type of protection boards they are using
        Or could be that the device does take more power than the protection board can give it if this is the case then you need to find a protection board that can handle the power this device needs
        I know this because I have a NextBook tablet that I bought a replacement battery and it did not like the protection board that was on the replacement battery I had use the protection board off the old battery for it to work right
        The problem was that it would not charge right and it would not turn ON unless you had the charger hook up to the tablet
        • petehall347
          • Jan 2015
          • 4426
          never used those cells i parallel . not something i would consider . if i was to i might think of resistor divider to balance them a little bit . no 2 things are exactly alike .
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            I agreee with sam_sam_sam - pull the protection board off one cell and only use one board for both parallel cells.
            A working TV? How boring!
            • gabiz_ro
              • Mar 2011
              • 167
              May or may be not OK
              Protection board is designed for 1 cell.
              In this case one with 1500mA
              Over current protection may trigger at 2000mA
              In that case may be at limit,a little increase of volume may result in increase current to 2A amd protection will switch off cell.
              • audiomodder
                • Dec 2017
                • 54
                Thanks for the suggestions everyone.
                As I am making this board for production, removing / modifying the Lipo PCB really isn't a good alternative at all. I plan to sell 100s of these.
                I seem to have fixed the issue though. Not entirely sure how, but what I did was:
                1) matched new connectors / cables for each battery (same length, too)
                2) rebalanced both batteries (charged each separately
                3) added much larger cap (470uf instead of 100uf) to audio board
                So far, so good! Maybe the issue will turn up later when / if they unbalance...
                Also, the circuit for the audio already has a nice LC filter, though adding another one couldn't hurt I guess. If I want to go really nuts, I could step up and use an LDO just for the audio board...yuck that is not a great solution. Let's just see where this goes in the meantime,
                I scoped everything btw, but it was really hard to see the noise. the power rail is <100mV noise level, probably closer to 50mV. It looked really clean but obviously something was in the audible frequency range.
                • petehall347
                  • Jan 2015
                  • 4426
                  maybe consider an over temperature cut out , just in case . i know very little about those cells but i do know they are a fire risk .
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    use 1 protection board rated to handle the load and parallel as many cells as you want to get the needed capacity.
                    multiple boards in parallel will always have quirks as they are never going to trip at the same current.
                    • Soulzink
                      Samsug washing machine. Power supply DC41-00189a board issue
                      by Soulzink
                      I am trying to fix a samsung washinmachine power supply main board.
                      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                      The power supply board reference is the following: DC41-00189a
                      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                      04-19-2025, 06:26 AM
                    • Asraf Atb
                      Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                      by Asraf Atb
                      Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                      Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                      I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                      01-27-2025, 05:02 PM
                    • notallbad
                      TCL 55RP620K power board issue
                      by notallbad
                      Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                      0% p_dim at 1.65v and a_dim at 1v
                      50% p_dim at 3.3v and a_dim at 1.65v
                      100% p_dim at 3.3v and a_dim at 2.88v
                      Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                      Leds are 2 rows of 15 6v leds.
                      On inspection of the power board found diode MBR3200 shorted so replaced with...
                      07-12-2025, 05:45 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • howardc64
                      by howardc64
                      Yesterday, 05:17 PM
