Hi All,
First off, I'd like to thank Topcat for starting this forum (and his business). Thanks also to all the very knowledgable guys who contribute. Certainly makes life easier for newbies like me just starting out on the re-capping road.
I have an Antec True550 PS which needs re-capping. It contained one Fuhjyyu 4700uf @ 10 volts (TM series) which had started leaking from the top, and had blown the bung on the bottom. There were three Fuhjyyu 3300uf @ 10 volts (TMR series), one of which had leaked at the top. All of these were located in the same area glued to one another. Are these caps a part of the 5 volt rail?
There were two Teapo 3300uf @ 16 volts (A3 series?). These were glued together in the same area.Neither were visually bad, but I'll replace them anyway. Are these caps part of the 12 volt rail?
There were two Fuhjyyu 1000uf @ 10 volts (TNR series) and one 470uf @ 16volts (TNR series). None were visually bad but I'm going to replace them. What rail are these caps associated with?
I've been looking at the replacements Topcat has in both Rubycon and Samxon and I wanted you all to help me make sure I'm getting the correct caps.
For the fu 4700uf, I'm getting the Rubycon 4700uf PX series.
For the fu 3300uf, I'm getting the Samxon 3300uf RS series.
For the teapo 3300uf, I'm getting the Samxon 3300uf 16v RS series.
For the fu 1000uf, I'm thinking about getting the Rubycon 1200uf @ 10v ZL series.
For the fu 470uf, I'm thinking about getting the Rubycon 680uf @ 16v ZL series
I approximated the uf values for the fu 1000 uf's and the 470 uf as I'd read in these forums that ultra low esr caps are not desirable. Will the larger uf values be acceptable for this power supply application?
Also, one other question, who is the maker of the two large caps? They only have an insignia of an "M within a square" on them.
Thanks, in advance, Richard
