RELAND SUN 6.3v 3300uf Low or High ESR?
  • Oldschool297
    • Jun 2023
    • 24
    • Sweden
    I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
    https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
    • 31303
    Re: RELAND SUN Low or High?
    3300 in a 10x20 package is questionable.
    dont buy them.
    maybe you could find some 2700uf chinese polymers in 10mm - those would be worthy of trying
    • Oldschool297
      • Jun 2023
      • 24
      • Sweden
      You got a point , i only wanted to try if the board post before buying more exspensive. You can solder them away but if i can save money. What would you recommend for the best performance if the price gets higher? Sanyo should be good. But 10 caps is often for around 30-40$.
      • andrewsawesomr
        • Jun 2022
        • 101
        • United States of America
        If you want Sanyo WG, LCSC (https://www.lcsc.com) sells them (they can also do transactions in Swedish Krona). It's kr 146.05 with shipping to where you are (about $13 US).
        https://www.lcsc.com/product-detail/...G_C242095.html
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          You can also do quite well via Mouser, can get the caps well below €1 each and as long as you have some more stuff you need you will get free shipping on order over ca 400:-
          https://www.mouser.se/c/passive-comp...R&sort=pricing
          But if you want just some caps you might want to contact member Behemot instead:
          http://www.hwworld.cz/index.php?opti...ory&Itemid=102
            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
            I tested the battery cells there are installed right now and they are testing good with no issues that I...
            02-04-2025, 08:08 PM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • ictc
            Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
            by ictc
            I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
            Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
            The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
            02-25-2025, 12:15 PM
